標題: 為什么單片機T0的中斷無法執(zhí)行,只可執(zhí)行T1的中斷 [打印本頁]
作者: syh112    時間: 2023-6-13 03:19
#include "reg52.h"
#include<intrins.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit moto=P1^0;
sbit k2=P3^0;
sbit k3=P3^2;
//sbit k00=P2^2;
unsigned char timer1;
unsigned char timer0;
uint n=1;
uint m=2;
uint sunumber;
uint worksign;
void TimeConfig();
void delay1ms(uint t);
void sudu();
void moshi();
void ziran();
void main(void)
        TimeConfig();
                moshi();
void delay1ms(uint t){
        char i;
        while(t--)
                 for(i=0;i<50;i++);
void TimeConfig()
        TMOD|= 0x11;
        TH1 = 0xFE;
        TL1 = 0x0C;
        ET1 = 1;
        EA = 1;
        TR1 = 1;
  TH0=0xD8;//(65536-10000)/256;
        TL0=0xF0;//(65536-10000)%256;//10ms
        ET0=1;
        TR0=1;
void Time1(void) interrupt 3
        TR0=0;
        TH1 = 0xFE;
        TL1 = 0x0C;
        TR0=1;
        timer1++;
void Time0(void) interrupt 1
        TR1=0;
        TH0=0xD8;
        TL0=0xF0;
        TR1=1;
        timer0++;
        if(timer0>1200)
                timer0=0;
void sudu()
         if(k2==0)
                 delay1ms(10);
                 if(k2==0)
                        n+=1;
                        if(n>3)
                        {n=1;
                  while(!k2);
                switch(n)
                        case 1:sunumber=15;break;
                        case 2:sunumber=50;break;
                        case 3:sunumber=90;break;
                if(timer1>100)
                        timer1=0;
                if(timer1<sunumber)
                        moto=1;
                        moto=0;
void moshi()
        if(k3==0)
         delay1ms(10);
         if(k3==0)
                  m+=1;
                        if(m>2)
                        {m=1;
                  while(!k3);
                switch(m)
                        case 1:sudu();break;
                        case 2:ziran();break;
//                        case 3:sunumber=90;break;
void ziran()
          ET0=1;
                TR0=1;
                if(timer0<400)
                        sudu();
                        moto=0;
作者: wys91203    時間: 2023-6-13 05:35
兩個定時器都用方式1,16位,自然優(yōu)先級是T0高于T1, 但在中斷程序中,有錯誤,T0中斷 INTERRUPT1
  子程序里,停止了T0空斷.
        TR0=0;   //應(yīng)是TR1=0
        TH1 = 0xFE;
        TL1 = 0x0C;
        TR0=1;
        timer1++;
作者: xuyaqi    時間: 2023-6-13 09:33
你定義:unsigned char timer0;
判斷要求,if(timer0>1200),后邊程序不能執(zhí)行。
