基于STC89C51單片機(jī)的光強(qiáng)檢測(cè)程序
[打印本頁(yè)]
LHY_lhy
時(shí)間:
2021-7-20 09:56
最近學(xué)習(xí)了AD 覺(jué)得光敏檢測(cè)很有意思
于是就根據(jù)光敏檢測(cè)的值點(diǎn)個(gè)燈吧
使用的普中51 A2開(kāi)發(fā)板
原理圖在附件
源代碼 如下
#include <reg52.h>
#define XPT2046_VBAT 0xAC
unsigned int ADvalue;
unsigned int led_num=0;
sbit XPT2046_CS=P3^5;
sbit XPT2046_DCLK=P3^6;
sbit XPT2046_DIN=P3^4;
sbit XPT2046_DOUT=P3^7;
void Delay(unsigned int xms)
unsigned char i, j;
while(xms--)
i = 2;
j = 239;
do
while (--j);
} while (--i);
unsigned int XPT2046_ReadAD(unsigned char Command)
unsigned int ADValue=0;
unsigned char i;
XPT2046_DCLK=0;
XPT2046_CS=0;
for(i=0;i<8;i++)
XPT2046_DIN=Command&(0x80>>i);
XPT2046_DCLK=1;
XPT2046_DCLK=0;
for(i=0;i<16;i++)
XPT2046_DCLK=1;
XPT2046_DCLK=0;
if(XPT2046_DOUT)
ADValue|=(0x8000>>i);
XPT2046_CS=1;
return ADValue>>8;
void led_light()
switch(led_num)
case 1:P2=0xfe;break;
case 2:P2=0xfc;break;
case 3:P2=0xf8;break;
case 4:P2=0xf0;break;
case 5:P2=0xe0;break;
case 6:P2=0xc0;break;
case 7:P2=0x80;break;
case 8:P2=0x00;break;
void pd()
if(ADvalue>0&&ADvalue<=10)
led_num=1;
else if(ADvalue>10&&ADvalue<=18)
led_num=2;
else if(ADvalue>18&&ADvalue<=26)
led_num=3;
else if(ADvalue>26&&ADvalue<=34)
led_num=4;
else if(ADvalue>34&&ADvalue<=42)
led_num=5;
else if(ADvalue>42&&ADvalue<=50)
led_num=6;
else if(ADvalue>50&&ADvalue<=52)
led_num=7;
else if(ADvalue>52)
led_num=8;
ADvalue=XPT2046_ReadAD(XPT2046_VBAT);
Delay(5);
pd();
led_light();
Keil代碼工程51hei附件下載:
光強(qiáng)燈.zip
(20.84 KB, 下載次數(shù): 27)
2021-7-20 09:55 上傳
點(diǎn)擊文件名下載附件
A2開(kāi)發(fā)板原理圖(1).pdf
(227.86 KB, 下載次數(shù): 18)
2021-7-20 09:55 上傳
點(diǎn)擊文件名下載附件
