STC15F2K60S2單片機萬年歷代碼 DS1302、內部eeprom、DHT11、1.3寸OLED
guaizai
2022-4-5 19:19
(79.9 KB, 下載次數: 42)
2022-4-5 22:15 上傳
目前只實現了1、2、3、4和1、2、4
#include <STC15F2K60S2.H>
#include "oled.h"
#include "Delay.h"
#include <DHT.h>
#include "MatrixKey.h"
#include "Buzzer.h"
#include "UART.h"
#include "DS1302.H"
#include "Timer0.h"
#include "esp8266.h"
#include "eeprom.h"
sbit LED = P3^4;
#define IAP_ADDRESS 0X000
unsigned char tempH,MiniSec,tempL,humiH,humiL,KeyNum,MODE=0,Run=0,i,j,temp,TimeSetselect;
unsigned char Sec=0,Min=0,Hour=0;
unsigned char ReadTime[14];
unsigned char receive[4];
unsigned char code table[]="AT+CIPMUX=1\r\n";
unsigned char code table1[]="AT+CIPSERVER=1,8080\r\n";
char xdata clock1_hour=0,clock1_min=0;
//unsigned char xdata clock1[7]="00:00";
static unsigned int T0Count3;
void TimeShow(void);
void Stopwatch();
void TimeSet(void);
void Clock(void);
void ESP8266(void);
void Buzzer(void);
void esp_init();
void int_init();
void eeprom(void);
void EEPROM_Init(void);
void Judge_Clock(void);
void main(void)
DHT11_Rst();
OLED_Init(); //初始化OLED
OLED_Clear();
Buzzer();
UART_Init();
DS1302_Init();
Timer0Init();
EEPROM_Init();
// DS1302_SetTime();
// DS1302_WriteByte(0x80,0x07);//關閉1302寫保護
// EEPROM_Erase(0);
// LED=~LED;
// OLED_ShowString(0,0,"hello");
KeyNum=MatrixKey();
P42=0;
if(KeyNum==13)
P42=1;
Delay(100);
P42=0;
if(MODE==0){MODE=1;TimeSetselect=0;}
else if(MODE==1){MODE=0;OLED_Clear();DS1302_SetTime();}
if(KeyNum==14)
P42=1;
Delay(100);
P42=0;
if(MODE==0){MODE=2; OLED_Clear();}
else if(MODE==2){MODE=0; OLED_Clear(); }
if(KeyNum==15)
P42=1;
Delay(100);
P42=0;
if(MODE==0){MODE=3; OLED_Clear();}
else if(MODE==3){MODE=0; OLED_Clear(); Judge_Clock(); }
if(KeyNum==9)
P42=1;
Delay(100);
P42=0;
Run=~Run;
// Run=1;
if(KeyNum==10)
P42=1;
Delay(100);
P42=0;
Sec=0;
Min=0;
MiniSec=0;
if(KeyNum==7)
P42=1;
Delay(100);
P42=0;
if(MODE==0){MODE=4; OLED_Clear();}
else if(MODE==4){MODE=0; OLED_Clear(); }
if(KeyNum==8)
P42=1;
Delay(100);
P42=0;
if(MODE==0){MODE=5; OLED_Clear();}
else if(MODE==5){MODE=0; OLED_Clear(); }
switch(MODE)
case 0:TimeShow();break;
case 1:TimeSet();break;
case 2:Stopwatch();break;
case 3:Clock();break;
case 4:ESP8266();break;
case 5:eeprom();break;
void ESP8266(void)
// int_init(); //中斷初始化,定時器初始化
// esp_init(); //模塊初始化,發送那兩條指令
// if(receive[1]=='1'){ //收到1點亮LED
// P34 =0 ;
// else P34 =1;
DS1302_ReadTime2();
ReadTime[0]=(DS1302_Time[0]>>4); //分離出年十位
ReadTime[1]=(DS1302_Time[0]&0x0F); //分離出年個位
ReadTime[2]=(DS1302_Time[1]>>4); //分離出月十位
ReadTime[3]=(DS1302_Time[1]&0x0F); //分離出月個位
ReadTime[4]=(DS1302_Time[2]>>4); //分離出日十位
ReadTime[5]=(DS1302_Time[2]&0x0F); //分離出日個位
ReadTime[6]=(DS1302_Time[3]>>4); //分離出小時十位
ReadTime[7]=(DS1302_Time[3]&0x0F); //分離出小時個位
ReadTime[8]=(DS1302_Time[4]>>4); //分離出分鐘十位
ReadTime[9]=(DS1302_Time[4]&0x0F); //分離出分鐘個位
ReadTime[10]=(DS1302_Time[5]>>4); //分離出秒鐘十位
ReadTime[11]=(DS1302_Time[5]&0x0F); //分離出秒鐘個位
Delay(10);
EA=0;
UART_SendByte(ReadTime[0]+48);//年
UART_SendByte(ReadTime[1]+48);
UART_SendByte('-');
UART_SendByte(ReadTime[2]+48);//月
UART_SendByte(ReadTime[3]+48);
UART_SendByte('-');
UART_SendByte(ReadTime[4]+48);//日
UART_SendByte(ReadTime[5]+48);
UART_SendByte(' ');
UART_SendByte(ReadTime[6]+48);//時
UART_SendByte(ReadTime[7]+48);
UART_SendByte(':');
UART_SendByte(ReadTime[8]+48);//分
UART_SendByte(ReadTime[9]+48);
UART_SendByte(':');
UART_SendByte(ReadTime[10]+48);//秒
UART_SendByte(ReadTime[11]+48);
UART_SendByte('\n');
SBUF='\n';
while(!TI); //等待發送完畢
TI=0; //清中斷
EA=1;
Delay(1000);
void eeprom(void)
unsigned char i;
// EEPROM_Erase(0x000);
for(i=0;i<1;i++)
UART_SendByte(EERPOM_ReadByte(0x000));
void Clock(void)
// OLED_Clear();
// clock1_hour=EERPOM_ReadByte(0x000);
OLED_ShowString(0,0," Clock");
OLED_ShowString(47,2,":");
OLED_ShowNum(30,2,clock1_hour,2,16);
OLED_ShowNum(54,2,clock1_min,2,16);
if(KeyNum==1) {clock1_hour++;if(clock1_hour>=24) clock1_hour=0;}
if(KeyNum==2) {clock1_hour--;if(clock1_hour<0) clock1_hour=23;}
if(KeyNum==3) {clock1_min++;if(clock1_min>=60) clock1_min=0;}
if(KeyNum==4) {clock1_min--;if(clock1_min<0) clock1_min=59;}
// EEPROM_WriteByte(0x000,clock1_hour);
void TimeShow(void)
// Delay(1200);
DS1302_ReadTime();
OLED_ShowNum(0,0,DS1302_Time[0],2,16);
OLED_ShowString(17,0,"-");
OLED_ShowNum(24,0,DS1302_Time[1],2,16);
OLED_ShowString(41,0,"-");
OLED_ShowNum(48,0,DS1302_Time[2],2,16);
OLED_ShowNum(30,2,DS1302_Time[3],2,16);
OLED_ShowNum(54,2,DS1302_Time[4],2,16);
OLED_ShowString(71,2,":");
OLED_ShowNum(78,2,DS1302_Time[5],2,16);
OLED_ShowString(87,0,"DAY:");
OLED_ShowNum(120,0,DS1302_Time[6],1,16);
DHT11_Read_Data(&tempH,&tempL,&humiH,&humiL);
OLED_ShowString(75,6,"T:");
OLED_ShowNum(95,6,tempH,2,16);
// OLED_ShowNum(119,6,tempL,2,16);
OLED_ShowString(0,6,"H:");
OLED_ShowNum(20,6,humiH,2,16);
// OLED_ShowNum(44,6,humiL,2,16);
// OLED_ShowString(37,6,".");
OLED_ShowString(50,6,"%");
void TimeSet(void)
if(KeyNum==16)
P42=1;
Delay(100);
P42=0;
TimeSetselect++;
TimeSetselect%=6;
OLED_ShowNum(102,2,TimeSetselect,2,16);
if(KeyNum==5)
DS1302_Time[TimeSetselect]++;
if(DS1302_Time[0]>99){DS1302_Time[0]=0;}
if(DS1302_Time[1]>12){DS1302_Time[1]=1;}
if(DS1302_Time[1]==1||DS1302_Time[1]==3||DS1302_Time[1]==3||DS1302_Time[1]==5||DS1302_Time[1]==7||DS1302_Time[1]==8||DS1302_Time[1]==10||DS1302_Time[1]==12){if(DS1302_Time[2]>31)
if(DS1302_Time[2]<1){DS1302_Time[2]=31;}//大月
if(DS1302_Time[2]>31){DS1302_Time[2]=1;}}
else if(DS1302_Time[1]==4||DS1302_Time[1]==6||DS1302_Time[1]==9||DS1302_Time[1]==11)
if(DS1302_Time[2]<1){DS1302_Time[2]=30;}//小月
if(DS1302_Time[2]>30){DS1302_Time[2]=1;}
else if(DS1302_Time[1]==2)
if(DS1302_Time[0]%4==0)
if(DS1302_Time[2]<1){DS1302_Time[2]=29;}//閏年2月
if(DS1302_Time[2]>29){DS1302_Time[2]=1;}
if(DS1302_Time[2]<1){DS1302_Time[2]=28;}//平年2月
if(DS1302_Time[2]>28){DS1302_Time[2]=1;}
if(DS1302_Time[3]>23){DS1302_Time[3]=0;}
if(DS1302_Time[4]>59){DS1302_Time[4]=0;}
if(DS1302_Time[5]>59){DS1302_Time[5]=0;}
if(KeyNum==6)//按鍵3按下
DS1302_Time[TimeSetselect]--;//時間設置位數值減1
if(DS1302_Time[0]<0){DS1302_Time[0]=99;}//年越界判斷
if(DS1302_Time[1]<1){DS1302_Time[1]=12;}//月越界判斷
if( DS1302_Time[1]==1 || DS1302_Time[1]==3 || DS1302_Time[1]==5 || DS1302_Time[1]==7 ||
DS1302_Time[1]==8 || DS1302_Time[1]==10 || DS1302_Time[1]==12)//日越界判斷
else if(DS1302_Time[1]==4 || DS1302_Time[1]==6 || DS1302_Time[1]==9 || DS1302_Time[1]==11)
if(DS1302_Time[3]<0){DS1302_Time[3]=23;}//時越界判斷
if(DS1302_Time[4]<0){DS1302_Time[4]=59;}//分越界判斷
if(DS1302_Time[5]<0){DS1302_Time[5]=59;}//秒越界判斷
// OLED_Clear();
void Stopwatch()
// LED=~LED;
// KeyNum=MatrixKey();
// OLED_Clear();
OLED_ShowString(4,0," StopWatch");
OLED_ShowNum(30,2,MiniSec,2,16);
OLED_ShowNum(54,2,Sec,2,16);
OLED_ShowNum(78,2,Min,2,16);
// if(KeyNum==9)
// Buzzer_Time(100);
// Run=1;
// Delay(100);
// LED=~LED;
void Sec_Loop(void)
// if(Run)
MiniSec++;
if(MiniSec>=10)
MiniSec=0;
Sec++;
if(Sec>=60)
Sec=0;
Min++;
if(Min>=60)
Min=0;
void Buzzer(void)
P4M1=0X00;
P4M0=0x04;
// P42=1;
// Delay(100);
// P42=0;
if(EERPOM_ReadByte(0)==0xff)//可用一個校驗位來判斷是否進行擦寫
P34=~P34;
clock1_hour=EERPOM_ReadByte(0);
clock1_min =EERPOM_ReadByte(0x001);
EEPROM_Erase(0);
// EEPROM_Erase(0x400);
EEPROM_WriteByte(0x001,clock1_min);
void shortdelay(unsigned int n){ //短延時
unsigned int i,j;
for(i=n;i>0;i--){
for(j=110;j>0;j--){;}
void esp_init()
unsigned char a=0,b=0;
while(table[a]!='\0')
SBUF=table[a]; //寫入要發送的字符
while(!TI); //等待發送完成
TI=0; //發送
a++;
shortdelay(50); //延時函數
while(table1[b]!='\0')
SBUF=table1[b];
TI=0;
b++;
void int_init(){ //開啟定時器1,產生9600波特率
TMOD = 0x20; //定時器1工作在方式2八位自動重裝模式
…………限于本文篇幅 余下代碼請從51黑下載附件…………
(8.2 KB, 下載次數: 45)
2022-4-5 23:24 上傳
Keil代碼下載:
代碼.zip
(155.92 KB, 下載次數: 57)
2022-4-5 19:19 上傳
