標題: stm32使用dac生產三角波、正旋、方波(頻率、幅度可調)iar工程 源程序 [打印本頁]
作者: 高鑫鵬    時間: 2021-6-11 09:29
void DAC02_Mode_sin(void)
    uint32_t Idx = 0;
    DAC_sin02_init();
    sin02.sin_frequency=char_change_num(Command01.command_number5,4);
    sin02.sin_range=char_change_num(Command01.command_number6,4);
    if(sin02.sin_frequency>5000)
        sin02.sin_frequency=5000;
    if( sin02.sin_range>3300)
        sin02.sin_range=3300;
    if(sin02.sin_frequency>1000)
        sin_frequency=50000/sin02.sin_frequency;
        sin02.point_num=point_num_sin2;
        DAC02_sin_Config();
        DAC02_TIM_Config();
        TIM3_NVIC_Config();
        for (Idx = 0; Idx < point_num_sin2; Idx++)
            DualSine02bit[Idx]=(Sine12bit[Idx*(1000/point_num_sin2)])*(sin02.sin_range/100)/33;
        sin_frequency=10000/sin02.sin_frequency;
        sin02.point_num=point_num_sin;
        DAC02_sin_Config();
        DAC02_TIM_Config();
        TIM3_NVIC_Config();
        for (Idx = 0; Idx < point_num_sin; Idx++)
            DualSine02bit[Idx]=(Sine12bit[Idx*(1000/point_num_sin)])*(sin02.sin_range/100)/33;
    sin02.sin_runflag=1;
IAP_APP.7z
928.83 KB, 下載次數: 58, 下載積分: 黑幣 -5
作者: maijinzhi    時間: 2021-6-12 11:14
不錯,可以參考下,謝謝
