標(biāo)題: 接上一個(gè)貼,ESP8266連接中移動(dòng)ONENET MQTT服務(wù)器 源程序 [打印本頁]
作者: chendeaaa    時(shí)間: 2022-6-6 14:01
注意仿真里面用的是at89c51單片機(jī)
接上一個(gè)貼,連接ONENET  MQTT服務(wù)器
unsigned char code CIPSTART[]="AT+CIPSTART=\"TCP\",\"x.x.x.39\",6002\r\n";
unsigned char code CIPMODE[]="AT+CIPMODE=1\r\n";
unsigned char code CIPSEND[]="AT+CIPSEND\r\n";//先連接上服務(wù)器
unsigned int  code  mqdata[]={0x32,0x0D,0x00,0x06,0x54,
0x6F,0x70,0x69,0x63,0x32,0x00,0x01,0x31,0x32,0x33};        //發(fā)送數(shù)據(jù)Topic2 123
unsigned int code mqtt[]={0x10,0x27,0x00,0x04,0x4D,0x51,0x54,0x54,0x04,0xC0,0x00,0x78,
0x00,0x09,0x39,0x35,0x34,0x30,0x32,0x35,0x39,0x36,0x30,0x00,0x06,
0x35,0x32,0x34,0x34,0x38,0x35,0x00,0x08,0x31,0x31,0x31,0x31,0x31,0x31,0x31,0x31}; //連接自己創(chuàng)建的設(shè)備后設(shè)備會(huì)顯示在線,這里的代碼可以自己去復(fù)制。(這是我的設(shè)備,不要去連,改成自己的)
1.
if(res=='O'&&CP==1){
    CP=0;
        sengstring(CWSTOPSMART);
         delay(500);
         sengstring(CIPMODE);
         delay(500);
        sengstring(CIPSEND);
         delay(500);
    memset(GOTIP,'\0',sizeof(GOTIP));
   for(i=0;i<41;i++){
            sengchar(mqtt[ i]);//這里發(fā)送連接服務(wù)器
                  delay(1);
           showchina_char(15,18,0,0);
        ET0=1;
        wififalg=1;
2.
void lcd1602T0() interrupt 1 /
     unsigned char  i;
     nu++;
         if(bis==0){ ET0=0;homepage();bis=1;}
         if(nu>=150){
           nu=0;
           nud++;
      DTH11_START();
      humi =((DTH11data[0]>>4)*16)+(DTH11data[0]&0x0f);
             temp =((DTH11data[2]>>4)*16)+(DTH11data[2]&0x0f);  //溫度
          si[2]=((humi/10));
          si[3]=((humi%10));
          si[0]=((temp/10));
          si[1]=((temp%10));
      humiture();
          if(nud>=5){
           ET0=0;
                nud=0;
           if(wififalg==1){
         // sbuftem[0]=((temp/10)+'0');
         // sbuftem[1]=((temp%10)+'0');
         // sengstring(sbuftem);
          for(i=0;i<15;i++){
            sengchar(mqdata[ i]);//這里定時(shí)發(fā)送消息到服務(wù)器,數(shù)據(jù)寫死的,可以自行更改
           ET0=1;
Keil5代碼下載: Keil代碼.7z (91.19 KB, 下載次數(shù): 16)
作者: chendeaaa    時(shí)間: 2022-6-9 19:18
這個(gè)仿真圖,正常開機(jī)是不會(huì)讀取溫度,要等WIFI連上了后,才開始啟動(dòng)定時(shí)器,讀取溫濕度
