HC32F460的IAP例程與資料
pp8899
2021-6-23 18:25
HC32F460的IAP例程與資料
這是華大的HC32F460的IAP例程,供大家參考。
(8.04 KB, 下載次數: 116)
2021-6-23 19:11 上傳
以上資料下載:
hc32f460_iap資料.7z
(3.11 MB, 下載次數: 215)
2021-6-23 19:14 上傳
* Include files
#include "iap.h"
#include "basic.h"
#include "flash.h"
#include "uart.h"
#include "modem.h"
#include "User_Timer.h"
* Local type definitions ('typedef')
* Local pre-processor symbols/macros ('#define')
* Global variable definitions (declared in header file with 'extern')
uint32_t JumpAddress;
func_ptr_t JumpToApplication;
* Local function prototypes ('static')
static en_result_t IAP_JumpToApp(uint32_t u32Addr);
static void IAP_ResetConfig(void);
* Local variable definitions ('static')
* Function implementation - global ('extern') and local ('static')
** \brief Initialize IAP
** \param [in] None
** \retval None
void IAP_Init(void)
SystemClock_Init();
LED_Init();
UART_Init();
** \brief UART receive byte.
** \param [out] u8RxData Pointer to Rx data.
** \retval Ok Receive data finished.
** \retval Error Don't receive data.
void IAP_Main(void)
uint32_t u32AppFlag;
en_result_t enRet;
while (1)
enRet = Modem_Process(BOOT_WAIT_TIME);
if ((enRet == Ok) || (enRet == ErrorTimeout))
u32AppFlag = *(__IO uint32_t *)BOOT_PARA_ADDRESS;
if ((0xFFFF != u32AppFlag))
if (Error == IAP_JumpToApp(APP_ADDRESS))
LED0_OFF();
LED1_ON();
LED0_ON();
LED1_ON();
LED1_OFF();
LED0_ON();
** \brief IAP main function
** \param [in] u32Addr APP address
** \retval Error APP address error
uint32_t u32StackTop = *((__IO uint32_t *)u32Addr);
/* Check if user code is programmed starting from address "u32Addr" */
/* Check stack top pointer. */
if ((u32StackTop > SRAM_BASE) && (u32StackTop <= (SRAM_BASE + RAM_SIZE)))
IAP_ResetConfig();
/* Jump to user application */
JumpAddress = *(__IO uint32_t *)(u32Addr + 4);
JumpToApplication = (func_ptr_t)JumpAddress;
/* Initialize user application's Stack Pointer */
__set_MSP(*(__IO uint32_t *)u32Addr);
JumpToApplication();
return Error;
** \brief Boot reset configure
** \param [in] None
** \retval None
LED_DeInit();
UART_DeInit();
Timer_DeInit();
SystemClock_DeInit();
* EOF (not truncated)
yutouyes
2021-9-2 16:49
好資料,51黑有你更精彩!!!
cliff_w
2022-3-31 16:28
感謝感謝,找了很久終于找到了
150315175
2022-4-26 09:53
這個資料在哪里找的啊?我去官網都沒找到
mmloster001
2023-3-13 22:01
感謝,,,,馬上下載來研究研究
