標題: 想實現(xiàn)52單片機控制兩個超聲波測距然后數(shù)碼管顯示距離(2~9)不過數(shù)碼管只有一個亮 [打印本頁]
作者: 1888888    時間: 2022-3-14 20:00
#include <REGX52.H>
#include <intrins.h>
#include <stdio.h>
#define uint  unsigned int
sbit SH_CP1 = P0^1;
sbit DS = P0^0;
sbit ST_CP1 = P0^2;
int distL,distR;
unsigned char code table[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
sbit TrigL    = P2^4;                // 超聲波模塊的Trig管腳
sbit EchoL    = P2^5;                // 超聲波模塊的Echo管腳
sbit TrigR    = P2^6;                // 超聲波模塊的Trig管腳
sbit EchoR    = P2^7;                // 超聲波模塊的Echo管腳
//============MAIN===============================
void Delay(unsigned int xms)  //延時
        unsigned char i, j;
        while(xms--)
                i = 2;
                j = 199;
                do
                        while (--j);
                } while (--i);
void send_data_74hc595(uint data_74hc595)                    //傳送數(shù)據(jù)給74hc595
        uchar a;
        for(a = 0; a < 8; ++a)
                DS = (data_74hc595 << a) & 0x80;                    //從高位開始傳輸
                SH_CP1 = 0;
                _nop_();
                _nop_();
                SH_CP1 = 1;
void show_74hc595()                                         //數(shù)據(jù)顯示
        ST_CP1 = 0;
        _nop_();
        _nop_();
        ST_CP1 = 1;
void Nixie()
           switch(distR)
                         case 1:send_data_74hc595(table[1]);show_74hc595();break;
                         case 2:send_data_74hc595(table[2]);show_74hc595();break;
                         case 3:send_data_74hc595(table[3]);show_74hc595();break;
                         case 4:send_data_74hc595(table[4]);show_74hc595();break;
                         case 5:send_data_74hc595(table[5]);show_74hc595();break;
                         case 6:send_data_74hc595(table[6]);show_74hc595();break;
                         case 7:send_data_74hc595(table[7]);show_74hc595();break;
                         case 8:send_data_74hc595(table[8]);show_74hc595();break;
                         case 9:send_data_74hc595(table[9]);show_74hc595();break;
                  switch(distL)
//模塊程序
uint GetDistanceL(void)
        uint s;
  TH0 = 0;
        TL0 = 0;
  TrigL=1;                                         //800MS  啟動一次模塊
        Delay(0.001);
  TrigL=0;
  while(!EchoL);                //當RX為零時等待
         TR0=1;                            //開啟計數(shù)
  while(EchoL);                        //當RX為1計數(shù)并等待
         TR0=0;                                //關閉計數(shù)
  //timeL=TH0*256+TL0;
        // timeL *= 12/11.0592;
  //s=(timeL*1.7)/100;     //算出來是CM
        s=((TH0*256+TL0)*0.034)/2;
        return s;
uint GetDistanceR(void)
        uint s;
        TH0 = 0;
        TL0 = 0;
  TrigR=1;                                         //800MS  啟動一次模塊
         Delay(0.001);
  TrigR=0;
  while(!EchoR);                //當RX為零時等待
         TR0=1;                            //開啟計數(shù)
  while(EchoR);                        //當RX為1計數(shù)并等待
         TR0=0;                                //關閉計數(shù)
        return s;
                                TMOD = 0x02;
                                ET0=0;
                                EA =1;                                                // 選擇定時器0,并且確定是工作方式1(為了超聲波模塊測量距離計時用的)
        TrigL=0;        // 初始化觸發(fā)引腳為低電平
        TrigR=0;
        //===========Ultrasonic measurement===========
                //left
                 distL = GetDistanceL();
                //right
                 distR = GetDistanceR();
                        Nixie();
        }//end of while
}//end of main
