Proteus仿真 具有開始、暫停、清零功能秒表相關(guān)
田所浩二單推人
時(shí)間:
2021-6-17 10:47
仿真圖如下 代碼如下
#include <reg52.h>
#define T0HIGH 0xec
#define T0LOWW 0x8a
typedef unsigned char u8;
typedef unsigned int u16;
typedef unsigned long u32;
typedef bit BOOL;
sbit KEY_PIN = P3^3;
#define true 1
#define false 0
#define KEY_NULL 0
#define KEY_DOWN 0x80
#define KEY_LONG 0x40
#define KEY_UP 0x20
#define KEY_STATE_INIT 0
#define KEY_STATE_WOBBLE 1
#define KEY_STATE_PRESS 2
#define KEY_STATE_LONG 3
#define KEY_STATE_RELEASE 4
#define COUNT_INIT 0
#define COUNT_START 1
#define COUNT_STOP 2
code u8 DisCode[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0xff};
u8 CouNum[4] = {0x00, 0x00, 0x00, 0x00};
u8 DisNum[4] = {0x0a, 0x0a, 0x00, 0x00};
u8 DisPosition = 0;
u8 SecCount = 0;
BOOL b10msEvent = false;
BOOL b100msEvent = false;
BOOL CountStart = false;
void Key_Prosess(void);
void Counter(void);
main()
TMOD = 0x01;
TH0 = T0HIGH;
TL0 = T0LOWW;
TR0 = 1;
ET0 = 1;
EA = 1;
P1 = 0x00;
Key_Prosess(); //按鍵掃描
if(b10msEvent == true)
b10msEvent = false;
LCD_Display(); //動(dòng)態(tài)顯示
if(b100msEvent == true)
if(CountStart == true)
Counter(); //計(jì)時(shí)
void Num_Clear(void)
u8 i;
for(i=0; i<4; i++)
CouNum = 0;
DisNum[0] = DisNum[1] = 0x0a;
DisNum[2] = DisNum[3] = 0x00;
u8 Key_Scan(void)
if(KEY_PIN == false)
return (1);
return KEY_NULL;
u8 GetKey(void)
static u8 KeyState = KEY_STATE_INIT;
static u8 KeyTimeCount = 0;
static u8 LastKey = KEY_NULL; //保存按鍵釋放時(shí)候的鍵值
u8 KeyTemp = KEY_NULL ;
KeyTemp = Key_Scan();
switch(KeyState)
case KEY_STATE_INIT: //初始狀態(tài)
if(KEY_NULL != KeyTemp) //有鍵按下
KeyState = KEY_STATE_WOBBLE; //進(jìn)入消抖
break;
case KEY_STATE_WOBBLE: //消抖
KeyState = KEY_STATE_PRESS;
break;
case KEY_STATE_PRESS:
LastKey = KeyTemp; //保存鍵值,以便在釋放按鍵狀態(tài)返回鍵值
KeyTemp |= KEY_DOWN; //按鍵按下
KeyState = KEY_STATE_LONG;
break;
case KEY_STATE_LONG:
if(++KeyTimeCount >= 100)
KeyTimeCount = 0;
LastKey |= KEY_LONG;
KeyState = KEY_STATE_RELEASE;
break;
case KEY_STATE_RELEASE:
LastKey |= KEY_UP; //按鍵釋放
KeyTemp = LastKey;
break;
default:
break;
return KeyTemp;
u8 KeyData;
static u8 CountState = COUNT_INIT;
KeyData = GetKey();
if(KeyData == 0x81)
switch(CountState)
case COUNT_INIT: //開始計(jì)時(shí)
SecCount = 0;
TH0 = T0HIGH;
TL0 = T0LOWW;
CountStart = true;
CountState = COUNT_START;
break;
case COUNT_START: //停止計(jì)時(shí)
CountStart = false;
CountState = COUNT_STOP;
break;
case COUNT_STOP: //清零
Num_Clear();
break;
default:
break;
void Counter(void)
u8 i;
if(++CouNum[3] == 10) //0.1秒
CouNum[3] = 0;
CouNum[2] += 1;
if(CouNum[2] == 10) //1秒
CouNum[2] = 0;
CouNum[1] += 1;
if(CouNum[1] == 10) //10秒
CouNum[1] = 0;
CouNum[0] += 1;
if(CouNum[0] == 10) //100秒
CouNum[0] = 0;
for(i=0; i<2; i++)
if(CouNum != 0)
break;
for(; i<4; i++)
DisNum = CouNum;
void LCD_Display(void)
static u8 DisPinOn = 0x01;
DisPinOn <<= 1;
if(DisPinOn == 0x10)
DisPosition = 0;
DisPinOn = 0x01;
P0 = 0xff;
P1 = DisPinOn;
P0 = DisCode[DisNum[DisPosition++]];
if(DisPinOn == 0x04)
P0 &= 0x7f;
void timer0(void) interrupt 1
TH0 = T0HIGH;
TL0 = T0LOWW;
b10msEvent = true;
if(++SecCount == 10)
SecCount = 0;
b100msEvent = true;
keil報(bào)錯(cuò)如下
1.c(63): error C213: left side of asn-op not an lvalue
1.c(160): error C187: not an lvalue
1.c(188): error C231: 'LCD_Display': redefinition
1.c(201): error C231: 'LCD_Display': redefinition
(97.63 KB, 下載次數(shù): 66)
2021-6-17 10:45 上傳
