標題: TB67H450FNG引腳圖與pdf英文資料 PWM斬波式直流有刷電機驅動芯片 [打印本頁]
作者: chipspower123    時間: 2021-8-31 15:46
PWM斬波式直流有刷電機驅動器
下載見附件
PWM Chopper Type DC Brushed Motor Driver
The TB67H450FNG is a PWM chopper type DC brushed motor driver.
One channel of motor output block is embedded.
Fabricated with the BiCD process, the TB67H450FNG is rated at output
voltage 50 V, maximum current 3.5A.
Features
・  Monolithic IC using BiCD process
・  Capable of PWM constant current drive and direct PWM drive
・  Supporting 4 operation modes, Forward / Reverse / Brake / STOP (OFF)
引腳圖:
TB67H450FNG.pdf
742.08 KB, 下載次數: 45, 下載積分: 黑幣 -5
