標題: 單片機矩陣鍵盤C語言程序不運行 不用return,不寫成函數,在while大循環(huán)里可以 [打印本頁]
作者: dlbg654321    時間: 2022-1-2 10:38
#include<reg52.h>
sbit wela=P2^7;
sbit dula=P2^6;
uchar temp,num;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0};
void delay(uchar z);
uchar keyscan();
void display(uchar aa);
        num=17;
        dula=1;
        P0=0;
        dula=0;
        wela=1;
        P0=0xc0;
        wela=0;
                    display(keyscan());
        dula=1;
        P0=table[aa-1];
        dula=0;
uchar keyscan()
        P3=0xfe;
        temp=P3;
        temp=temp&0xf0;
        if(temp!=0xf0)
                delay(5);
                temp=P3;
            temp=temp&0xf0;
                while(temp!=0xf0)
                   temp=P3;
                   switch(temp)
                        case 0xee:num=1;
                                break;
                        case 0xde:num=2;
                                break;
                        case 0xbe:num=3;
                                break;
                        case 0x7e:num=4;
                                break;
                 while(temp!=0xf0);
                 temp=P3;
                 temp=temp&0xf0;
        return num;
void delay(uchar z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
代碼是先寫,后照范例改
范例.zip
599 Bytes, 下載次數: 2
作者: 人工置頂員    時間: 2022-1-2 20:45
頂一下
作者: wulin    時間: 2022-1-3 08:54
改成這樣
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. sbit wela=P2^7;
  5. sbit dula=P2^6;
  6. uchar temp,num;
  7. uchar code table[]={
  8. 0x3f,0x06,0x5b,0x4f,
  9. 0x66,0x6d,0x7d,0x07,
  10. 0x7f,0x6f,0x77,0x7c,
  11. 0x39,0x5e,0x79,0x71,0};
  12. void delay(uchar z);
  13. uchar keyscan();
  14. void display(uchar aa);
  15. void main()
  16. {
  17.         num=17;
  18.         wela=1;
  19.         P0=0xfe;
  20.         wela=0;
  21.         dula=1;
  22.         P0=0;
  23.         dula=0;
  24.         while(1)
  25.         {
  26.                 display(keyscan());
  27.         }
  28. }
  29. void display(uchar aa)
  30. {
  31.         dula=1;
  32.         P0=table[aa-1];
  33.         dula=0;
  34. }
  35. uchar keyscan()
  36. {
  37.         P3=0xf0;
  38.         if(P3!=0xf0)
  39.         {
  40.                 delay(5);
  41.                 if(P3!=0xf0)
  42.                 {
  43.                         temp=P3;
  44.                         P3=0x0f;
  45.                         P3|=temp;
  46.                         switch(P3)
  47.                         {
  48.                                 case 0xee: num= 1; break;
  49.                                 case 0xde: num= 2; break;
  50.                                 case 0xbe: num= 3; break;
  51.                                 case 0x7e: num= 4; break;
  52.                                 case 0xed: num= 5; break;
  53.                                 case 0xdd: num= 6; break;
  54.                                 case 0xbd: num= 7; break;
  55.                                 case 0x7d: num= 8; break;
  56.                                 case 0xeb: num= 9; break;
  57.                                 case 0xdb: num=10; break;
  58.                                 case 0xbb: num=11; break;
  59.                                 case 0x7b: num=12; break;
  60.                                 case 0xe7: num=13; break;
  61.                                 case 0xd7: num=14; break;
  62.                                 case 0xb7: num=15; break;
  63.                                 case 0x77: num=16; break;
  64.                         }
  65.                         P3=0x0f;
  66.                         while(P3!=0x0f);
  67.                 }
  68.         }
  69.         return num;
  70. }
  71. void delay(uchar z)
  72. {
  73.         uint x,y;
  74.         for(x=z;x>0;x--)
  75.                 for(y=110;y>0;y--);
  76. }
作者: dlbg654321    時間: 2022-1-3 13:14
wulin 發(fā)表于 2022-1-3 08:54
改成這樣
謝謝!
