標題: TLC549轉換器應用模真+仿真C語言源代碼-已測可用 [打印本頁]
作者: 風揚互聯(lián)    時間: 2023-10-20 08:22
TLC549轉換器電路Proteus仿真原理圖如下:
  1. /*
  2. *軟 件 標 題:TLC549 AD采樣子程序
  3. *軟 件 說 明:從TLC549讀取采樣值
  4. *_________________________________________
  5. *
  6. */
  7. #include <REGX51.H>//頭文件
  8. #include "intrins.h"
  9. #define    Wait1us        _nop_();
  10. #define    Wait2us        {_nop_();_nop_();}
  11. #define    Wait4us        {Wait2us;Wait2us;}
  12. #define    Wait8us        {Wait4us;Wait4us;}
  13. #define    Wait10us      {Wait8us;Wait2us;}
  14. #define    Wait30us      {Wait10us;Wait8us;Wait4us;Wait2us;}
  15. /************定義接口總線**************/
  16. sbit Clock = P1 ^ 5; //時鐘口線
  17. sbit DataOut = P1 ^ 4; //數(shù)據(jù)輸出口線
  18. sbit ChipSelect = P1 ^ 3; //片選口線
  19. /************接口總線定義結束**********/
  20. /*********函數(shù)名稱:ADCSelChannel********
  21. *
  22. *功能:轉換指定通道的模擬量為數(shù)字量
  23. *
  24. *說明:
  25. *
  26. *位置:1
  27. *
  28. ****************************************/
  29. unsigned char ADCSelChannel(void)
  30. {
  31.       unsigned char ConvertValue = 0;
  32.       unsigned char i;
  33.       ChipSelect = 1; //芯片復位
  34.       ChipSelect = 0;
  35.       ChipSelect = 1;
  36.       Clock = 0;
  37.       Wait4us;
  38.       ChipSelect = 0; //芯片起始
  39.       Wait4us; //等待延時
  40.       for (i = 0; i < 8; i ++) //輸入采樣轉換時鐘
  41.       {
  42.             Clock = 1;
  43.             Clock = 0;
  44.       }
  45.       ChipSelect = 1; //開始轉換
  46.       Wait10us; //等待轉換結束
  47.       ChipSelect = 0; //讀取轉換結果
  48.       Wait4us;
  49.       for (i = 0; i < 8; i ++) //
  50.       {
  51.             Clock = 1;
  52.             ConvertValue <<= 1;
  53.             if (DataOut)
  54.             {
  55.                    ConvertValue = 0x1;
  56.             }
  57.             Clock = 0;
  58.       }
  59.       ChipSelect = 1;
  60.       return (ConvertValue); //返回轉換結果
  61. }
  1. #include <REGX51.H>//頭文件
  2. #include "intrins.h"//空操作文件
  3. #include<stdio.h>
  4. #include<stdlib.h>
  5. #define  uchar unsigned char//宏定義char
  6. #define  uint          unsigned int//宏定義int
  7. void delay(long i){while(i--);}
  8. uchar code tb[10] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};//數(shù)碼管段選
  9. uchar code seg_bit_scan[]={0xef,0xdf,0xbf,0x7f}; //各個數(shù)碼管對應的位選數(shù)據(jù)
  10. sbit data_temp=P1^4;//數(shù)據(jù)線(讀出數(shù)據(jù))
  11. sbit cs=P1^3;//片選
  12. sbit sclk=P1^5;//io口時鐘
  13. uint j;        uchar qian,bai,shi,ge;
  14. void chuli(uint num)          //顯示程序
  15. {
  16.
  17.   qian=num/1000%10;              //千,百,十,個處理
  18.   bai=num/100%10;
  19.   shi=num/10%10;
  20.   ge=num%10;
  21.   }
  22. uint ad_549()                    //TLC549處理
  23. {
  24.   uchar i;
  25.   uint data_ad=0;
  26.   cs=1;//先拉高電平 //初始化,啟動
  27.   sclk=0;//clk拉低電平
  28.   cs=0;//cs拉低電平
  29.   _nop_();//空操作 5微妙
  30.
  31.    for(i=8;i>0;i--)//循環(huán)讀取8位A/D轉換結果
  32.         {
  33.                 data_ad<<=1;
  34.                 data_ad=data_temp|data_ad;
  35.                 sclk=1;
  36.                 _nop_();_nop_();
  37.                 sclk=0;
  38.                 _nop_();
  39.         }//循環(huán)八次 讀到一個8個2進制數(shù)
  40.   cs=1;//cs拉高電平
  41. sclk=0;
  42.            if (data_ad==0xff) data_ad=data_ad+1.953125 ;
  43.            data_ad=data_ad*19.53125;//采集到的0--255,對應0--5V
  44.   return(data_ad);//返回ad的數(shù)據(jù)
  45. }
  46. void timer0_isr(void)  interrupt 1//定時器的0中斷服務函數(shù)
  47. {
  48.
  49.         TR0=0;//關閉定時器0
  50.         TL0=(65536-10000)%256;//賦初值
  51.         TH0=(65536-10000)/256;//賦初值
  52.         j++;
  53.         if(j>=4) //變量j加一次 //如果j大于4
  54.         j=0;//j等于0
  55.
  56.            TR0=1;//重新啟動定時器0
  57. }
  58. void timer0_init (void)//定時器0中斷初始化函數(shù)
  59. {
  60.         EA=0;//關閉總中斷
  61.         TMOD=0x01;//確定定時器0的工作方式為1
  62.         TR0=0;//關閉定時器0
  63.         TL0=(65536-10000)%256;//賦初值
  64.         TH0=(65536-10000)/256;//賦初值
  65.         PT0=1;//
  66.         ET0=1;//打開定時器0的中斷開關
  67.         EA=1;//打開總中斷開關
  68.         TR0=1;//啟動定時器0
  69. }
  70. void main(void)//主程序
  71. {
  72.
  73.         uint i;//變量i
  74.         timer0_init ();//初始化定時器0 啟動定時器0
  75.
  76.         while(1)//循環(huán)函數(shù)
  77.         {
  78.             P0=0xff;
  79.                 i=ad_549();//把ad_549讀到的數(shù)賦給i
  80.                 chuli(i);//顯示最終結果(啟動ad_549轉換)
  81.
  82.                 switch(j)
  83.                 {
  84.                         case 0: P0 = tb[ge]; break;
  85.                         case 1: P0 = tb[shi]; break;
  86.                         case 2: P0 = tb[bai];break;
  87.                         case 3: P0 = tb[qian]&0x7f; break;
  88.             default: break;
  89.                 }
  90.
  91.                 P2 = seg_bit_scan[j];      //與j對應,P2輸出數(shù)碼管的位選信號
  92.                  delay(8);
  93.                 }
  94.         }
  95.
仿真程序下載: A_D轉換器應用-已測可用.zip (334.45 KB, 下載次數(shù): 15)
