請教關(guān)于對單片機pin腳二進(jìn)制賦值的問題
muse122334
2023-2-15 21:35
首先感謝各位大佬進(jìn)來指導(dǎo)
本人愚鈍想使用STM32F10x單片機通過按鍵控制ADG732并完成對應(yīng)開關(guān)選擇,將采集到的ADC通過串口發(fā)送到PC。
但是在操作過程中,A0-A4口一直處于低電平,不管怎么按鍵都沒有作用,想請問大家是因為我的宏定義沖突嗎亦或者其他問題,該如何修改?
另外編譯是沒有錯誤的,電路圖如圖所示
為了方便大家編譯,將部分void添加主程序
(134.48 KB, 下載次數(shù): 47)
2023-2-15 21:34 上傳
#include <stm32f10x.h>
#include <stdint.h>
#include <stdio.h>
#include <delay.h>
#include <ADC.h>
#include <Usart.h>
#include <delay.h>
void USART_Config(void);
void GPIO_Config(void);
void ADC_Config(void);
void Switch_Pin(uint8_t pin_number, uint8_t state);
uint16_t Read_Voltage(void);
void Send_Voltage(uint16_t voltage);
#define A0 PBout(3)
#define A1 PBout(4)
#define A2 PBout(5)
#define A3 PBout(6)
#define A4 PBout(7)
#define ADC PAout(0)
uint8_t word = 0;
int main(void)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB, ENABLE); // 使能GPIOA和GPIOB時鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
delay_init();
USART_Config();
ADC_Config();
uint16_t voltage;
if(GPIO_ReadInputDataBit(GPIOA, GPIO_Pin_2) == Bit_RESET)
// 將二進(jìn)制數(shù)加1,如果達(dá)到11111則重置為00000
if (word >= 32)
word = 0;
A4 = (word >> 4) & 0x01;
A3 = (word >> 3) & 0x01;
A2 = (word >> 2) & 0x01;
A1 = (word >> 1) & 0x01;
A0 = (word >> 0) & 0x01;
delay_ms(10);
word++;
voltage = Read_Voltage();
Send_Voltage(voltage);
//初始化串口通信
// 定義串口外設(shè)結(jié)構(gòu)體變量
USART_InitTypeDef USART_InitStructure;
// 定義GPIO外設(shè)結(jié)構(gòu)體變量
// 使能USART外設(shè)的時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
// 使能GPIO外設(shè)的時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
// 配置GPIO外設(shè)(TX)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
// 配置GPIO外設(shè)(RX)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
// 配置USART外設(shè)
USART_InitStructure.USART_BaudRate = 115200;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
// 使能USART外設(shè)
USART_Cmd(USART1, ENABLE);
//使用GPIOB的引腳作為ADG732的控制端
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); // 使能GPIOB時鐘
GPIO_ResetBits(GPIOB,GPIO_Pin_3); //PB.10 輸出低
GPIO_ResetBits(GPIOB,GPIO_Pin_4);
GPIO_ResetBits(GPIOB,GPIO_Pin_5);
GPIO_ResetBits(GPIOB,GPIO_Pin_6); //PB.10 輸出低
GPIO_ResetBits(GPIOB,GPIO_Pin_7);
delay_init();
ADC_InitTypeDef ADC_InitStructure;
//使能ADC和GPIO相關(guān)的時鐘
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
//配置ADC的工作模式
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel = 1;
ADC_Init(ADC1, &ADC_InitStructure);
//配置ADC的通道
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5);
//使能ADC
ADC_Cmd(ADC1, ENABLE);
//配置ADC的輸入GPIO
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
//復(fù)位ADC校準(zhǔn)寄存器
ADC_ResetCalibration(ADC1);
//等待校準(zhǔn)寄存器復(fù)位完成
while(ADC_GetResetCalibrationStatus(ADC1));
//開始校準(zhǔn)ADC
ADC_StartCalibration(ADC1);
//等待校準(zhǔn)完
//首先,需要對選擇的引腳進(jìn)行初始化,以便進(jìn)行輸出
//將引腳狀態(tài)設(shè)置為指定的狀態(tài)(0或1)
if(state == 0)
GPIO_ResetBits(GPIOA, GPIO_Pin_2);
GPIO_SetBits(GPIOA, GPIO_Pin_2);
// 讀取電壓值函數(shù)
// 啟動ADC轉(zhuǎn)換
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
// 等待轉(zhuǎn)換完成
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));
// 讀取轉(zhuǎn)換結(jié)果
uint16_t adc_value = ADC_GetConversionValue(ADC1);
// 計算電壓值
float voltage = (float)adc_value / 4096 * 3.3;
uint16_t voltage_mv = (uint16_t)(voltage * 1000);
return voltage_mv;
char buffer[16];
sprintf(buffer, "%d\r\n", voltage);
for(int i = 0; buffer[i] != '\0'; i++)
USART_SendData(USART1, buffer[i]);
while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
