標(biāo)題: STM32單片機(jī)RC522門(mén)禁程序(含保存IC卡功能掉電不丟失) [打印本頁(yè)]
作者: cxjbook    時(shí)間: 2023-11-29 20:20
單片機(jī)源程序如下:
  1. #include "delay.h"
  2. #include "sys.h"
  3. #include "usart.h"
  4. #include "rc522.h"
  5. #include "LED.h"
  6. #include "Key.h"
  7. #include "OLED.h"
  8. #include "Store.h"
  9. #include "Servo.h"
  10. /**
  11. *   連線說(shuō)明:
  12. *   1--SDA  <----->PA4
  13. *   2--SCK  <----->PA5
  14. *   3--MOSI <----->PA7
  15. *   4--MISO <----->PA6
  16. *   5--懸空
  17. *   6--GND <----->GND
  18. *   7--RST <----->PB0
  19. *   8--VCC <----->VCC
  20. **/
  21. uint32_t num;  //
  22. uint8_t j = 0;
  23. int main(void)
  24. {
  25.     delay_init();                     //延時(shí)函數(shù)初始化
  26.     NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置中斷優(yōu)先級(jí)分組為組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
  27.     uart_init(115200);                 //串口初始化為115200
  28.     RC522_Init();       //初始化射頻卡模塊
  29.
  30.                 LED_Init();                //LED???
  31.                 Key_Init();                //?????
  32.                 OLED_Init();                //OLED???
  33.                 Store_Init();
  34.                 Servo_Init();                //?????
  35.
  36.     while(1)
  37.     {
  38.                         Key_GetNum();
  39.                         //先將sn清零
  40.                         SN[0]=0X00;
  41.                         SN[1]=0X00;
  42.                         SN[2]=0X00;
  43.                         SN[3]=0X00;
  44.
  45.                         if (KeyNum == 1)
  46.                         {
  47.                                 //這里執(zhí)行讀卡
  48.                                 OLED_ShowString(1, 1, "moshi:       ");
  49.                                 OLED_ShowString(1, 1, "moshi:du");
  50.                                 RC522_Handel();
  51.                                  //
  52.                                 num = (uint32_t)SN[0] << 24 | (uint32_t)SN[1] << 16 | (uint32_t)SN[2] << 8 | SN[3];
  53.                                 OLED_ShowHexNum(2, 1, num, 8);
  54.                                         //將存儲(chǔ)里的卡號(hào)讀出來(lái)對(duì)比這個(gè)卡號(hào)是否開(kāi)鎖
  55.                                 for (j = 1; j < 255; j ++)                                //
  56.                                 {
  57.                                         if(num==0x00000000){
  58.                                                 //跳出循環(huán)
  59.                                                  break;
  60.                                         }else        if(Store_Data[j]==0x00000000){
  61.                                                 OLED_ShowString(3, 1, "                  ");
  62.                                                 OLED_ShowString(3, 1, "error:failed");
  63.
  64.                                                 //跳出循環(huán)
  65.                                                  break;  //
  66.                                         }
  67.                                         else if(Store_Data[j]==num){
  68.                                                 OLED_ShowString(3, 1, "                  ");
  69.                                                 OLED_ShowString(3, 1, "success:ok");
  70.                                                 //開(kāi)門(mén)
  71.                                                 Servo_SetAngle(90);
  72.                                                 delay_ms(5000);
  73.                                                 Servo_SetAngle(0);
  74.                                                 //跳出循環(huán)
  75.                                                  break;  //
  76.                                         }
  77.                                 }
  78.
  79.                         }
  80.
  81.                         if (KeyNum == 2)
  82.                         {
  83.                                 //這里執(zhí)行授權(quán)
  84.                                 OLED_ShowString(1, 1, "moshi:shouqun");
  85.                                 RC522_Handel();
  86.                                  //
  87.                                 num = (uint32_t)SN[0] << 24 | (uint32_t)SN[1] << 16 | (uint32_t)SN[2] << 8 | SN[3];
  88.                                 OLED_ShowHexNum(2, 1, num, 8);
  89.                                 //將存儲(chǔ)里的卡號(hào)讀出來(lái)對(duì)比這個(gè)卡號(hào)是否存在
  90.                                 for (j = 1; j < 255; j ++)                                //
  91.                                 {
  92.                                         if(num==0x00000000){
  93.                                                 //跳出循環(huán)
  94.                                                  break;
  95.                                         }else        if(Store_Data[j]==num){
  96.                                                 OLED_ShowString(3, 1, "                  ");
  97.                                                 OLED_ShowString(3, 1, "success:exist");
  98.
  99.                                                 //跳出循環(huán)
  100.                                                  break;  //
  101.                                         }else        if(Store_Data[j]==0x00000000){
  102.                                                 Store_Data[j] = num;
  103.                                                 Store_Save();
  104.                                                 OLED_ShowString(3, 1, "                  ");
  105.                                                 OLED_ShowString(3, 1, "success:save ok");
  106.                                                 delay_ms(5000);
  107.                                                 //跳出循環(huán)
  108.                                                  break;  //
  109.                                         }
  110.
  111.                                 }
  112.                         }
  113.
  114.     }
  115. }
原理圖: 無(wú)
仿真: 無(wú)
代碼: RFID-RC522.7z (226.75 KB, 下載次數(shù): 83)
作者: yinqing452    時(shí)間: 2024-2-19 16:39
樓主,這個(gè)程序您測(cè)試過(guò)嗎?為什么用不了呢?
作者: cxjbook    時(shí)間: 2024-2-20 13:07
yinqing452 發(fā)表于 2024-2-19 16:39
提示什么錯(cuò)誤?
作者: cxjbook    時(shí)間: 2024-2-20 13:30
測(cè)試的芯片是stm32f103c8t6,芯片不同內(nèi)置存儲(chǔ)的地址會(huì)有所不同。
作者: cxjbook    時(shí)間: 2024-2-22 11:28
原理圖是stlink的下載方式,我測(cè)試的時(shí)候是用ttl的下載方式,如果要使用stlink的方式下載想要自信再配置一下。
作者: 退役的人    時(shí)間: 2024-4-8 16:26
cxjbook 發(fā)表于 2024-2-20 13:30
工程打開(kāi)之后的默認(rèn)芯片是STM32F103ZE,改成C8之后好多報(bào)錯(cuò)
作者: cxjbook    時(shí)間: 2024-4-9 13:18
退役的人 發(fā)表于 2024-4-8 16:26
由于代碼是多個(gè)項(xiàng)目拼接的,所以會(huì)有一點(diǎn)設(shè)置上的問(wèn)題,但目前ttl的燒錄方式的話是測(cè)試通過(guò)的。
作者: ZhengX5897    時(shí)間: 2024-5-1 19:23
大佬用什么軟件畫(huà)的圖
作者: cxjbook    時(shí)間: 2024-5-2 13:09
ZhengX5897 發(fā)表于 2024-5-1 19:23
大佬用什么軟件畫(huà)的圖
很明顯,原圖不是我畫(huà)的,后面畫(huà)的亂七八糟那個(gè)是我畫(huà)的
作者: gz5353741    時(shí)間: 2024-6-1 21:19
樓主,用ttl的下載方式?jīng)]oled顯示,用不了。
作者: cxjbook    時(shí)間: 2024-6-3 08:37
gz5353741 發(fā)表于 2024-6-1 21:19
可以用的,兩個(gè)按鈕一個(gè)是授權(quán)模式,一個(gè)是讀取模式
作者: gz5353741    時(shí)間: 2024-6-27 11:47
cxjbook 發(fā)表于 2024-6-3 08:37
我用mcuisp 0.993上傳可以了,謝謝樓主分享。
