C++演講比賽程序
jackzhu123
2023-7-23 16:38
C++演講比賽程序
#include<iostream>
using namespace std;
#include<vector>;
#include<map>
#include<string>
#include<algorithm>
#include<ctime>
#include<functional>
#include<deque>
#include<numeric>
#include<fstream>
#include<ctime>
void showMenu()
cout << "**********************************" << endl;
cout << "******* 歡迎參加演講比賽 *******" << endl;
cout << "******* 1.開始演講比賽 *******" << endl;
cout << "******* 2.查看往屆記錄 *******" << endl;
cout << "******* 3.清空比賽記錄 *******" << endl;
cout << "******* 0.退出比賽記錄 *******" << endl;
class Player
public:
Player()
Player(string name, double score)
this->name = name;
this->score = score;
string name;
double score;
void print(int a)
cout << a << " ";
class Jiang
public:
bool operator()(double dou1, double dou2)const
return dou1 > dou2;
class SpeechContest
public:
map<int, string>players;
vector<int>draw;
bool is_empty=true;
map<int, vector<string>>his_rec;
//創建比賽選手容器
void creatPlayers()
string st = "ABCDEFJHIJKL";
int number = 10001;
for (int i = 0; i < 12; i++)
string name = "選手";
name += st[i];
players.insert(make_pair(number + i, name));
draw.push_back(number + i);
//進行抽簽
void drawLots()
random_shuffle(draw.begin(), draw.end());
//打印抽簽后的演講順序
void print_DrawLots()
cout << "抽簽后演講順序如下:" << endl;
for_each(draw.begin(), draw.end(), print);
cout << endl;
system("pause");
void print_group(multimap<double, int, Jiang>&group1)
for (multimap<double, int>::iterator it = group1.begin(); it != group1.end(); it++)
cout << it->second << " " << it->first << " " << players.find(it->second)->second << endl;
void delete_End(multimap<double, int, Jiang>& group1)
int i = 0;
do
multimap<double, int>::iterator it = group1.end();
--it;
group1.erase(it);
i++;
}while (i < 3);
void add_Final_Player(multimap<double, int, Jiang>& group1)
draw.push_back(it->second);
void competition(multimap<double, int, Jiang>&group1,int a)
deque<double>de;
double score;
for (int i = a; i < 6+a; i++)
de.clear();
for(int j=0;j<10;j++)
score = rand() % 21 + 79 + rand() % 100 / 100.00;
de.push_back(score);
sort(de.begin(),de.end());
de.pop_back();
de.pop_front();
score=accumulate(de.begin(), de.end(),0)/8.00;
group1.insert(make_pair(score, draw[i]));
void first_Round()
multimap<double, int, Jiang>group1;
multimap<double, int, Jiang>group2;
drawLots();
print_DrawLots();
competition(group1,0);
cout << "第1小組比賽名次:" << endl;
print_group(group1);
competition(group2,6);
cout << "第2小組比賽名次:" << endl;
print_group(group2);
delete_End(group1);
delete_End(group2);
cout << "晉級人員:" << endl;
draw.clear();
add_Final_Player(group1);
add_Final_Player(group2);
cout << "第一輪比賽完畢" << endl;
void read()
ifstream ifs;
ifs.open("speech_result.csv", ios::in);
if (!ifs.is_open())
cout << "該文件不存在" << endl;
is_empty = true;
ifs.close();
return;
char ch;
ifs >> ch;
if (ifs.eof())
cout << "記錄為空" << endl;
is_empty = true;
ifs.close();
return;
is_empty = false;
ifs.putback(ch);
vector<string>ve;
string date;
int index = 1;
while (ifs>>date)
ve.clear();
int start = 0;
int pos = -1;
while (true)
pos = date.find(',', start);
if (pos==-1)
break;
string st = date.substr(start, pos - start);
ve.push_back(st);
start = pos + 1;
his_rec.insert(make_pair(index, ve));
index++;
void store(multimap<double, int, Jiang>&group)
ofstream ofs;
ofs.open("speech_result.csv",ios::out|ios::app);
for(multimap<double, int, Jiang>::iterator it=group.begin();it!=group.end();it++)
ofs << it->second << "," << it->first << ",";
ofs << endl;
ofs.close();
cout << "記錄已保存" << endl;
is_empty = false;
void second_Round()
multimap<double, int, Jiang>group;
cout << "第二輪比賽開始" << endl;
drawLots();
print_DrawLots();
competition(group, 0);
cout << "決賽名次:" << endl;
print_group(group);
delete_End(group);
cout << "冠亞季軍:" << endl;
print_group(group);
store(group);
void del_rec()
fstream fs;
fs.open("speech_result.csv", ios::out);
fs.clear();
is_empty = true;
cout << "記錄已清空" << endl;
void contest(SpeechContest &con)
con.creatPlayers();
con.first_Round();
con.second_Round();
void showTop(string st)
cout << st << "\t";
void showHis(const pair<int,vector<string>>&pa)
cout << "第" << pa.first << "屆:";
for_each(pa.second.begin(), pa.second.end(), showTop);
cout << endl;
void hisRec(SpeechContest &con)
con.read();
if (con.is_empty)
return;
for_each(con.his_rec.begin(), con.his_rec.end(),showHis);
int main()
srand((unsigned int)time(NULL));
SpeechContest con;
while (true)
showMenu();
cout << "請輸入您的選擇:" << endl;
int sel;
cin >> sel;
switch (sel)
case 1:
contest(con);
system("pause");
system("cls");
break;
case 2:
hisRec(con);
system("pause");
system("cls");
break;
case 3:
con.del_rec();
system("pause");
system("cls");
break;
case 0:
cout << "歡迎下次使用" << endl;
system("pause");
return 0;
break;
default:
cout << "您輸入有誤!" << endl;
system("pause");
system("cls");
system("pause");
return 0;
