單片機60秒計時秒表(仿真+程序)
新鄉工程學院
2023-11-3 22:06
單片機60秒計時秒表(仿真+程序)
(70.8 KB, 下載次數: 29)
2023-11-4 01:05 上傳
#include <reg52.h>
unsigned char table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
sbit shi=P0^0;
sbit ge=P0^1;
sbit key0 = P1^5;
sbit key1 = P1^6;
sbit key2 = P1^7;
uint num = 0;
bit key0_enter=0;
bit key1_enter=0;
bit key2_enter=0;
void init(void)
ge = 1;
shi = 1;
EA = 1;
IT0 = 1;
void delay(uchar ms)
uchar i ,j;
for (i=0;i<ms;i++)
for(j=101;j>0;j--);
void key_loop()
if ((key0==0)&&(key0_enter==0))
key0_enter=1;
EX0=1;
if(key0==1)
key0_enter=0;
if ((key1==0)&&(key1_enter==0))
key1_enter=1;
EX0=0;
if(key1==1)
key1_enter=0;
if ((key2==0)&&(key2_enter==0))
key2_enter=1;
num = 0;
if(key2==1)
key2_enter=0;
void display()
static uchar nms=0;
static bit wei=0;
uchar ges=0;
uchar shis=0;
nms++;
if(nms>5)
nms=0;
if(wei)
shis=(num/10)%10;
ge=0;
shi=0;
P2=table[shis];
shi=1;
wei=0;
ges=num%10;
ge=0;
shi=0;
P2=table[ges];
ge=1;
wei=1;
init();
for(;;)
key_loop();
display();
delay(1);
void waibu() interrupt 0
num++;
仿真程序51hei附件下載:
共陽極單片機.7z
(69.93 KB, 下載次數: 29)
2023-11-4 01:05 上傳
點點賣豆腐
2024-1-3 19:33
這是AT89C51板子嗎
Noki715
2024-1-4 12:54
點點賣豆腐 發表于 2024-1-3 19:33
這是AT89C51板子嗎
這個就是at89c51的
