標(biāo)題: STC8A單片機(jī)輸出任意路(8路以內(nèi))同頻率同占空比不同相位的pwm波怎么實(shí)現(xiàn)啊? [打印本頁(yè)]
作者: yjx156    時(shí)間: 2022-10-26 22:11
用定時(shí)器1查詢延時(shí)和中斷延時(shí)都試過了,示波器上顯示的都是相位一樣的PWM波。求大神指點(diǎn)。PWM波是直接用STC8A帶的pwm寄存器生成的。代碼如下:
作者: hhh402    時(shí)間: 2022-10-27 09:56
STC8A增強(qiáng)型PWM可以自由設(shè)定高低電平位置。頻率必須相同,占空比和相位隨便調(diào)。
范例:
#include "reg51.h"
#include "intrins.h"
//測(cè)試工作頻率為11.0592MHz
sfr     P_SW2       =   0xba;
sfr     PWMCFG      =   0xf1;
sfr     PWMIF       =   0xf6;
sfr     PWMFDCR     =   0xf7;
sfr     PWMCR       =   0xfe;
#define PWMC            (*(unsigned int volatile xdata *)0xfff0)
#define PWMCKS          (*(unsigned char volatile xdata *)0xfff2)
#define TADCP           (*(unsigned int volatile xdata *)0xfff3)
#define PWM0T1          (*(unsigned int volatile xdata *)0xff00)
#define PWM0T2          (*(unsigned int volatile xdata *)0xff02)
#define PWM0CR          (*(unsigned char volatile xdata *)0xff04)
#define PWM0HLD         (*(unsigned char volatile xdata *)0xff05)
#define PWM1T1          (*(unsigned int volatile xdata *)0xff10)
#define PWM1T2          (*(unsigned int volatile xdata *)0xff12)
#define PWM1CR          (*(unsigned char volatile xdata *)0xff14)
#define PWM1HLD         (*(unsigned char volatile xdata *)0xff15)
#define PWM2T1          (*(unsigned int volatile xdata *)0xff20)
#define PWM2T2          (*(unsigned int volatile xdata *)0xff22)
#define PWM2CR          (*(unsigned char volatile xdata *)0xff24)
#define PWM2HLD         (*(unsigned char volatile xdata *)0xff25)
#define PWM3T1          (*(unsigned int volatile xdata *)0xff30)
#define PWM3T2          (*(unsigned int volatile xdata *)0xff32)
#define PWM3CR          (*(unsigned char volatile xdata *)0xff34)
#define PWM3HLD         (*(unsigned char volatile xdata *)0xff35)
#define PWM4T1          (*(unsigned int volatile xdata *)0xff40)
#define PWM4T2          (*(unsigned int volatile xdata *)0xff42)
#define PWM4CR          (*(unsigned char volatile xdata *)0xff44)
#define PWM4HLD         (*(unsigned char volatile xdata *)0xff45)
#define PWM5T1          (*(unsigned int volatile xdata *)0xff50)
#define PWM5T2          (*(unsigned int volatile xdata *)0xff52)
#define PWM5CR          (*(unsigned char volatile xdata *)0xff54)
#define PWM5HLD         (*(unsigned char volatile xdata *)0xff55)
#define PWM6T1          (*(unsigned int volatile xdata *)0xff60)
#define PWM6T2          (*(unsigned int volatile xdata *)0xff62)
#define PWM6CR          (*(unsigned char volatile xdata *)0xff64)
#define PWM6HLD         (*(unsigned char volatile xdata *)0xff65)
#define PWM7T1          (*(unsigned int volatile xdata *)0xff70)
#define PWM7T2          (*(unsigned int volatile xdata *)0xff72)
#define PWM7CR          (*(unsigned char volatile xdata *)0xff74)
#define PWM7HLD         (*(unsigned char volatile xdata *)0xff75)
    P_SW2 = 0x80;
    PWMCKS = 0x00;                              // PWM時(shí)鐘為系統(tǒng)時(shí)鐘
    PWMC = 0x0800;                              //設(shè)置PWM周期為0800H個(gè)PWM時(shí)鐘
    PWM0T1= 0x0100;                             //PWM0在計(jì)數(shù)值為100H地方輸出低電平
    PWM0T2= 0x0700;                             //PWM0在計(jì)數(shù)值為700H地方輸出高電平
    PWM1T2= 0x0080;                             //PWM1在計(jì)數(shù)值為0080H地方輸出高電平
    PWM1T1= 0x0780;                             //PWM1在計(jì)數(shù)值為0780H地方輸出低電平
    PWM0CR= 0x80;                               //使能PWM0輸出
    PWM1CR= 0x80;                               //使能PWM1輸出
    P_SW2 = 0x00;
    PWMCR = 0x80;                               //啟動(dòng)PWM模塊
    while (1);
說明:PWM0,PWM1高低電平的位置是可以設(shè)置的,也就是相位,占空比可以隨意,但是頻率必須一樣。
