新手求助?*** ERROR L104: MULTIPLE PUBLIC DEFINITIONS
virus123
2021-11-14 19:39
#include <reg52.h>
#include <intrins.h>
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P1^2;
sbit DQ=P1^4;
sbit buzz=P0^6;
unsigned char temp0,temp1,temp2,readtemp;
unsigned char s[]={"Temp:"};
unsigned char str[]={0,1,2,3,4,5,6,7,8,9};
void delay(unsigned int n)
unsigned i=0,j=0;
for(i=0;i<n;i++)
for(j=0;j<120;j++);
//*************************ds18b20****************************************
void Write_DS18B20(unsigned char dat)
unsigned char i;
for(i=0;i<8;i++)
DQ = 0;
DQ = dat&0x01;
delay(5);
DQ = 1;
dat >>= 1;
delay(5);
unsigned char Read_DS18B20(void)
unsigned char i;
unsigned char dat;
for(i=0;i<8;i++)
DQ = 0;
dat >>= 1;
DQ = 1;
if(DQ)
dat |= 0x80;
delay(5);
return dat;
bit init_ds18b20(void)
bit initflag = 0;
DQ = 1;
delay(12);
DQ = 0;
delay(80);
DQ = 1;
delay(10);
initflag = DQ;
delay(5);
return initflag;
unsigned char Readtemp(void)
unsigned char low,high;
char temp;
init_ds18b20();
Write_DS18B20(0xCC);
Write_DS18B20(0x44);
delay(200);
init_ds18b20();
Write_DS18B20(0xBE);
low = Read_DS18B20();
high = Read_DS18B20();
temp = high<<4;
temp |= (low>>4);
return temp;
//*********************1602************************************
void writedat(unsigned char dat)
RS=1;
RW=0;
E=0;
P0=dat;
delay(5);
E=1;
E=0;
void writecom(unsigned char com)
RS=0;
RW=0;
E=0;
P0=com;
delay(5);
E=1;
E=0;
void initlcd()
writecom(0x38);
writecom(0x0c);
writecom(0x06);
writecom(0x01);
void display()//ÏÔê¾oˉêy
unsigned int temp0=0,temp1=0,temp2=0,i=0;
temp0=readtemp/100;
temp1=(readtemp%100)/10;
temp2=readtemp%10;
writecom(0x80);
delay(5);
while(s[i]!='\0')
writedat(s[i]);
delay(5);
i++;
writecom(0x80+0x40+5);
delay(5);
writedat(str[temp0]);
delay(5);
writedat(str[temp1]);
delay(5);
writedat(str[temp2]);
delay(5);
writedat(0xDF);
delay(5);
writedat('C');
delay(5);
initlcd();
readtemp=Readtemp();
display();
wulin
2021-11-14 20:48
變量與函數同名錯誤:readtemp=Readtemp();
virus123
2021-11-14 21:17
wulin 發表于 2021-11-14 20:48
已解決!
