標(biāo)題: 單片機(jī)16位按鍵控制兩位數(shù)碼管程序Proteus仿真 [打印本頁(yè)]
作者: linminjy    時(shí)間: 2021-11-10 15:42
1.盡量不要一個(gè)一個(gè)位的設(shè)置,通過(guò)P0,P1,P2設(shè)置輸出狀態(tài)
2.P1 = 0x0f;
delay(1);
Tmp = P1 ^ 0x0f;
P1 = 0xf0;
delay(1);
Tmp = P1 >> 4 ^ 0x0f
3.P1=0x0f->芯片內(nèi)部對(duì)外輸出狀態(tài)
單片機(jī)源程序如下:
  1. #include <reg51.h>
  2. typedef unsigned char uint8;
  3. typedef unsigned int uint16;
  4. code uint8 LED_CODE1[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  5. 0x7f,0x6f,0x3f,0x06,0x5b,0x4f,0x66,0x6d};
  6. //個(gè)位:0,1,2,3,4,5,6,7,8,9,0,1,2,3,4,5
  7. code uint8 LED_CODE2[] = {0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,
  8. 0x3f,0x3f,0x06,0x06,0x06,0x06,0x06,0x06};
  9. //十位:0,0,0,0,0,0,0,0,0,0,1,1,1,1,1,1
  10. uint8 KeyValue; //存放讀取的鍵值
  11. uint8 KeyState; //存放鍵的狀態(tài)
  12. void delay(uint16 x)
  13. {
  14.         uint16 i,j;
  15.         for(i = x; i > 0; i --)
  16.         for(j = 114; j > 0; j --);
  17. }
  18. void Beep()
  19. {
  20.         uint8 i;
  21.         for(i=0;i<100;i++)
  22.         {
  23.                 delay(1);
  24.                 P3 ^= 0x01;
  25.         }
  26. }
  27. void DigDisplay()
  28. {
  29.         P2 = 0x01;
  30.         P0 = LED_CODE1[KeyValue];
  31.         delay(10);
  32.         P2 = 0x02;
  33.         P0 = LED_CODE2[KeyValue];
  34.         delay(10);
  35. }
  36. void KeyDown()
  37. {
  38.         uint8 Tmp;
  39.         P1=0xf0; //對(duì)于并行口,不算賦值,是輸出狀態(tài);
  40.         if(P1!=0xf0)
  41.         {
  42.                 KeyState=1;
  43.                 P1=0x0f;
  44.                 Tmp = P1 ^ 0x0f;  //檢測(cè)低四位
  45.                 switch(Tmp)
  46.                 {
  47.                         case 1: KeyValue = 0; break;
  48.                         case 2: KeyValue = 1; break;
  49.                         case 4: KeyValue = 2; break;
  50.                         case 8: KeyValue = 3; break;
  51.                         default: KeyValue = 16;
  52.                 }
  53.                 P1=0xf0;
  54.                 Tmp = P1 >> 4 ^ 0x0f;//檢測(cè)高四位
  55.                 switch(Tmp)
  56.                 {
  57.                         case 1: KeyValue += 0; break;
  58.                         case 2: KeyValue += 4; break;
  59.                         case 4: KeyValue += 8; break;
  60.                         case 8: KeyValue += 12;
  61.                 }
  62.                 while(P1!=0xf0);
  63.                 Beep();
  64.         }
  65. }
  66. void main()
  67. {
  68.         KeyState = 0;
  69.         KeyValue = 0;
  70.         while(1)
  71.         {
  72.                 KeyDown();
  73.                 if(KeyState==1)
  74.                         KeyState = 0;
  75.                 DigDisplay();
  76.         }
  77. }
所有資料51hei附件下載:
實(shí)驗(yàn)四.zip (192.67 KB, 下載次數(shù): 13)
