標題: stm32 開發板的通信 [打印本頁]
作者: hhha_    時間: 2021-11-25 13:38
標題: stm32 開發板的通信
void RS485_Init(u32 bound) ;
void RS485_Receive_Data(u8 *ReceiveBuf,u8 *len);
void RS485_Send_Data(u8 *SendBuf ,u8 len);
    GPIO_InitTypeDef GPIO_InitType;
    USART_InitTypeDef USART_InitType;
    NVIC_InitTypeDef NVIC_InitType;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD,ENABLE);       //使能GPIOA和GPIOD的時鐘
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);                       //使能USART2的時鐘
    GPIO_InitType.GPIO_Pin=GPIO_Pin_7;                                   //接收或者發送模式控制引腳PD7(初始化之后才能用)
    GPIO_InitType.GPIO_Mode = GPIO_Mode_Out_PP;                       //推挽輸出
    GPIO_InitType.GPIO_Speed=GPIO_Speed_50MHz;                     //這個引腳是485芯片中的發送接收控制引腳
    GPIO_Init(GPIOD,&GPIO_InitType);                                   //當PDout(7)輸出的是高電平‘1’時是發送,為‘0’時是接收
    GPIO_InitType.GPIO_Pin=GPIO_Pin_2;                                  //USART2的TX引腳是PA2
    GPIO_InitType.GPIO_Mode=GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA,&GPIO_InitType);
    GPIO_InitType.GPIO_Pin=GPIO_Pin_3;                                  //USART2的RX引腳是PA3
    GPIO_InitType.GPIO_Mode=GPIO_Mode_IN_FLOATING;
    #ifdef EN_RS485_RX
        USART_InitType.USART_BaudRate=bound;                                        //串口2的初始化
        USART_InitType.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
        USART_InitType.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
        USART_InitType.USART_Parity=USART_Parity_No;                       //其中重要的是USART_Mode要既能接收又能發送
        USART_InitType.USART_StopBits=USART_StopBits_1;                   //USART2的波特率都設置為9600
        USART_InitType.USART_WordLength=USART_WordLength_8b;
        USART_Init(USART2,&USART_InitType);
        NVIC_InitType.NVIC_IRQChannel=USART2_IRQn;                          //USART2中斷初始化
        NVIC_InitType.NVIC_IRQChannelCmd=ENABLE;                            //其實這個中斷主要是對發送的數據及時處理,使接收時便捷高效
        NVIC_InitType.NVIC_IRQChannelPreemptionPriority=3;
        NVIC_InitType.NVIC_IRQChannelSubPriority=3;
        NVIC_Init(&NVIC_InitType);
        USART_ITConfig(USART2,USART_IT_RXNE,ENABLE);            //要用到USART2中斷除了初始化之外當然要對中斷進行配置以及使能
        USART_Cmd(USART2,ENABLE);                                 //明確發生什么時會進入串口中斷
    #endif
    RX485_TX_EN=0;              //默認接收模式
這里的串口中斷函數,發送的數據被接收數據寄存器接收到,就會觸發中斷,進行處理
#ifdef EN_RS485_RX
u8 RS485_RX_BUF[64];
u8 RS485_RX_CNT=0;
void USART2_IRQHandler(void)       //發送完數據就使能接收中斷,使串口可以接收數據到緩沖區(數組RS485_RX_BUF)中
    u8 Res;
    if(USART_GetITStatus(USART2,USART_IT_RXNE)!=RESET)
        Res=USART_ReceiveData(USART2);
        if(RS485_RX_CNT<64)                         //一次接收的數據最多為64,超過之后將不會對發送過來的數據進行緩存
            RS485_RX_BUF[RS485_RX_CNT]=Res;
            RS485_RX_CNT++;
#endif
void RS485_Send_Data(u8 *SendBuf ,u8 len)                       //發送處理函數
    u8 i;
    RX485_TX_EN=1;
    for(i=0;i<len;i++)                                                          //把長度為len的數組SendBuf發送出去
        while(USART_GetFlagStatus(USART2,USART_FLAG_TC)==RESET);        //等待發送移位數據寄存器的數據非空時(即發送結束)跳出來
        USART_SendData(USART2,SendBuf[i]);                                          //發送數據
    RS485_RX_CNT=0;
void RS485_Receive_Data(u8 *ReceiveBuf,u8 *len)                     //接收處理函數
    u8 rxlen,i=0;
    rxlen=RS485_RX_CNT;
    delay_ms(10);
    if((rxlen==RS485_RX_CNT)&&rxlen)                             //把中斷函數處理之后的緩存數據取出來
        for(i=0;i<rxlen;i++)
            ReceiveBuf[i]=RS485_RX_BUF[i];                       //傳遞接收到的數據以及長度回去
        *len=RS485_RX_CNT;
        RS485_RX_CNT=0;                                            //對接收的個數進行清零,方便下次接收
