關于步進電機 這個單片機程序怎么實現正反轉的?
無形者
2022-3-14 16:35
switch(capstastus)
case 5: EPwm1Regs.AQCTLA.all=0x90;EPwm1Regs.AQCSFRC.all=0x8;//A+
EPwm2Regs.AQCTLB.all=0x90;EPwm2Regs.AQCSFRC.all=0x2;//B-
EPwm3Regs.AQCSFRC.all=0x0a;
break;
case 1:
EPwm2Regs.AQCSFRC.all=0x0a;
EPwm3Regs.AQCTLB.all=0x90;EPwm3Regs.AQCSFRC.all=0x2;//C-
break;
case 3: EPwm1Regs.AQCSFRC.all=0x0a;
EPwm2Regs.AQCTLA.all=0x90;EPwm2Regs.AQCSFRC.all=0x8;//B+
EPwm3Regs.AQCSFRC.all=0x2;EPwm3Regs.AQCTLB.all=0x90;//C-
break;
case 2: EPwm1Regs.AQCTLB.all=0x90;EPwm1Regs.AQCSFRC.all=0x2;//A-
break;
case 6: EPwm1Regs.AQCTLB.all=0x90;EPwm1Regs.AQCSFRC.all=0x2;//A-
EPwm3Regs.AQCTLA.all=0x90;EPwm3Regs.AQCSFRC.all=0x8;//C+
break;
case 4: EPwm1Regs.AQCSFRC.all=0x0a;
break;
switch(capstastus)//ir2136 的hin和lin是反向的
case 5: EPwm1Regs.AQCSFRC.all=0x2;EPwm1Regs.AQCTLB.all=0x90;EPwm2Regs.AQCTLA.all=0x90;EPwm2Regs.AQCSFRC.all=0x8;EPwm3Regs.AQCSFRC.all=0xA;break;//h1 rise
case 1: EPwm1Regs.AQCSFRC.all=0xA;EPwm2Regs.AQCTLB.all=0x90;EPwm2Regs.AQCSFRC.all=0x2;EPwm3Regs.AQCSFRC.all=0x8;EPwm3Regs.AQCTLA.all=0x90;//h3 fall
case 3: EPwm1Regs.AQCTLB.all=0x90;EPwm1Regs.AQCSFRC.all=0x2;EPwm2Regs.AQCSFRC.all=0x0a;EPwm3Regs.AQCTLA.all=0x90;EPwm3Regs.AQCSFRC.all=0x8;break;//h2 rise
case 2: EPwm1Regs.AQCSFRC.all=0x8;EPwm1Regs.AQCTLA.all=0x90;EPwm2Regs.AQCTLB.all=0x90;EPwm2Regs.AQCSFRC.all=0x2;EPwm3Regs.AQCSFRC.all=0xA;break;//h1 fall
case 6: EPwm1Regs.AQCTLA.all=0x90;EPwm1Regs.AQCSFRC.all=0x8;EPwm2Regs.AQCSFRC.all=0x0a;EPwm3Regs.AQCTLB.all=0x90;EPwm3Regs.AQCSFRC.all=0x2;break;//h3 rise
case 4: EPwm1Regs.AQCSFRC.all=0xA;EPwm2Regs.AQCTLA.all=0x90;EPwm2Regs.AQCSFRC.all=0x8;EPwm3Regs.AQCSFRC.all=0x2;EPwm3Regs.AQCTLB.all=0x90;break;//h2 fall
有哪位大佬能夠知道這個電機是怎么實現正反轉的,謝謝了
