標(biāo)題: fread讀取文件數(shù)據(jù)程序,strstr無(wú)法匹配到指定字符串,請(qǐng)教一下是哪里的問(wèn)題,謝謝 [打印本頁(yè)]
作者: hei51com    時(shí)間: 2021-9-25 11:00
要求:匹配bin文件中是否有"R_FW_FLAG"、"T_FW_FLAG"字符串,如果有返回真、和字符串所在文件中的偏移量(只使用fread讀文件數(shù)據(jù))。
問(wèn)題:讀取bin文件數(shù)據(jù),strstr無(wú)法匹配到指定字符串,讀出來(lái)的數(shù)據(jù)我打印出來(lái)確認(rèn)跟bin文件是一樣的,我的代碼如下,bin文件如附件,請(qǐng)幫忙看看是哪里的問(wèn)題,非常感謝!
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#include<time.h>
#include <conio.h>
#ifdef __cplusplus
#error "1111"
extern "C" {
#endif
typedef signed char        int8_t;    /*!< exact-width  8-bit signed   int  */
typedef signed short       int16_t;   /*!< exact-width 16-bit signed   int  */
typedef signed long        int32_t;   /*!< exact-width 32-bit signed   int  */
typedef signed long long   int64_t;   /*!< exact-width 64-bit signed   int  */
typedef unsigned char      uint8_t;   /*!< exact-width  8-bit unsigned int  */
typedef unsigned short     uint16_t;  /*!< exact-width 16-bit unsigned int  */
typedef unsigned long      uint32_t;  /*!< exact-width 32-bit unsigned int  */
typedef unsigned long long uint64_t;  /*!< exact-width 64-bit unsigned int  */
void log_infox(const void *s, const uint8_t n)
        uint8_t i;
        if(n == 0) return;
        for(i = 0; i < n; i++)
                //printf("%02X ", *(s + i));
                printf("%02X ", *((uint8_t *)s + i));
                //printf("%02X ", uint8_t*(s + i));
        printf("\n");
#define R_FW_FLAG "R_FW_FLAG"
#define T_FW_FLAG "T_FW_FLAG"
#ifndef FALSE
#define FALSE  0
#endif
#ifndef TRUE
#define TRUE   (!FALSE)
#endif
#define _OK    TRUE
#define _FAIL  FALSE
FILE *fd;
#if 1
uint8_t file_read(void* buf,uint32_t offs, int len)
    char*  err_str = "FAIL";
    uint64_t read_sta = 0,seek_sta= 1;
        seek_sta = fseek(fd, offs, SEEK_SET);
        //printf("seek_sta=0x%x(%d),offs=0x%x(%d),len=0x%x(%d)\n",seek_sta,seek_sta,offs,offs,len,len);
    if (seek_sta != 0)
            printf("\nfseek fail:fd=%d\n",fd);
        goto err;
        read_sta = fread(buf, 1,len,fd);
        //printf("read_sta=0x%x(%d)\n",read_sta,read_sta);
    if (read_sta != len)
            printf("\nfread fail:fd=%d,len=%d,%d\n",fd,len,fread(buf, len,1,fd));
        goto err;
        //printf("file_read ok:fd=%d\n",fd);
    return _OK;
    err:
    printf("%s,fd=%d\n",err_str,fd);
    return _FAIL;
#endif
int main(int argc, char *argv[]) {
        printf("----main-----\n");
        uint64_t seek_offset = 0,length = 0,i = 0;
        //uint64_t j = 0,k = 0;
    uint16_t upgarde_state;
        uint8_t temp_buf[500];
        uint8_t read_sta = _FAIL;
        (void) i;
        clock_t start,end;
        start = clock();
        memset(temp_buf,0x00,sizeof(temp_buf));
        if((fd = fopen("test.bin","rb"))==NULL)//同main.c目錄下
                printf("Open file fail!\n");
                exit(1);
        fseek(fd,0L,SEEK_END);
        length = ftell(fd);
        printf("file lenght=0x%x(%d)\n",length,length);
        //file_read(&temp_buf[0],seek_offset,64);
        //log_infox(temp_buf,64);
        printf("\n");
            read_sta = file_read((void*)temp_buf+seek_offset,seek_offset,16);
            seek_offset+=16;
                if (read_sta == _OK)
                        log_infox((void*)temp_buf+(seek_offset-16),16);
                        #if 1
                        if (!(upgarde_state&0x04))
                        if (strstr(temp_buf, R_FW_FLAG) != NULL)
                                upgarde_state|= 0x04;
                                printf("check R fw flag ok!\n");
                                end = clock(); //結(jié)束時(shí),取得結(jié)束時(shí)間
                                printf("Run time: %lf S\n",(double)(end-start)/CLOCKS_PER_SEC);
                                //break;
                        if (!(upgarde_state&0x08))
                        if (strstr(temp_buf, T_FW_FLAG) != NULL)
                                upgarde_state|= 0x08;
                                printf("check T fw flag ok!\n");
                                //break;
                        #endif
                        goto main_end;
        main_end:
                printf("main end: %lf S\n",(double)(end-start)/CLOCKS_PER_SEC);
        return 0;
#ifdef __cplusplus
#endif
test.rar
239 Bytes, 下載次數(shù): 1
作者: hei51com    時(shí)間: 2021-12-22 22:37
已自行摸索解決了
