基于8086的16X16點(diǎn)陣顯示程序Proteus仿真圖
liwujun
2022-6-30 22:17
本項目是基于8086的點(diǎn)陣顯示,可以通過按鍵顯示所要顯示的內(nèi)容
(38.48 KB, 下載次數(shù): 29)
2022-6-30 22:14 上傳
單片機(jī)源程序如下:
IOY0 EQU 0C400H ;片選第一片8255的地址
IOY1 EQU 0C440H ;片選第二片8255的地址
O8255_A EQU IOY0+00*2 ;第一片8255的地址的A口
O8255_B EQU IOY0+01*2 ;第一片8255的地址的B口
O8255_C EQU IOY0+10*2 ;第一片8255的地址的C口
O8255_MODE EQU IOY0+11*2 ;第一片8255的地址的控制字寄存器
T8255_A EQU IOY1+00*2 ;第二片8255的地址的A口
T8255_B EQU IOY1+01*2 ;第二片8255的地址的B口
T8255_C EQU IOY1+10*2 ;第二片8255的地址的C口
T8255_MODE EQU IOY1+11*2 ;第二片8255的地址的控制字寄存器
DATAS SEGMENT
;此處輸入數(shù)據(jù)段代碼
COUNT1 DB 00H
COUNT2 DB 01H
TAB DB 08H,02H,18H,02H,0C8H,3FH,14H,02H,32H,02H,11H,02H,0E8H,7FH,08H,08H
DB 0CH,08H,0EAH,7FH,08H,08H,88H,08H,88H,08H,08H,08H,08H,0AH,08H,04H ;待
DB 08H,00H,08H,1FH,08H,11H,7FH,11H,08H,11H,08H,11H,1CH,11H,2CH,11H
DB 2AH,11H,0AH,11H,89H,10H,88H,50H,48H,50H,48H,50H,28H,60H,08H,00H ;機(jī)
DB 00H,01H,00H,01H,3FH,01H,0A0H,7FH,0A1H,20H,52H,12H,14H,02H,08H,02H
DB 18H,02H,18H,06H,24H,05H,24H,09H,82H,18H,61H,70H,1CH,20H,00H,00H ;歡
DB 02H,00H,84H,01H,6CH,3EH,24H,22H,20H,22H,20H,22H,27H,22H,24H,22H
DB 0A4H,22H,64H,2AH,24H,12H,04H,02H,04H,02H,0AH,00H,0F1H,7FH,00H,00H ;迎
DB 80H,08H,82H,08H,84H,08H,0ECH,3FH,84H,08H,80H,08H,80H,08H,0EFH,7FH
DB 88H,08H,88H,08H,48H,08H,48H,08H,28H,08H,14H,00H,0E2H,7FH,00H,00H ;進(jìn)
DB 30H,00H,60H,00H,40H,00H,80H,00H,0C0H,00H,40H,01H,40H,01H,20H,02H
DB 20H,04H,10H,04H,10H,08H,08H,10H,04H,70H,02H,20H,01H,00H,00H,00H ;入
DB 00H,3EH,0FCH,01H,40H,04H,20H,04H,10H,02H,0F8H,01H,0C0H,04H,30H,08H
DB 0FCH,1FH,08H,31H,20H,05H,10H,09H,08H,11H,04H,21H,42H,21H,80H,00H ;系
DB 08H,02H,08H,04H,0C4H,7FH,04H,02H,22H,02H,1FH,11H,90H,20H,0C8H,7FH
DB 04H,29H,3EH,09H,00H,09H,00H,09H,0B8H,48H,87H,48H,40H,70H,20H,00H ;統(tǒng)
DB 00H,00H,00H,00H,00H,00H,00H,00H,08H,00H,08H,00H,08H,00H,08H,00H
DB 08H,00H,08H,00H,08H,00H,08H,00H,08H,00H,00H,00H,08H,00H,00H,00H ;!
DB 0FEH,3FH,80H,00H,80H,00H,0F8H,0FH,88H,08H,88H,08H,0F8H,0FH,88H,08H
DB 88H,08H,88H,08H,0FFH,7FH,08H,08H,08H,08H,08H,08H,08H,0AH,08H,04H ;再
DB 0F8H,0FH,08H,08H,08H,08H,88H,08H,88H,08H,88H,08H,88H,08H,88H,08H
DB 48H,09H,40H,01H,20H,01H,20H,21H,10H,21H,0CH,61H,03H,3EH,00H,00H ;見
DATAS ENDS
STACKS SEGMENT
;此處輸入堆棧段代碼
N1 DB 100 DUP(?)
STACKS ENDS
CODES SEGMENT
ASSUME CS:CODES,DS:DATAS,SS:STACKS
START:
MOV AX,DATAS
MOV DS,AX
MOV DX,O8255_MODE
MOV AL,81H
OUT DX,AL ;第一片8255方式選擇
MOV DX,T8255_MODE
MOV AL,80H
OUT DX,AL ;第二片8255方式選擇
MOV CX,0
CALL C1
X: CALL C2
MOV SI,0000H ;指針賦值0
MOV AH,2 ;顯示“待機(jī)”
JMP X0
Y: CALL C2
MOV AH,7 ;顯示“歡迎進(jìn)入系統(tǒng)”
MOV SI,0040H
MOV DI,SI
JMP X0
Z: CALL C2
MOV AH,2 ;顯示“再見”
MOV SI,0120H
MOV DI,SI
X0: PUSH CX
MOV BX,1024 ;整體循環(huán)1024次
X1: PUSH BX
MOV BH,COUNT1 ;初始化
MOV BL,COUNT2
CLC ;CF位清零
RER: MOV CX,16 ;循環(huán)次數(shù)
MOV SI,DI ;指向原來的位置
LOOP1:
MOV DX,T8255_A ;清除列
MOV AL,00H
OUT DX,AL
MOV DX,T8255_B
MOV AL,00H
OUT DX,AL
CALL FI
INC SI ;指針再次加1
RCL BL,1 ;每次循環(huán)向左移動1位
RCL BH,1 ;連帶CF位一同左移1位
DEC CX ;循環(huán)次數(shù)減1
CMP CX,0 ;循環(huán)次數(shù)大于0,就繼續(xù)循環(huán)
JNZ LOOP1
POP BX ;第二重循環(huán)計數(shù)
DEC BX
CMP BX,0
JNZ X1
LOOP3:
POP CX ;第三重循環(huán),控制顯示哪些字
INC CX
MOV DI,SI
CMP CL,AH
JNZ X0 ;顯示程序結(jié)束
MOV DI,0000H
MOV AH,0
MOV CX,0
CALL C1
MOV AH,4CH
INT 21H
C1: MOV DX,O8255_C ;讀取C口狀態(tài)
IN AL,DX
CMP AL,0EH ;判斷按下的是第幾個按鍵,依次跳轉(zhuǎn)
JZ X
CMP AL,0DH
JZ Y
CMP AL,0BH
JZ Z
O: MOV DX,O8255_C ;初始化鍵盤掃描輸入
PUSH AX
MOV AL,0FH
OUT DX,AL
POP AX
JMP C1
RET
C2: MOV DX,O8255_C ;對數(shù)碼管的輸出
PUSH AX
CALL C3
OUT DX,AL
POP AX
RET
C3: CMP AL,0EH ;數(shù)碼管輸出變量
JZ M1
CMP AL,0DH
JZ M2
CMP AL,0BH
JZ M3
M1: MOV AL,17H
RET
M2: MOV AL,27H
RET
M3: MOV AL,37H
RET
FI: MOV DX,O8255_A ;循環(huán)行掃描
MOV AL,BL
OUT DX,AL
MOV DX,O8255_B
MOV AL,BH
OUT DX,AL
LOOP2:
MOV DX,T8255_A ;循環(huán)列掃描
MOV AL,TAB[SI]
OUT DX,AL
INC SI ;指針加1,指向下一個數(shù)據(jù)
MOV DX,T8255_B
MOV AL,TAB[SI]
OUT DX,AL
RET
CODES ENDS
END START
以上是代碼
附件只包含1個文件 Proteus仿真文件下載:
基于8086點(diǎn)陣.zip
(109.44 KB, 下載次數(shù): 42)
2022-6-30 22:12 上傳
點(diǎn)擊文件名下載附件
8086點(diǎn)陣
