標(biāo)題: 關(guān)于ESP32-c3 arduino燒錄進(jìn)程序之后,串口就一直打印以下內(nèi)容,不執(zhí)行程序? [打印本頁(yè)]
作者: 偽爺    時(shí)間: 2022-3-31 12:28
ESP-ROM:esp32c3-api1-20210207
Build:Feb  7 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x403d11b2
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd6100,len:0x1484
load:0x403ce000,len:0xb80
load:0x403d0000,len:0x2ba4
entry 0x403ce000
I (35) boot: ESP-IDF v4.4-dev-960-gcf457d412 2nd stage bootloader
I (35) boot: compile time 12:10:59
I (35) boot: chip revision: 3
I (35) boot_comm: chip revision: 3, min. bootloader chip revision: 0
I (41) qio_mode: Enabling default flash chip QIO
I (46) boot.esp32c3: SPI Speed      : 80MHz
I (50) boot.esp32c3: SPI Mode       : QIO
I (53) boot.esp32c3: SPI Flash Size : 2MB
I (57) boot: Enabling RNG early entropy source...
E (62) flash_parts: partition 3 invalid - offset 0x150000 size 0x140000 exceeds flash chip size 0x200000
E (71) boot: Failed to verify partition table
E (75) boot: load partition table error!
作者: munuc_w    時(shí)間: 2022-3-31 17:17
檢查代碼,這是某項(xiàng)條件沒(méi)有滿足要求,在輸出信息。
作者: 偽爺    時(shí)間: 2022-3-31 17:20
問(wèn)題已經(jīng)解決了,在燒錄時(shí)配置為 DIO 4M  就可以編譯通過(guò)也不打印這些消息了。
感謝回復(fù)
作者: 75324747    時(shí)間: 2022-7-7 08:53
偽爺 發(fā)表于 2022-3-31 17:20
感謝回復(fù)
大神,請(qǐng)受我一拜,解決了我的大問(wèn)題了
