標題: 簡易單片機電子鐘制作 [打印本頁]
作者: kevinw    時間: 2021-11-27 15:16
標題: 簡易單片機電子鐘制作
本著免費打樣的福利,鄭重聲明我不是廠商托,
不是廣告
不是廣告
不是廣告,
重要的事說三遍。
拿出了十幾年不用的STC,翻箱倒柜兩星期,終于找齊了原件,,打算給孩子做個玩具,本以為一兩天就搞定的事情,結果搞了一星期,。最后也是終于在參考論壇后,找到BUG,本著搬運他人,現回饋他人的原則,貢獻電路代碼。
#include "STC12C5A60S2.h"
#include<intrins.h>
typedef unsigned char uchar;
typedef unsigned int uint;
/* define constants */
#define FOSC 11059200L
//#define MODE1T                      //Timer clock mode, comment this line is 12T mode, uncomment is 1T mode
#ifdef MODE1T
#define T1MS (65536-FOSC/500)      //2ms timer calculation method in 1T mode
#else
#define T1MS (65536-FOSC/12/50)   //50ms timer calculation method in 12T mode
#endif
#define F4KHz (256-FOSC/2/12/1000)   //CLOCKOUT1
sfr WAKE_CLKO = 0x8f;
//數碼管共陰極端口選擇,低電平
sbit S1        =        P0^7;
sbit S2        =        P0^6;
sbit S3        =        P0^5;
sbit S4        =        P0^4;
//LED共陰極,低電平
sbit S5        =        P0^2;
sbit S6=        P0^1;
sbit S7        =        P0^0;
sbit S8        =        P1^2;
sbit S9        =        P1^3;
sbit S10        =        P1^7;
sbit S11        =        P1^6;
sbit S12        =        P0^3;
//蜂鳴器
sbit fmq = P3^5;
// 按鍵
sbit KEY_IN_1 = P1^4;
sbit KEY_IN_2 = P1^5;
//sbit KEY_IN_3 = P3^1;
//sbit KEY_IN_4 = P3^0;
//DS1302
sbit sclk = P3^2;
sbit sda  = P3^3;
sbit rst  = P3^4;
//共陰極數碼管顯示碼,0-9,a-f,-,全滅,code區常數
unsigned char code smg[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,
                          0x77,0x7C,0x39,0x5E,0x79,0x71,0x40,0x00};
unsigned char num[4]={0,0,0,0};//顯示緩沖區
unsigned char alarm_num[4]={0,0,0,0};//alarm顯示緩沖區
//60位LED流水燈控制
unsigned char data led_smg [8]= {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
/* define variables */
unsigned char  miao = 0,fen =0,shi =0;                     //TIME
unsigned char  alarm_fen = 0; alarm_shi =12;   //alarm time
unsigned int         count1;                //counter for 1s
unsigned int         key_count;             //按鍵次數計數,狀態切換
bit alarm = 0;                       //時鐘啟動控制位
bit dq =0;                           //設置時間模式
unsigned char mod = 0;  //設置分=1 設置時=2  ,設置鬧鐘分=3,設置鬧鐘時=4,
/*----------------------------函數聲明-------------------*/
void led_display();
void display();
void alarm_display();
void time();
void KeyScan();
void alarm_prc();
void time_prc();
void delay(unsigned int T)   //us延時函數
    unsigned char b,c;
    for(c=T;c>0;c--)
        for(b=5;b>0;b--);
void delayms(uint z)     //delayms
         uint x,y;
          for(x=z;x>0;x--)
            for(y=848;y>0;y--);
/* Timer0 interrupt routines,2ms */
void tm0_isr() interrupt 1
     TL0 = T1MS;                     //reload timer0 low byte
     TH0 = T1MS >> 8;                //reload timer0 high byte
                 count1++;
                 time();                        //定時器時鐘
/* main program */
          P2M1 = 0x00;
                P2M0 = 0xff;        //        P2強推挽
          P2   = 0x00;        //  全關閉
#ifdef MODE1T
    AUXR = 0x80;                    //timer0 work in 1T mode,timer1 work 12T mode
#endif
    TMOD = 0x21;                    //set timer0 as mode1 (16-bit),set timer1 as mode2 (8-bit auto-reload)
    TL0 = T1MS;                     //initial timer0 low byte
    TH0 = T1MS >> 8;                //initial timer0 high byte
          TL1 = F4KHz;                 //initial timer1
    TH1 = F4KHz;                 //initial timer1
    ET0 = 1;                        //enable timer0 interrupt
    EA = 1;                         //open global interrupt switch
                TR0 = 1;                        //timer0 start running
    while (1)
     KeyScan();
                        if (dq)
                                         time_prc();         //設置時鐘
                                         display();
                        if(alarm)
                                 alarm_prc();         //設置鬧鐘
                                 alarm_display();     //顯示設置時間
                        if((dq == 0) && (alarm ==0))
                                display();
                    led_display();
             if((alarm_shi==shi)&&(alarm_fen==fen)) { WAKE_CLKO= 0x02;        TR1 = 1 ;}
                         if(fen == (alarm_fen+1))     // 1s
                         WAKE_CLKO= 0x00;TR1 = 0;
//-------------------- control time function --------------------
void time_prc()
                num[3] = fen%10;    //分鐘個位
                num[2] = fen/10;    //分鐘十位
                num[1] = shi%10;
                num[0] = shi/10;
//-----------------------alarm  time function------------------
void alarm_prc()
                alarm_num[3] = alarm_fen%10;    //分鐘個位
                alarm_num[2] = alarm_fen/10;    //分鐘十位
                alarm_num[1] = alarm_shi%10;
                alarm_num[0] = alarm_shi/10;
//--------------------------------key Scan-----------------------
void KeyScan()
          if (KEY_IN_1 == 0)
                          delayms(10);
                          if (KEY_IN_1 == 0)              //按鍵確認
              key_count++;              //按鍵次數計數
                                      while(!KEY_IN_1);         //等待釋放
                                                  if(key_count ==1)         // first key
        TR0 =0;            //關閉定時器
                   P0 = P0|0x0f;
                   P1 = P1|0xcc;      //關閉LED
        dq =1;             //時間設置模式
        alarm = 0;                                        //鬧鐘設置關閉
        mod =1;            // 時間分設置
                                                        if(key_count == 2)
        mod = 2;          //時間時設置
                                                        if(key_count == 3)
        dq = 0;         //時間設置關閉
        alarm = 1;      //鬧鐘設置開
        mod = 3;       //鬧鐘分設置
                                                        if(key_count == 4)
        mod = 4;       //鬧鐘時設置
                                                        if(key_count == 5)    //退出設置,開始記時
        key_count =0 ;      //
        alarm = 0;
        dq = 0;
        mod =0;
                    TR0=1;
                if(key_count != 0)                //進入設置模式
                   if(KEY_IN_2== 0)
                               delayms(10);
                               if(KEY_IN_2 == 0)        //確認KEY2按鍵
                  while(!KEY_IN_2);     //等待釋放
        if(mod == 1)
                            fen++;
                               if(fen == 60)
        fen = 0;
        if(mod == 2)
        shi++;
        if(shi == 24)
        shi = 0;
        if(mod == 3)
        alarm_fen++;
        if(alarm_fen == 60)
        alarm_fen =0;
        if(mod == 4)
        alarm_shi++;
        if(alarm_shi == 24)
        alarm_shi =0;
//-----------------------------auto 時間更新函數-----------------------------------
void time()
         if(count1 == 50)               // 1s
                  count1 = 0;
                  miao++;
                         switch(miao)
                                          case 1:   led_smg[0] = 0x01;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x00;        break;
                                                case 2:   led_smg[0] = 0x02;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 3:   led_smg[0] = 0x04;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 4:   led_smg[0] = 0x08;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
            case 5:   led_smg[0] = 0x10;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 6:   led_smg[0] = 0x20;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 7:   led_smg[0] = 0x40;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 8:   led_smg[0] = 0x80;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                          case 9:   led_smg[0] = 0x00;led_smg[1] = 0x01;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 10:  led_smg[0] = 0x00;led_smg[1] = 0x02;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 11:  led_smg[0] = 0x00;led_smg[1] = 0x04;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 12:  led_smg[0] = 0x00;led_smg[1] = 0x08;led_smg[2] = 0x00;led_smg[3] = 0x00;
            case 13:  led_smg[0] = 0x00;led_smg[1] = 0x10;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 14:  led_smg[0] = 0x00;led_smg[1] = 0x20;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 15:  led_smg[0] = 0x00;led_smg[1] = 0x40;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                                case 16:  led_smg[0] = 0x00;led_smg[1] = 0x80;led_smg[2] = 0x00;led_smg[3] = 0x00;
                                          case 17:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x01;led_smg[3] = 0x00;
                                                case 18:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x02;led_smg[3] = 0x00;
                                                case 19:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x04;led_smg[3] = 0x00;
                                                case 20:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x08;led_smg[3] = 0x00;
            case 21:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x10;led_smg[3] = 0x00;
                                                case 22:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x20;led_smg[3] = 0x00;
                                                case 23:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x40;led_smg[3] = 0x00;
                                                case 24:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x80;led_smg[3] = 0x00;
                                          case 25:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x01;
                                                case 26:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x02;
                                                case 27:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x04;
                                                case 28:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x08;
            case 29:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x10;
                                                case 30:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x20;
                                                case 31:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x40;
                                                case 32:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x80;
                                          case 33:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x01;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x00;        break;
                                                case 34:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x02;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x00;        break;
                                                case 35:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x04;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x00;        break;
                                                case 36:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x08;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
            case 37:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x10;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                                case 38:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x20;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                                case 39:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x40;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                                case 40:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x80;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                          case 41:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x01;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                                case 42:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x02;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                                case 43:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x04;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                                case 44:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x08;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
            case 45:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x10;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                                case 46:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x20;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                                case 47:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x40;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                                case 48:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x80;led_smg[6] = 0x00;led_smg[7] = 0x00;  break;
                                          case 49:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x01;led_smg[7] = 0x00;  break;
                                                case 50:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x02;led_smg[7] = 0x00; break;
                                                case 51:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x04;led_smg[7] = 0x00; break;
                                                case 52:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x08;led_smg[7] = 0x00; break;
            case 53:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x10;led_smg[7] = 0x00; break;
                                                case 54:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x20;led_smg[7] = 0x00; break;
                                                case 55:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x40;led_smg[7] = 0x00; break;
                                                case 56:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x80;led_smg[7] = 0x00; break;
                                          case 57:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x01; break;
                                                case 58:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x02;  break;
                                                case 59:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x04;  break;
                                                case 60:  led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                      led_smg[4] = 0x00;led_smg[5] = 0x00;led_smg[6] = 0x00;led_smg[7] = 0x08; break;
           default :         led_smg[0] = 0x00;led_smg[1] = 0x00;led_smg[2] = 0x00;led_smg[3] = 0x00;
                    if(miao == 60)             //1min
                                             miao = 0;
                                             fen++;
                                             if(fen == 60)
        fen = 0;
        shi++;
        if(shi == 24)
        shi = 0;
                num[1] = shi%10;
                num[0] = shi/10;
//數碼管顯示函數
void display()
        P2  =  smg[num[0]];
              S1= 0;
              delay(1);
                                P2 =   smg[17];
              S1  = 1 ;
              P2 = smg[num[1]];
              S2 = 0;
        delay(1);
                    P2 =   smg[17];
              S2 = 1;
                    P2 = smg[num[2]];
              S3 = 0;
        delay(1);
                    P2 =   smg[17];
              S3 = 1;
              P2 = smg[num[3]];
              S4 = 0;
        delay(1);
                    P2 =   smg[17];
              S4 = 1;
//alarm數碼管顯示函數
        P2  =  smg[alarm_num[0]];
              S1= 0;
              delay(1);
                                P2 =   smg[17];
              S1  = 1 ;
              P2 = smg[alarm_num[1]];
              S2 = 0;
        delay(1);
                    P2 =   smg[17];
              S2 = 1;
                    P2 = smg[alarm_num[2]];
              S3 = 0;
        delay(1);
                    P2 =   smg[17];
              S3 = 1;
              P2 = smg[alarm_num[3]];
              S4 = 0;
        delay(1);
                    P2 =   smg[17];
              S4 = 1;
//流水燈顯示
void led_display()
              P2  =  led_smg[0];
              S5 = 0;
              delay(1);
                                P2 =   0x00;
              S5  = 1 ;
              P2 = led_smg[1];
              S6 = 0;
       delay(1);
                    P2 =   0x00;
              S6 = 1;
                    P2 = led_smg[2];
              S7 = 0;
        delay(1);
                    P2 =   0x00;
              S7 = 1;
              P2 = led_smg[3];
              S8 = 0;
       delay(1);
                    P2 =   0x00;
              S8 = 1;
              P2 = led_smg[4];
              S9 = 0;
        delay(1);
                    P2 =   0x00;
              S9 = 1;
              P2 = led_smg[5];
              S10 = 0;
        delay(1);
                    P2 =   0x00;
              S10 = 1;
              P2 = led_smg[6];
              S11 = 0;
        delay(1);
                    P2 =   0x00;
              S11 = 1;
              P2 = led_smg[7];
              S12 = 0;
        delay(1);
                    P2 =   0x00;
              S12 = 1;
作者: npn    時間: 2021-11-27 16:34
你這程序太亂,delay 這樣寫,數碼管顯示,流水燈什么都要用定時器中斷處理才對的吧。
unsigned int delay_ms = 0;
bit _delay_ = 0;
#define delayms(ms) delay_ms=(ms);_delay_=1;while(_delay_)
    TL0 = T1MS;
    TH0 = T1MS >> 8;
    count1++;
    time();
    if (_delay_ && !--delay_ms) {
        _delay_ = 0;
作者: wxxl    時間: 2021-11-27 17:37
樓主,可以的,竟然給人送鐘(終),這要多大的仇啊!
作者: hhdsdy    時間: 2021-11-27 23:31
圓盤LED那里,強迫癥患者表示無法接受,首先是數字1呆在了60(應該為0)的位置,所以15也無法呆在水平的位置,偏偏30的位置又是對的(29的絲印也反了)。
然后是LED的方向,從28到57是雜亂無章的
明明是圓盤時鐘,卻整了個四方形的邊框,而且數字太密也不好看,還是0、5、10、15……這樣比較好看。
沒有RTC,沒有亮度控制,所以并不實用(最好鬧鐘一起整一個)。
玩笑話,沒有貶低的意思,別介意啊,我自己用60個WS2812加ESP-12F模塊加PCF8563做的,硬件線路很簡單的,還可以網絡校時。
作者: tieq1952    時間: 2021-11-28 07:15
謝謝分享!!!
雖不完美,但值得稱贊!!!
