我想從串口助手獲取數字而不是字符,但是單片機程序編寫錯誤
黑大不帥就瀟灑
2021-11-4 15:07
#include <STC89C5xRC.H>
int PWM = 10, num1 = 0, num2 = 9;
void UartInit(void) //9600bps@11.0592MHz
PCON &= 0x7F; //波特率不倍速
SCON = 0x50; //8位數據,可變波特率
TMOD &= 0x0F; //設置定時器模式
TMOD |= 0x22; //設置定時器模式
TL1 = 0xFD; //設置定時初始值
TH1 = 0xFD; //設置定時重載值
TL0 = 0x48; //設置定時初始值
TH0 = 0x48; //設置定時重載值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
ET0 = 1;
ET1 = 0;
TR1 = 1; //定時器1開始計時
char _getkey ()
char num2;
while(!RI);
num2 = SBUF;
RI = 0;
return (num2);
void int4() interrupt 4
if (RI)
scanf("%bd ", &num2);
void int1() interrupt 1
num1 = (num1 + 1) % PWM;
if (num1 < num2)
P20 = 1;
P20 = 0;
UartInit();
ES = 1;
EA = 1;
while(1);
(239.56 KB, 下載次數: 41)
2021-11-4 15:06 上傳
Y_G_G
2021-11-4 20:55
#include "stdio.h"
標準輸入輸出的函數原型要包含
這不是C語言的基礎嗎?
man1234567
2021-11-4 21:23
知錯就改,善摸大煙
