幫我看看at89c51單片機(jī)電子琴,只能發(fā)出哆啦咪達(dá)四個(gè)音,剩下四個(gè)不發(fā)音
tangxilfy
時(shí)間:
2021-11-30 19:50
#include<AT89X52.h>
#define SPK P0_0 //定義方波輸出口
#define LED P1_1
#define shumaguan P0 //定義數(shù)碼管段碼輸出
unsigned int tone1,tone2;
/*****標(biāo)準(zhǔn)音符表*****/
//用于使定時(shí)器初值變化以產(chǎn)生相應(yīng)頻率的定時(shí)
unsigned char code yinfu[]={
0xfb,0xe9, //Do
0xfc,0x5c, //Re
0xfc,0xc1, //Mi
0xfc,0xef, //Fa
0xfd,0x45, //So
0xfd,0x92, //La
0xfd,0xd0, //Si
0xfd,0xee, //Do#
0xfa,0x14, //So低
0xfa,0xb9, //La低
0xfb,0x4d, //Si低
0x00,0x00 //音符之間的間隔,只要間隔時(shí)間小于65ms時(shí),
//喇叭不會(huì)發(fā)出聲音,用作拍子之間的短暫停頓
/*****軍港之夜音調(diào)表*****/
unsigned char code shengri_tone[]={9,3,3,1,2,3,2,3,3,10,9,1,2,1,3,5,5,3,6,5,3,
3,3,2,1,2,3,2,3,11,9,10,11,10,1,11,3,3,11,10,11,10,11,3,3,11,
11,10,11,10,2,10,1,11,10,9,10,9,3,5,5,3,6,5,6,5,3,5,3,1,3,3,3,5,
3,5,5,3,3,2,3,2,11,10,11,10,9,3,3,5,5,3,6,5,6,5,3,5,3,1,3,
3,5,3,5,5,3,3,3,2,3,2,11,10,11,10,9,1 //0代表不發(fā)聲,即停頓;數(shù)字即為音調(diào)
/*****軍港之夜節(jié)拍表*****/
unsigned char code shengri_beat[]={24,24,24,24,12,12,48,24,48,24,24,12,12,86,24,24,24,24,24,48,24,
48,12,12,24,12,12,86,48,24,24,12,12,48,24,24,24,24,24,12,12,72,24,24,24,24,
24,12,12,48,24,12,12,24,24,12,12,86,24,24,24,24,24,12,12,48,12,24,12,24,12,12,12,48,
24,24,24,24,24,12,12,48,24,12,12,24,24,86,24,24,24,24,24,12,12,48,12,24,12,24,24,
24,72,24,24,24,12,12,24,12,12,48,24,12,12,24,24,86 //節(jié)拍,即tone表各音調(diào)的延時(shí)
/*****自動(dòng)演示音調(diào)表*****/
unsigned char code yanshi_tone[]={ 1,0,2,0,3,0,4,0,5,0,6,0,7,0,8,0,
8,0,7,0,6,0,5,0,4,0,3,0,2,0,1,0
/*****自動(dòng)演示節(jié)拍表*****/
unsigned char code yanshi_beat[]={ 48,1,48,1,48,1,48,1,48,1,48,1,48,1,48,2,
/*****15ms延時(shí)子程序,用于節(jié)拍*****/
void delay(void)
unsigned char n=50;
while(n--)
unsigned char i;
for(i=0;i<125;i++);
/*****定時(shí)器0初始化*****/
void initTimer(void)
TMOD=0x01; //定時(shí)器0,工作方式1;定時(shí)器1,工作方式1
TH0=tone1;
TL0=tone2;
void timer0(void) interrupt 1
TH0=tone1;
TL0=tone2;
SPK=~SPK; //取反,以產(chǎn)生方波
/*****演奏子程序1*****/
void play1(void)
unsigned char m=0;
unsigned char s;
unsigned char a=1;
EA=0;
LED=0;
a=shengri_tone[m]; //取音符
s=shengri_beat[m]; //取節(jié)拍
tone1=yinfu[2*a-2];
tone2=yinfu[2*a-1];
EA=1;
while(s--)
delay();
LED=1;
m++;
if(m>=119) return; //數(shù)值是shengri相關(guān)表中的元素?cái)?shù)量
/*****演奏子程序2*****/
void play2(void)
unsigned char m=0;
unsigned char s;
unsigned char a=1;
EA=0;
LED=0;
a=yanshi_tone[m];
s=yanshi_beat[m];
tone1=yinfu[2*a-2];
tone2=yinfu[2*a-1];
EA=1;
while(s--)
delay();
LED=1;
m++;
if(m>=32) return;
/*****按鍵檢測*****/
void check_key(void)
P2=0xff;
P3=0xff; //設(shè)置為輸入狀態(tài)
switch(P2) //檢測按鍵,輸出數(shù)碼管、載入定時(shí)器初值、允許中斷
case 0xfe:shumaguan=0xF9;tone1=0xfb;tone2=0x90;EA=1;break;
case 0xfd:shumaguan=0xA4;tone1=0xfc;tone2=0xc;EA=1;break;
case 0xfb:shumaguan=0xB0;tone1=0xfc;tone2=0x7b;EA=1;break;
case 0xf7:shumaguan=0x99;tone1=0xfc;tone2=0xad;EA=1;break;
case 0xef:shumaguan=0x92;tone1=0xfd;tone2=0xa;EA=1;break;
case 0xdf:shumaguan=0x82;tone1=0xfd;tone2=0x5d;EA=1;break;
case 0xbf:shumaguan=0xF8;tone1=0xfd;tone2=0xa7;EA=1;break;
case 0x7f:play1();break;
default: EA=0;SPK=0;shumaguan=0xff;//如果沒有鍵按下則關(guān)閉中斷和數(shù)碼管
switch(P3)
case 0xfe:shumaguan=0x79;tone1=0xfd;tone2=0xc8;EA=1;break;
case 0xfd:shumaguan=0x24;tone1=0xfe;tone2=0x6;EA=1;break;
case 0xfb:shumaguan=0x30;tone1=0xfe;tone2=0x3e;EA=1;break;
case 0xf7:shumaguan=0x19;tone1=0xfe;tone2=0x57;EA=1;break;
case 0xef:shumaguan=0x12;tone1=0xfe;tone2=0x85;EA=1;break;
case 0xdf:shumaguan=0x02;tone1=0xfe;tone2=0xaf;EA=1;break;
case 0xbf:shumaguan=0x78;tone1=0xfe;tone2=0xd4;EA=1;break;
case 0x7f:play2();break;
/*****主程序*****/
void main(void)
initTimer();
// shumaguan=0xff;
TR0=1;
ET0=1;
SPK=0;
check_key();
