標(biāo)題: java JSP數(shù)據(jù)庫核心技術(shù)實驗 [打印本頁]
作者: 19190572549    時間: 2022-5-29 11:55
實驗內(nèi)容:利用Statement演示SQL
實驗要求:
1.    =演示用戶登錄功能;
2.    用戶輸入用戶名,如tom;用戶輸入密碼,如123,成功登錄,顯示success!;否則登錄不成功,顯示error!
3.    演示SQL,用戶名輸入:jack ‘ or 1=1 -- ,密碼輸入:345,成功登錄,顯示success!
【貼代碼】
package com;
import java.sql.*;
import java.util.Scanner;
public class Jdbc {
    private final String URL="jdbc:mysql://localhost:3306/mon";
    private final String USER="root";
    private final String PWD="1234";
    public void login() {
        Connection con = null;
        Statement stmt = null;
        ResultSet rs = null;
        try {
            Class.forName("com.mysql.jdbc.Driver");
            con = DriverManager.getConnection(URL,USER,PWD);
            stmt=con.createStatement();
            Scanner input = new Scanner(System.in);
            System.out.println("input user:");
            String u=input.nextLine();
            System.out.println("input pwd:");
            String p=input.nextLine();
            String sql="select count(*) from login where user='"+u+"' and pwd='"+p+"'";
            rs=stmt.executeQuery(sql);
            int c=-1;
            if(rs.next()) {
                c=rs.getInt(1);
            if(c>0) {
                System.out.println("success!");
            } else {
                System.out.println("error!");
        } catch(Exception e) {
            e.printStackTrace();
        } finally {
            try {
                if(rs!=null) rs.close();
                if(stmt!=null) rs.close();
                if(con!=null) rs.close();
            } catch (SQLException e) {
    public static void main(String[] args) {
        // TODO Auto-generated method stub
        Jdbc b= new Jdbc();
        b.login();
