標題: 電賽快來了給大家來個去年的小車STM32版 [打印本頁]
作者: garrettzls    時間: 2021-8-1 21:48
本帖最后由 garrettzls 于 2021-8-2 09:28 編輯
大家來交流一下電賽啊
PN編碼器旋鈕:
    SW -> PA10
    DT -> PA11
    CLK -> PA12
編碼電機:
左輪:
    IN1 -> PB10
    IN2 -> PB8 TIM4_CH3
    A -> PA2
    B ->
右輪:
    IN3 -> PB11
    IN4 -> PB9 TIM3_CH4
    A -> PA3
    B ->
OLED:
    CS -> PA6
    DC -> PA7
    RES -> PA5
    D1 -> PB0
    D0 -> PB1
    VCC ->
    GND ->
舵機:
    IN -> PA0
紅外傳感器:
    IN1 -> PA4
    IN2 -> PA5
    IN3 -> PA6
    IN4 -> PA7
板載LED:
    LED -> PB12
  1. /* Includes ------------------------------------------------------------------*/
  2. #include "stm32f10x.h"
  3. #include "infrared_sensor.h"
  4. #include "encode_motor.h"
  5. #include "steering_motor.h"
  6. #include "bluetooth.h"
  7. #include "usart.h"
  8. #include "PID.h"
  9. #include "timer.h"
  10. #include "delay.h"
  11. #include "oled.h"
  12. #include "led.h"
  13. #include <string.h>
  14. #include "encodeing.h"
  15. //OLED刷新顯示
  16. void OLED_update()
  17. {
  18.         OLED_ShowString(0,0,(u8 *)"V1:    V2:    ",16);
  19.         OLED_ShowString(0,16,(u8 *)"PIDOUT:   ",16);
  20.         OLED_ShowString(0,32,(u8 *)"TIME:   Spd:   ",16);
  21.
  22.         if(run_flag == 1)
  23.                 OLED_ShowString(0,48,(u8 *)"RUNING...   ",16);
  24.         else
  25.                 OLED_ShowString(0,48,(u8 *)"STOP...     ",16);
  26.
  27.
  28.         OLED_ShowNum(26,0,(int)V_left,4,12);
  29.         OLED_ShowNum(82,0,(int)V_right,4,12);
  30.
  31.         OLED_ShowNum(58,16,(int)PID_OUT,4,12);
  32.         OLED_ShowNum(42,32,(int)time,2,12);
  33.         OLED_ShowNum(94,32,(int)speed,3,12);
  34.         OLED_Refresh_Gram();//更新顯示
  35. }
  36. //設(shè)置小車前進的固定速度
  37. void set_PID_speed(int v1,int v2)
  38. {
  39.         Set_Temp = v1;
  40.         Set_Temp1 = v2;
  41. }
  42. //主函數(shù)
  43. int main(void)
  44. {
  45.         u8 state;
  46.         int ang;
  47.
  48.
  49.         //設(shè)置APP偏移
  50.         //SCB->VTOR = FLASH_BASE | 0x8000; /* Vector Table Relocation in Internal FLASH. */
  51.
  52.     uart_init(9600);//藍牙串口初始化
  53.         delay_init(); //延時初始化
  54.         SteerinMotor_Init(); //舵機初始化
  55.         EncodeMotor_Init();//編碼電機初始化
  56.         OLED_Init();//oled初始化
  57.         LED_Init();//led初始化
  58.         TIM1_Int_Init(100,7200);//定時器初始化10ms
  59.         Encodeing_Init();//旋鈕編碼器初始化
  60.         //測試
  61.     printf(" this is Ramp patorl trolley  by HUAZUOCHEN! ^_^ \r\n");
  62.     while (1) {
  63.                 OLED_update();//更新OLED顯示
  64.                 encodeing_scan();//編碼器掃描
  65.                 //獲取紅外線傳感器傳回的數(shù)據(jù)
  66.                 state = Get_Infrared_Sensor();
  67.                 ang = 0;
  68.                 switch (state)//循跡轉(zhuǎn)彎設(shè)置
  69.                 {
  70.                         case 0x00:ang = 0;
  71.                                 break;
  72.                         case 0x01:ang = -55;
  73.                                 break;
  74.                         case 0x03:ang = -35;
  75.                                 break;
  76.                         case 0x02:ang = -10;
  77.                                 break;
  78.                         case 0x06:set_steerMotor_ang(0);//設(shè)置舵機角度 0
  79.                                 break;
  80.                         case 0x04:ang = 10;
  81.                                 break;
  82.                         case 0x0c:ang = 35;
  83.                                 break;
  84.                         case 0x08:ang = 55;
  85.                                 break;
  86.                         case 0x0f:  //識別到雜亂信號角度設(shè)置為0
  87.                         case 0x09:
  88.                         case 0x05:
  89.                         case 0x0a:
  90.                         case 0x0e:
  91.                         case 0x0b:
  92.                                         run_flag = 0;//停止
  93.                                 break;
  94.                         default:ang = 0;
  95.                                 break;
  96.                 }
  97.                 if(ang != 0)
  98.                 {
  99.                         set_steerMotor_ang(ang);//設(shè)置舵機角度
  100.                         delay_ms(100);
  101.                 }
  102.                 state = 0;
  103.     }
  104. }
以上代碼51hei附件下載:
32坡道小車代碼.7z (219.21 KB, 下載次數(shù): 22)
原理圖自取資源來自網(wǎng)絡(luò)侵刪
作者: 51hei團團    時間: 2021-8-1 22:55
紅外+舵機 能分享下原理圖嗎?
作者: garrettzls    時間: 2021-8-2 09:29
51hei團團 發(fā)表于 2021-8-1 22:55
紅外+舵機 能分享下原理圖嗎?
自取zsbd
