標題: 16*16點陣循環漢字 [打印本頁]
作者: chqqppbb    時間: 2023-12-25 18:27
標題: 16*16點陣循環漢字
#include <reg51.h>
#define out0 P0
#define out1 P1
#define out2 P2
void delay(uint y) //延時函數
        uchar x=250;
        for(;y>0;y--)
                while(--x);
                x=100;
uchar code string[]=
/*--  文字:  歡  --*/
/*--  宋體14;  此字體下對應的點陣為:寬x高=19x19   --*/
/*--  寬度不是8的倍數,現調整為:寬度x高度=24x19  --*/
0x08,0x68,0xE8,0xC8,0x88,0xE8,0xF8,0x78,0x88,0xF0,0xFE,0xFE,0xE6,0xA0,0x20,0xE0,
0xF0,0x60,0x00,0x00,0xC0,0xE0,0x79,0x1F,0x1F,0x7F,0x78,0xE3,0xC1,0xF8,0x3F,0x1F,
0x7F,0xF9,0xC1,0x80,0x00,0x00,0x80,0x80,0x86,0x9E,0x9C,0x98,0xF8,0xFC,0xFC,0x04,
0x06,0xFE,0xFC,0xF8,0x08,0xF8,0xF8,0xF8,0x00,
/*--  文字:  迎  --*/
0x80,0xC0,0xC0,0x7F,0x7F,0xC0,0xCF,0x9F,0x9F,0x8C,0x84,0xFF,0xFF,0xFF,0x88,0x9F,
0x9F,0x8F,0x00,0x00,0x00,0x00,0x08,0x18,0xF8,0xF0,0x60,0xFE,0xFE,0xFE,0x80,0xE0,
0x78,0x38,0x10,0x80,0x00,0x00,0x00,0x01,0x01,0x01,0x81,0xF1,0x7F,0x3F,0x03,0x01,
0xFF,0xFF,0x01,0x01,0x01,0x01,0xF1,0xF1,0x00,
/*--  文字:  光  --*/
0x00,0xFC,0xFC,0xF8,0xFF,0xFF,0xFF,0xC0,0x78,0x3E,0x2F,0x6F,0xE8,0xC8,0xC8,0x0C,
0x0C,0x08,0x00,0x00,0x7F,0x7F,0x3F,0xFF,0xFF,0xFF,0x00,0xFE,0xFE,0x82,0xFE,0xFE,
0xFF,0x83,0xFE,0xFE,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  臨  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
{        uchar i,j,n;
                for(j=0;j<4;j++)
                        for(n=0;n<40;n++)
                                for(i=0;i<15;i++)
                                        out1=i%15;
                                    out0=string[i*2+j*32];
                                        out2=string[i*2+1+j*32];
                                        delay(4);
                        delay(40);
                        out0=0x00;        //點陣正極接P0和P2口,所以給0熄滅
                        out2=0x00;
作者: cgmadpj    時間: 2024-5-16 23:46
  out1=i%15啥意思?大佬們給萌新講一下?
