51單片機1602液晶顯示 有沒有大佬給一個程序 試了很多次都不對 求分享
liyang129
2022-5-15 14:14
有沒有大佬給一個程序 試了很多次 都不對
lkc8210
2022-5-16 10:35
試試這個
#include <reg51.h>
#include"intrins.h"
#define LCD_Dat P0
sbit lcd_rs = P2 ^ 0;
sbit lcd_rw = P2 ^ 1;
sbit lcd_e = P2 ^ 2;
void delay(unsigned int x)//t = 18.45 + x * 9.77 us @11.0592Mhz
while(x--);
void lcd_write_cmd(unsigned char cmd) //寫命令函數
lcd_rs = 0;
lcd_rw = 0;
LCD_Dat = cmd;
lcd_e = 1;
lcd_e = 0;
delay(3);//>40us
void lcd_write_date(unsigned char date) //寫數據函數
lcd_rs = 1;
lcd_rw = 0;
LCD_Dat = date;
lcd_e = 1;
lcd_e = 0;
delay(3);//>40us
void lcd_init() //LCD初始化函數
lcd_write_cmd(0x38);
lcd_write_cmd(0x0c);
lcd_write_cmd(0x06);
lcd_write_cmd(0x01);
delay(200);//>1.7ms
void lcd_show_char(unsigned char column, unsigned char dat)
if(column == 1)
lcd_write_cmd(0x80);
lcd_write_cmd(0xC0);
lcd_write_date(dat);
void lcd_show_str(unsigned char column, unsigned char *dat)
if(column == 1)
do
lcd_write_date(*dat);
} while(*dat++);
lcd_init();
lcd_show_str(1, "LCD1602 Demo");
lcd_show_str(2, "Hello World!");
hy47566398
2022-5-16 17:26
LCD1602.H
#ifndef __LCD1604__H
#define __LCD1604__H
#include "def.h"
//行控制碼1602&1604通用
#define LINE0 0x80
#define LINE1 0xC0
#define LINE2 0x90
#define LINE3 0xD0
#ifdef _USE_SHOP_A_
//P2口接LCD的D0~D7
#define LCD1602_DATA P2
//LCD的RS、RW、E腳
sbit LCD1602_RS = P0^4;
sbit LCD1602_E = P0^5;
sbit LCD1602_RW = P0^6;
//與LCD12864用同一P2口
//置PSB=1插上也能亮
sbit PSB = P0^7;
#endif
#ifdef _LY5A_L2A_
sbit BEEP = P1^5;
#define LED_PORT P2
//P2口接LCD的D0~D7
#define LCD1602_DATA P0
//LCD的RS、RW、E腳
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E = P1^2;
//與LCD12864用同一P2口
//置PSB=1插上也能亮
sbit PSB = P1^6;
#endif
//LCD初如化
void LcdInit();
//LCD清屏
void LcdClr();
//清某一行
void LcdClr0();
void LcdClr1();
//void LcdClr2();
//void LcdClr3();
* 在指定坐標顯示整型數字
* x,y : 橫縱屏幕坐標(列,行)
* num : 要顯示的整型數字
* nDispW: 要顯示的占位寬度(0~16個字符),0-基本的顯示,不設定(后兩位參就無意義了)
* bRightAlign : 0-左對齊,1-右對齊
* bLeftAdd0 : 右對齊時的數字前導空,左邊是否補0,0-不補0,1-補0
void LcdDisplayNum(u8 x, u8 y, const long num, u8 nDispW , bool bRightAlign, bool bLeftAdd0);
* 在指定(列,行)位置顯示字符串
void LcdDisplayStr(u8 x, u8 y, const char *msg);
#endif
LCD1604.c
// LCD1602&LCD1604字符顯示功能
// LCD1602_RW 不用功能電路不接入這個腳
#include <string.h>
#include <intrins.h>
#include "LCD1602.h"
void delay1Cycle(unsigned int cycle)
unsigned int i;
for(i=0; i<cycle; i++)
_nop_();
/*OK
bool LcdBusy()
bit b;
LCD1602_RS = 0;
LCD1602_RW = 1;
delay1Cycle(5);
LCD1602_E = 1;
delay1Cycle(5);
b = LCD1602_DATA & 0x80;
LCD1602_E = 0;
return b;
//LCD E口跳變時,LCD顯示一個字符/接收一個指令
//RS=0:命令指令,RS=1:顯示數據指令
void LcdWriteInfo( u8 RS, u8 RW, u8 dat )
//while(LcdBusy());
LCD1602_RS = RS;
LCD1602_E = 0;
LCD1602_RW = RW;
LCD1602_DATA = dat;
delay1Cycle(5);
LCD1602_E = 1;
delay1Cycle(5);
LCD1602_E = 0;
delay1Cycle(25);
//RS=0,指令寄存器
//RW=0,寫數據
void LcdWriteCom( u8 com )
LcdWriteInfo( 0, 0, com );
//RS=1,數據寄存器
void LcdWriteData(u8 dat)
LcdWriteInfo( 1, 0, dat );
//LCD初如化
void LcdInit()
//要等待開機啟穩
//否則顯示錯位不全
delay1Cycle(1000);
PSB = 1; //與開發板LCD12864同一數據口
//讓12864插上也能有字,但...
LcdWriteCom(0x38); //開顯示:0011 1000
LcdWriteCom(0x38); //剛開機,各方電位還不穩定
LcdWriteCom(0x38); //重要的事情說三便
LcdWriteCom(0x0c); //不顯示光標:0000 1100
LcdWriteCom(0x06); //光標右移:0000 0110
LcdWriteCom(0x01); //清屏
//別著急,抽根煙
delay1Cycle(1000);
//LCD清屏
/*OK
void LcdClr()
* 在指定位置顯示字符串
char *p1 = msg;
char *p2 = 0;
u8 xx, nlen=0;;
if( x>15 || y>3 ) return;
//取顯示字串長度
nlen = strlen(msg);
if(nlen==0) return;
if(nlen>32) nlen=32;
//p2-折行字串指針
//只顯示一個折行
if(nlen<=16-x)
p2 = 0; //字串只用顯示一行
p2 = p1 +16 - x; //字串長度過長有折行
//顯示列控制碼
if(y==0) LcdWriteCom(LINE0+x); //第一行顯示
if(y==1) LcdWriteCom(LINE1+x); //第二行
if(y==2) LcdWriteCom(LINE2+x); //第三行
if(y==3)
{ p2 = 0; LcdWriteCom(LINE3+x);} //第四行
for(xx = x; xx<16; xx++)
LcdWriteData( *p1 );
p1++;
if(*p1=='\0') break;
//有折行時
if(p2!=0)
if(y==0) LcdWriteCom(LINE1);
if(y==1) LcdWriteCom(LINE2);
if(y==2) LcdWriteCom(LINE3);
for(xx = 0; x<16; xx++)
LcdWriteData( *p2 );
p2++;
if(*p2=='\0') break;
* 在指定坐標顯示整型數字
* x,y : 橫縱屏幕坐標
* num : 顯示整型數字
* nDispW: 顯示占位寬度,當寬度小于顯示數字寬度時,此值無效
* bLeftAdd0 : 數字前導空左邊是否補0,0-不補0,1-補0
void LcdDisplayNum(u8 x, u8 y, const long num, u8 nDispW, bool bRightAlign, bool bLeftAdd0)
u8 w=0, i=0;
char num_str[17]={'*'};
char strBuff[17]={0x20};
long tmp = 0;
if(x>15 || y>3) return;
if(nDispW>16) nDispW=16;
//負數不支持左補0
if(num<0) bLeftAdd0 = 0;
tmp = num>0 ? num : num * (-1);
//取字長度,數字到臨時字符串中
w++;
strBuff[i] = tmp%10 + '0';
if(tmp<10) break;
tmp = tmp/10;
i++;
//負號(-)
if(num<0) {strBuff[i+1]='-';w++;}
if(nDispW<w) nDispW=0;
//寬度內填空格
if(nDispW>0)
for(i=0; i<nDispW; i++)
num_str[i] = 0x20;
//左補0的條件:給定寬度是否右對齊
if(bLeftAdd0==1 && nDispW>0 && bRightAlign==1 )
num_str[i] = '0';
if(nDispW>0)
if(bRightAlign)
memcpy(num_str, strBuff, w);
memcpy(num_str+nDispW-w, strBuff, w);
//應以最寬的值
w = (nDispW > w ? nDispW : w);
if(y==3) LcdWriteCom(LINE3+x);
for( i=w; i>0; i-- )
{//LCD顯示
LcdWriteData( num_str[i-1] );
*清行
OK
void LcdClrLine(u8 y)
u8 x;
if(y>3) return;
if(y==0) LcdWriteCom(LINE0); //第一行
if(y==1) LcdWriteCom(LINE1); //第二行
if(y==2) LcdWriteCom(LINE2); //第三行
if(y==3) LcdWriteCom(LINE3); //第四行
for(x = 0; x<16; x++)
LcdWriteData( 0x20 );
void LcdClr0()
LcdClrLine(0);
void LcdClr1()
LcdClrLine(1);
/*OK
void LcdClr2()
LcdClrLine(2);
void LcdClr3()
LcdClrLine(3);
def.h
#ifndef __DEF__H__
#define __DEF__H__
#include <reg52.h>
#ifndef u8
#define u8 unsigned char
#endif
#ifndef bool
#define bool bit
#define false 0
#define true 1
#endif
#ifndef u16
#define u16 unsigned int
#endif
#ifndef u32
#define u32 unsigned long
#endif
#ifndef NULL
#define NULL 0
#endif
#define ON 1
#define OFF 0
#define _ON 0
#define _OFF 1
//ShopAxxx開發板
#ifdef _USE_SHOP_A_
sbit BEEP = P1^2; //1 - off 蜂鳴器
sbit RELAY = P1^0; //1 - off 繼電器
sbit _LE = P1^5; //0 - off 74HC573(/LE),控制P2口的LED
#endif
#endif
