STC12單片機硬件SPI實現NRF24L01的發送/接收/中斷接收
michaelchain
2021-8-29 21:23
今天解決了一個之前困擾很久的1E狀態的問題, 把RX, TX和EXIT+RX的模式都跑通了.
代碼基于
HML_FwLib_STC12
, 在倉庫的examples里,
鏈接地址
使用的是STC12的硬件SPI的方式, 不是軟件模擬的SPI, 主體代碼如下, 將 CURRENT_MODE 改成不同的值, 會分別啟動到RX, TX和EXTI RX這三種模式, 運行時需要兩塊NRF24L01配合測試.
* \file spi_nrf24l01_tx.c
* \date
* \brief Example code of SPI driving NRF24L01 module in TX mode
* \note Pin connection:
* P1_4(SS, Ignored) => CSN,
* P1_5(MOSI) => MOSI,
* P1_6(MISO) => MISO,
* P1_7(SPCLK) => CLK,
* P3_2(INT0) => IRQ,
* P3_7(IO) => CE,
* \version v0.1
* \ingroup example
* \remarks test-board: Minimum System; test-MCU: STC12C5AF56S2
* header file *
#include "hml/hml.h"
#include <stdio.h>
/********** SPI(nRF24L01) commands ***********/
#define NRF24_CMD_REGISTER_R 0x00 // Register read
#define NRF24_CMD_REGISTER_W 0x20 // Register write
#define NRF24_CMD_ACTIVATE 0x50 // (De)Activates R_RX_PL_WID, W_ACK_PAYLOAD, W_TX_PAYLOAD_NOACK features
#define NRF24_CMD_RX_PLOAD_WID_R 0x60 // Read RX-payload width for the top R_RX_PAYLOAD in the RX FIFO.
#define NRF24_CMD_RX_PLOAD_R 0x61 // Read RX payload
#define NRF24_CMD_TX_PLOAD_W 0xA0 // Write TX payload
#define NRF24_CMD_ACK_PAYLOAD_W 0xA8 // Write ACK payload
#define NRF24_CMD_TX_PAYLOAD_NOACK_W 0xB0 //Write TX payload and disable AUTOACK
#define NRF24_CMD_FLUSH_TX 0xE1 // Flush TX FIFO
#define NRF24_CMD_FLUSH_RX 0xE2 // Flush RX FIFO
#define NRF24_CMD_REUSE_TX_PL 0xE3 // Reuse TX payload
#define NRF24_CMD_LOCK_UNLOCK 0x50 // Lock/unlock exclusive features
#define NRF24_CMD_NOP 0xFF // No operation (used for reading status register)
// SPI(nRF24L01) register address definitions
#define NRF24_REG_CONFIG 0x00 // Configuration register
#define NRF24_REG_EN_AA 0x01 // Enable "Auto acknowledgment"
#define NRF24_REG_EN_RXADDR 0x02 // Enable RX addresses
#define NRF24_REG_SETUP_AW 0x03 // Setup of address widths
#define NRF24_REG_SETUP_RETR 0x04 // Setup of automatic re-transmit
#define NRF24_REG_RF_CH 0x05 // RF channel
#define NRF24_REG_RF_SETUP 0x06 // RF setup
#define NRF24_REG_STATUS 0x07 // Status register
#define NRF24_REG_OBSERVE_TX 0x08 // Transmit observe register
#define NRF24_REG_RPD 0x09 // Received power detector
#define NRF24_REG_RX_ADDR_P0 0x0A // Receive address data pipe 0
#define NRF24_REG_RX_ADDR_P1 0x0B // Receive address data pipe 1
#define NRF24_REG_RX_ADDR_P2 0x0C // Receive address data pipe 2
#define NRF24_REG_RX_ADDR_P3 0x0D // Receive address data pipe 3
#define NRF24_REG_RX_ADDR_P4 0x0E // Receive address data pipe 4
#define NRF24_REG_RX_ADDR_P5 0x0F // Receive address data pipe 5
#define NRF24_REG_TX_ADDR 0x10 // Transmit address
#define NRF24_REG_RX_PW_P0 0x11 // Number of bytes in RX payload in data pipe 0
#define NRF24_REG_RX_PW_P1 0x12 // Number of bytes in RX payload in data pipe 1
#define NRF24_REG_RX_PW_P2 0x13 // Number of bytes in RX payload in data pipe 2
#define NRF24_REG_RX_PW_P3 0x14 // Number of bytes in RX payload in data pipe 3
#define NRF24_REG_RX_PW_P4 0x15 // Number of bytes in RX payload in data pipe 4
#define NRF24_REG_RX_PW_P5 0x16 // Number of bytes in RX payload in data pipe 5
#define NRF24_REG_FIFO_STATUS 0x17 // FIFO status register
#define NRF24_REG_DYNPD 0x1C // Enable dynamic payload length
#define NRF24_REG_FEATURE 0x1D // Feature register
// Register bits definitions
#define NRF24_CONFIG_PRIM_RX 0x01 // PRIM_RX bit in CONFIG register
#define NRF24_CONFIG_PWR_UP 0x02 // PWR_UP bit in CONFIG register
#define NRF24_FEATURE_EN_DYN_ACK 0x01 // EN_DYN_ACK bit in FEATURE register
#define NRF24_FEATURE_EN_ACK_PAY 0x02 // EN_ACK_PAY bit in FEATURE register
#define NRF24_FEATURE_EN_DPL 0x04 // EN_DPL bit in FEATURE register
#define NRF24_FLAG_RX_DREADY 0x40 // RX_DR bit (data ready RX FIFO interrupt)
#define NRF24_FLAG_TX_DSENT 0x20 // TX_DS bit (data sent TX FIFO interrupt)
#define NRF24_FLAG_MAX_RT 0x10 // MAX_RT bit (maximum number of TX re-transmits interrupt)
// Register masks definitions
#define NRF24_MASK_REG_MAP 0x1F // Mask bits[4:0] for CMD_RREG and CMD_WREG commands
#define NRF24_MASK_CRC 0x0C // Mask for CRC bits [3:2] in CONFIG register
#define NRF24_MASK_STATUS_IRQ 0x70 // Mask for all IRQ bits in STATUS register
#define NRF24_MASK_RF_PWR 0x06 // Mask RF_PWR[2:1] bits in RF_SETUP register
#define NRF24_MASK_RX_P_NO 0x0E // Mask RX_P_NO[3:1] bits in STATUS register
#define NRF24_MASK_DATARATE 0x28 // Mask RD_DR_[5,3] bits in RF_SETUP register
#define NRF24_MASK_EN_RX 0x3F // Mask ERX_P[5:0] bits in EN_RXADDR register
#define NRF24_MASK_RX_PW 0x3F // Mask [5:0] bits in RX_PW_Px register
#define NRF24_MASK_RETR_ARD 0xF0 // Mask for ARD[7:4] bits in SETUP_RETR register
#define NRF24_MASK_RETR_ARC 0x0F // Mask for ARC[3:0] bits in SETUP_RETR register
#define NRF24_MASK_RXFIFO 0x03 // Mask for RX FIFO status bits [1:0] in FIFO_STATUS register
#define NRF24_MASK_TXFIFO 0x30 // Mask for TX FIFO status bits [5:4] in FIFO_STATUS register
#define NRF24_MASK_PLOS_CNT 0xF0 // Mask for PLOS_CNT[7:4] bits in OBSERVE_TX register
#define NRF24_MASK_ARC_CNT 0x0F // Mask for ARC_CNT[3:0] bits in OBSERVE_TX register
#define NRF24_ADDR_WIDTH 5 // RX/TX address width
#define NRF24_PLOAD_WIDTH 32 // Payload width
#define NRF24_TEST_ADDR "nRF24"
typedef enum
NRF24_MODE_RX = 0x00,
NRF24_MODE_TX = 0x01,
NRF24_MODE_IT = 0x02
} NRF24_MODE;
const uint8_t TX_ADDRESS[NRF24_ADDR_WIDTH] = {0x32,0x4E,0x6F,0x64,0x65};
const uint8_t RX_ADDRESS[NRF24_ADDR_WIDTH] = {0x32,0x4E,0x6F,0x64,0x22};
const NRF24_MODE CURRENT_MODE = NRF24_MODE_IT;
uint8_t rx_buf[NRF24_PLOAD_WIDTH];
#define NRF_CSN P1_4
#define NRF_MOSI P1_5
#define NRF_MISO P1_6
#define NRF_SCK P1_7
#define NRF_IRQ P3_2
#define NRF_CE P3_7
uint8_t NRF24L01_Write_Reg(uint8_t reg,uint8_t value)
uint8_t status;
NRF_CSN = 0;
status = SPI_RW(reg);
SPI_RW(value);
NRF_CSN = 1;
return status;
uint8_t NRF24L01_Read_Reg(uint8_t reg)
uint8_t value;
NRF_CSN = 0;
SPI_RW(reg);
value = SPI_RW(NRF24_CMD_NOP);
NRF_CSN = 1;
return value;
uint8_t NRF24L01_Read_To_Buf(uint8_t reg, uint8_t *pBuf, uint8_t len)
uint8_t status, u8_ctr;
NRF_CSN = 0;
for (u8_ctr = 0; u8_ctr < len; u8_ctr++)
pBuf[u8_ctr] = SPI_RW(NRF24_CMD_NOP);
NRF_CSN = 1;
return status;
uint8_t NRF24L01_Write_From_Buf(uint8_t reg, const uint8_t *pBuf, uint8_t len)
NRF_CSN = 0;
SPI_RW(*pBuf++);
NRF_CSN = 1;
return status;
* Flush the RX FIFO
void NRF24L01_FlushRX(void)
NRF24L01_Write_Reg(NRF24_CMD_FLUSH_RX, NRF24_CMD_NOP);
* Flush the TX FIFO
void NRF24L01_FlushTX(void)
NRF24L01_Write_Reg(NRF24_CMD_FLUSH_TX, NRF24_CMD_NOP);
* Clear IRQ bit of the STATUS register
* reg - NRF24_FLAG_RX_DREADY
* NRF24_FLAG_TX_DSENT
* NRF24_FLAG_MAX_RT
void NRF24L01_ClearIRQFlag(uint8_t reg)
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_STATUS, reg);
* Clear RX_DR, TX_DS and MAX_RT bits of the STATUS register
void NRF24L01_ClearIRQFlags(void)
uint8_t reg;
reg = NRF24L01_Read_Reg(NRF24_REG_STATUS);
reg |= NRF24_MASK_STATUS_IRQ;
NRF24L01_Write_Reg(NRF24_REG_STATUS, reg);
uint8_t NRF24L01_RxPacket(uint8_t *rxbuf)
while(NRF_IRQ);
uint8_t state = NRF24L01_Read_Reg(NRF24_REG_STATUS);
printf_tiny("Interrupted, state: %x\r\n", state);
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_STATUS, state);
if (state & NRF24_FLAG_RX_DREADY)
NRF24L01_Read_To_Buf(NRF24_CMD_RX_PLOAD_R, rxbuf, NRF24_PLOAD_WIDTH);
NRF24L01_FlushRX();
return state;
uint8_t NRF24L01_TxPacket(uint8_t *txbuf)
uint8_t state;
NRF_CE = 0;
NRF24L01_Write_From_Buf(NRF24_CMD_TX_PLOAD_W, txbuf, NRF24_PLOAD_WIDTH);
NRF_CE = 1;
while (NRF_IRQ == 1);
if (state & NRF24_FLAG_MAX_RT)
NRF24L01_FlushTX();
NRF24L01_ClearIRQFlag(NRF24_FLAG_MAX_RT);
if (state & NRF24_FLAG_TX_DSENT)
NRF24L01_ClearIRQFlag(NRF24_FLAG_TX_DSENT);
return state;
uint8_t NRF24L01_Check(void)
uint8_t i;
uint8_t *ptr = (uint8_t *)NRF24_TEST_ADDR;
NRF24L01_Write_From_Buf(NRF24_CMD_REGISTER_W | NRF24_REG_TX_ADDR, ptr, NRF24_ADDR_WIDTH);
NRF24L01_Read_To_Buf(NRF24_CMD_REGISTER_R | NRF24_REG_TX_ADDR, rx_buf, NRF24_ADDR_WIDTH);
for (i = 0; i < NRF24_ADDR_WIDTH; i++) {
if (rx_buf[i] != *ptr++) return 1;
return 0;
void NRF24L01_init(NRF24_MODE mode)
NRF_CE = 0;
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_RX_PW_P0, NRF24_PLOAD_WIDTH);
NRF24L01_Write_From_Buf(NRF24_CMD_REGISTER_W + NRF24_REG_TX_ADDR, (uint8_t *)TX_ADDRESS, NRF24_ADDR_WIDTH);
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_EN_AA, 0x3f);
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_EN_RXADDR, 0x3f);
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_SETUP_RETR, 0x0a);
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_RF_CH, 40);
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_RF_SETUP, 0x07);
switch (mode)
case NRF24_MODE_RX:
case NRF24_MODE_IT:
NRF24L01_Write_From_Buf(NRF24_CMD_REGISTER_W + NRF24_REG_RX_ADDR_P0, (uint8_t *)RX_ADDRESS, NRF24_ADDR_WIDTH);
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_CONFIG, 0x0F);
break;
case NRF24_MODE_TX:
default:
NRF24L01_Write_From_Buf(NRF24_CMD_REGISTER_W + NRF24_REG_RX_ADDR_P0, (uint8_t *)TX_ADDRESS, NRF24_ADDR_WIDTH);
NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_CONFIG, 0x0E);
break;
NRF_CE = 1;
void NRF24L01_printBuf(void)
for (uint8_t i = 0; i < NRF24_PLOAD_WIDTH; i++)
printf_tiny("%x ", rx_buf[i]);
printf_tiny("\r\n");
void NRF24L01_irqHandler(void) __interrupt IE0_VECTOR
NRF24L01_Read_To_Buf(NRF24_CMD_RX_PLOAD_R, rx_buf, NRF24_PLOAD_WIDTH);
NRF24L01_FlushRX();
NRF24L01_printBuf();
void EXTI_init(void)
EXTI_configTypeDef ec;
ec.mode = EXTI_mode_lowLevel;
ec.priority = IntPriority_High;
EXTI_config(PERIPH_EXTI_0, &ec);
EXTI_cmd(PERIPH_EXTI_0, ENABLE);
UTIL_setInterrupts(ENABLE);
void SPI_init(void)
SPI_configTypeDef sc;
sc.baudRatePrescaler = SPI_BaudRatePrescaler_4;
sc.cpha = SPI_CPHA_1Edge;
sc.cpol = SPI_CPOL_low;
sc.firstBit = SPI_FirstBit_MSB;
sc.pinmap = SPI_pinmap_P1;
sc.nss = SPI_NSS_Soft;
sc.mode = SPI_Mode_Master;
SPI_config(&sc);
SPI_cmd(ENABLE);
void main(void)
UTIL_enablePrintf();
SPI_init();
while (NRF24L01_Check())
printf_tiny("Check failed, waiting retry\r\n");
sleep(500);
NRF24L01_init(CURRENT_MODE);
if (CURRENT_MODE == NRF24_MODE_RX)
while (true)
uint8_t sta = NRF24L01_RxPacket(rx_buf);
printf_tiny("RX stat: %x\r\n", sta);
else if (CURRENT_MODE == NRF24_MODE_IT)
EXTI_init();
while(true);
uint8_t tmp[] = {
0x1F, 0x80, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18,
0x21, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x28,
0x31, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x38,
0x41, 0x12, 0x13, 0x14, 0x15, 0x16, 0x37, 0x48};
while (true)
uint8_t sta = NRF24L01_TxPacket(tmp);
tmp[1] = sta;
printf_tiny("TX stat: %x\r\n", sta);
sleep(500);
