怎么把這個單片機代碼改成具有加減乘除的計算器
晨曦的眷念
2023-12-1 20:43
#include <REG52.H>
sbit ADDR0=P2^2;
sbit ADDR1=P2^3;
sbit ADDR2=P2^4;
sbit ADDR3=P2^5;
sbit ENLED=P2^6;
sbit KEY_IN_1=P1^3;
sbit KEY_IN_2=P1^2;
sbit KEY_IN_3=P1^1;
sbit KEY_IN_4=P1^0;
sbit KEY_OUT_1=P1^7;
sbit KEY_OUT_2=P1^6;
sbit KEY_OUT_3=P1^5;
sbit KEY_OUT_4=P1^4;
unsigned char code LedChar[]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40
unsigned char LedBuff[6]={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF
unsigned char code KeyCodeMap[4][4]={
{0x31,0x32,0x33,0x26},
{0x34,0x35,0x36,0x35},
{0x37,0x38,0x39,0x28},
{0x30,0x1B,0x0D,0x27}
unsigned char KeySta[4][4]={
{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}
void KeyDriver();
ENLED=0;
ADDR3=1;
TMOD=0x01;
TH0=0xFC;
TL0=0x67;
EA=1;
ET0=1;
TR0=1;
LedBuff[0]=LedChar[0];
KeyDriver();
void ShowNumber(unsigned long num)
signed char i;
unsigned char buf[6];
for(i=0;i<6;i++)
buf[i]=num%10;
num=num/10;
for(i=5;i>=1;i--)
if(buf[i]==0)
LedBuff[i]=0xFF;
break;
for(;i>=0;i--)
LedBuff[i]=LedChar[buf[i]];
void KeyAction(unsigned char keycode)
static unsigned long result=0;
static unsigned long addend=0;
if((keycode>=0x30)&&(keycode<=0x39))
addend=(addend*10)+(keycode-0x30);
ShowNumber(addend);
else if(keycode==0x26)
result += addend;
addend=0;
ShowNumber(result);
else if(keycode==0x0D)
result += addend;
addend=0;
ShowNumber(result);
else if(keycode==0x1B)
addend=0;
result=0;
ShowNumber(addend);
void KeyDriver()
unsigned char i,j;
static unsigned char backup[4][4]={
for(i=0;i<4;i++)
for(j=0;j<4;j++)
if(backup[i][j] != KeySta[i][j])
if(backup[i][j] !=0)
KeyAction(KeyCodeMap[i][j]);
backup[i][j]=KeySta[i][j];
void KeyScan()
unsigned char i;
static unsigned char keyout=0;
static unsigned char keybuf[4][4]={
{0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF},{0xFF,0xFF,0xFF,0xFF}
keybuf[keyout][0]=(keybuf[keyout][0]<<1)|KEY_IN_1;
keybuf[keyout][1]=(keybuf[keyout][1]<<1)|KEY_IN_2;
keybuf[keyout][2]=(keybuf[keyout][2]<<1)|KEY_IN_3;
keybuf[keyout][3]=(keybuf[keyout][3]<<1)|KEY_IN_4;
for(i=0;i<4;i++)
if((keybuf[keyout][i]&0x0F)==0x00)
KeySta[keyout][i] = 0;
else if((keybuf[keyout][i]&0x0F)==0xFF)
KeySta[keyout][i] = 1;
keyout++;
keyout=keyout&0x03;
switch(keyout)
case 0:KEY_OUT_4=1;KEY_OUT_1=0;break;
case 1:KEY_OUT_1=1;KEY_OUT_2=0;break;
case 2:KEY_OUT_2=1;KEY_OUT_3=0;break;
case 3:KEY_OUT_3=1;KEY_OUT_4=0;break;
default:break;
void LedScan()
static unsigned char i=0;
P0=0xFF;
switch(i)
case 0:ADDR2=0;ADDR1=0;ADDR0=0;i++;P0=LedBuff[0];break;
case 1:ADDR2=0;ADDR1=0;ADDR0=1;i++;P0=LedBuff[1];break;
case 2:ADDR2=0;ADDR1=1;ADDR0=0;i++;P0=LedBuff[2];break;
case 3:ADDR2=0;ADDR1=1;ADDR0=1;i++;P0=LedBuff[3];break;
case 4:ADDR2=1;ADDR1=0;ADDR0=0;i++;P0=LedBuff[4];break;
case 5:ADDR2=1;ADDR1=0;ADDR0=1;i=0;P0=LedBuff[5];break;
default:break;
void InterruptTimer0() interrupt 1
TH0=0xFC;
TL0=0x67;
LedScan();
KeyScan();
clyf
2023-12-11 19:53
static unsigned long operand1 = 0; // 第一個操作數
static unsigned long operand2 = 0; // 第二個操作數
static unsigned char operator = 0; // 操作符,1代表加法,2代表減法,3代表乘法,4代表除法
static bit inputSecondOperand = 0; // 標記是否輸入第二個操作數
if (keycode >= 0x30 && keycode <= 0x39) // 數字鍵
if (!inputSecondOperand)
operand1 = operand1 * 10 + (keycode - 0x30);
ShowNumber(operand1);
operand2 = operand2 * 10 + (keycode - 0x30);
ShowNumber(operand2);
else if (keycode == 0x26) // 加法
operator = 1;
inputSecondOperand = 1;
else if (keycode == 0x35) // 減法
operator = 2;
else if (keycode == 0x28) // 乘法
operator = 3;
else if (keycode == 0x27) // 除法
operator = 4;
else if (keycode == 0x0D) // 等號
unsigned long result = 0;
switch (operator)
case 1: // 加法
result = operand1 + operand2;
break;
case 2: // 減法
result = operand1 - operand2;
break;
case 3: // 乘法
result = operand1 * operand2;
break;
case 4: // 除法
if (operand2 != 0)
result = operand1 / operand2;
// 處理除數為0的情況
break;
default:
break;
operand1 = result;
operand2 = 0;
ShowNumber(result);
else if (keycode == 0x1B) // 清零
operand1 = 0;
operand2 = 0;
operator = 0;
ShowNumber(0);
需要修改KeyAction函數,以便能夠實現加、減、乘、除等操作。試試,不知道能否成功
