標題: 51單片機+DHT111數碼管顯示出錯 [打印本頁]
作者: 1dddd    時間: 2021-7-24 20:32
首先感謝進來看的朋友,表示感謝。請問我這個DHT11數碼管顯示,為什么數碼管只顯示最后一位?
主函數:
#include<reg52.h>
#include"dht11.h"
#include"delay.h"
#include"uart.h"
sbit B1 = P2^2;
sbit B2 = P2^1;
sbit B3 = P2^0;
unsigned char tempH,tempL,humiH,humiL;
unsigned char Temp_Humi[4];
unsigned char code Temp_Table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void Show_temp(void)
        uint i=0;
        Temp_Humi[0] = tempH/10;
        Temp_Humi[1] = tempH%10;
        Temp_Humi[2] = humiH/10;
        Temp_Humi[3] = humiH%10;
        for(i=0;i<4;i++)
                switch(i)
                        case (0) : B1 = 0 ;B2 = 0 ;B3 = 0 ; break;
                        case (1) : B1 = 0 ;B2 = 0 ;B3 = 1 ; break;
                        case (2) : B1 = 0 ;B2 = 1 ;B3 = 0 ; break;
                        case (3) : B1 = 0 ;B2 = 1 ;B3 = 1 ; break;
                P0 =  Temp_Table[Temp_Humi[i]];
                Delay40us();
int main(void)
        Timer0Init();
        UartInit();
        Dht11_Star();
        if(Dht11_Check()<0)
                printf("error! \r\n");
                printf("ok!  \r\n");
                Dht11_Read_Dat(&tempL,&tempH,&humiH,&humiL);
                Delay4ms();
                Show_temp();
                printf("temp: %bu%bu  humi: %bu%bu\r\n",Temp_Humi[0],Temp_Humi[1],Temp_Humi[2],Temp_Humi[3]);
DHT11時序讀取
#include<intrins.h>
#include"dht11.h"
#include"delay.h"
void Dht11_Star(void)
        DATE = 0;
        Delay20ms();
        DATE = 1;
        Delay30us();
char Dht11_Check(void)
        uint t = 0;
        while(DATE)
                t++;
                _nop_();
                if(t>4000)
                        return -1;
        t=0;
        while(!DATE)
                t++;
                _nop_();
                if(t>100)
                        return -2;
                t=0;
        while(DATE)
                t++;
                _nop_();
                if(t>100)
                        return -3;
        return 0;
uchar Dht11_Read(void)
        uint i,t=0;
        uchar temp=0;
        for(i=0;i<8;i++)
                while(!DATE)
                        t++;
                        _nop_();
                        if(t>60)
                                return -1;
                Delay40us();
                temp <<= 1;
                if(DATE)
                        temp |= 1;
                        t=0;
                        while(DATE)
                                t++;
                                _nop_();
                                if(t>80)
                                        return -1;
        return temp;
short Dht11_Read_Dat(char *tempL,char *tempH,char *humiH,char *humiL)
        uchar i;
        uchar buff[5];
        Dht11_Star();
        if(Dht11_Check() == 0)
                for(i=0;i<5;i++)
                        buff[i]= Dht11_Read();
                Delay40us();
                if((buff[0]+buff[1]+buff[2]+buff[3]) == buff[4])
                        *humiH=buff[0];
                        *humiL=buff[1];
                        *tempH=buff[2];
                        *tempL=buff[3];
                        return 0;
                        return -1;
                return -2;
作者: wangshangxing    時間: 2021-7-25 01:54
把show-temp函數里delay延時改成4ms試試
作者: 1dddd    時間: 2021-7-25 14:38
wangshangxing 發表于 2021-7-25 01:54
謝謝 解決了
作者: 943224765    時間: 2021-9-9 20:45
怎么可以用dht11檢查溫度 當溫度大于三十攝氏度 濕度大于60%時亮警燈阿
