標題: LCD12864任意位置顯示文字 基于STM32F103C8T6單片機程序 [打印本頁]
作者: _Johke_    時間: 2021-5-16 00:00
LCD12864大液晶任意位置顯示文字
  1. #include "LCD12864.h"
  2. #include "U_Font.h"
  3. uint8_t         LCD12864_GRAM[1024]; /* LCD12864 顯存 */
  4. /*=======================================================================================*/
  5. void LCD12864_Init(void)
  6. {
  7.         LCD12864_GPIO_Config();
  8.         LCD12864_Write_CMD(0x30);  //選擇基本指令操作
  9.         LCD12864_Write_CMD(0x0c);  //顯示開,關光標
  10.         LCD12864_Write_CMD(0x01);  //清除LCD12864的顯示內容
  11. }
  12. void LCD12864_GPIO_Config(void)
  13. {
  14.         GPIO_InitTypeDef                 h_GPIO_LCD12864;
  15.
  16.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE);
  17.
  18.         h_GPIO_LCD12864.GPIO_Mode = GPIO_Mode_Out_PP;
  19.
  20.         h_GPIO_LCD12864.GPIO_Pin =         LCD12864_RS_Pin|
  21.        LCD12864_RW_Pin|
  22.        LCD12864_EN_Pin;
  23.
  24.         h_GPIO_LCD12864.GPIO_Speed = GPIO_Speed_50MHz;
  25.
  26.         GPIO_Init(LCD12864_CMD_Port,&h_GPIO_LCD12864);
  27. }
  28. void LCD12864_DAT_Port_Switch_InPut(void) /*LCD12864 Dat Port 切換為輸入*/
  29. {
  30.         GPIO_InitTypeDef                                         h_GPIO_LCD12864;
  31.
  32.         h_GPIO_LCD12864.GPIO_Mode = GPIO_Mode_IPU;
  33.
  34.         h_GPIO_LCD12864.GPIO_Pin =         GPIO_Pin_0|
  35.        GPIO_Pin_1|
  36.        GPIO_Pin_2|
  37.        GPIO_Pin_3|
  38.        GPIO_Pin_4|
  39.        GPIO_Pin_5|
  40.        GPIO_Pin_6|
  41.        GPIO_Pin_7;
  42.
  43.         GPIO_Init(LCD12864_DAT_Port,&h_GPIO_LCD12864);
  44. }
  45. void LCD12864_DAT_Port_Switch_OutPut(void) /*LCD12864 Dat Port 切換為輸出*/
  46. {
  47.         GPIO_InitTypeDef                                         h_GPIO_LCD12864;
  48.
  49.         h_GPIO_LCD12864.GPIO_Mode = GPIO_Mode_Out_PP;
  50.
  51.         h_GPIO_LCD12864.GPIO_Pin =         GPIO_Pin_0|
  52.        GPIO_Pin_1|
  53.        GPIO_Pin_2|
  54.        GPIO_Pin_3|
  55.        GPIO_Pin_4|
  56.        GPIO_Pin_5|
  57.        GPIO_Pin_6|
  58.        GPIO_Pin_7;
  59.
  60.         h_GPIO_LCD12864.GPIO_Speed = GPIO_Speed_50MHz;
  61.
  62.         GPIO_Init(LCD12864_DAT_Port,&h_GPIO_LCD12864);
  63. }
  64. uint8_t LCD12864_Check_Busy(void)
  65. {
  66.         uint8_t outTime;
  67.
  68.         LCD12864_RS_Low();
  69.         LCD12864_RW_High();
  70.         LCD12864_EN_High();
  71.
  72.         LCD12864_DAT_Port_Switch_InPut();
  73.
  74.         while((GPIO_ReadInputData(LCD12864_DAT_Port) & 0x80) == 0x80)
  75.         {
  76.                 outTime++;
  77.                 if(outTime > 100)
  78.                 {
  79.                         LCD12864_EN_Low();
  80.                         return 1;
  81.                 }
  82.         }
  83.         LCD12864_EN_Low();
  84.         return 0;
  85. }
  86. void LCD12864_Write_CMD(uint8_t cmd)
  87. {
  88.         while(LCD12864_Check_Busy());
  89.
  90.         LCD12864_RS_Low();
  91.         LCD12864_RW_Low();
  92.         LCD12864_EN_Low();
  93.
  94.         LCD12864_DAT_Port_Switch_OutPut();
  95.
  96.         GPIO_Write(LCD12864_DAT_Port,(uint16_t)cmd);
  97.
  98.         LCD12864_EN_High();
  99.
  100.         LCD12864_EN_Low();
  101.
  102. }
  103. void LCD12864_Write_DAT(uint8_t dat)
  104. {
  105.         while(LCD12864_Check_Busy());
  106.
  107.         LCD12864_RS_High();
  108.
  109.         LCD12864_RW_Low();
  110.
  111.         LCD12864_EN_Low();
  112.
  113.         LCD12864_DAT_Port_Switch_OutPut();
  114.
  115.         GPIO_Write(LCD12864_DAT_Port,(uint16_t)dat);
  116.
  117.         LCD12864_EN_High();
  118.
  119.         LCD12864_EN_Low();
  120. }
  121. /*=======================================================================================*/
  122. void LCD12864_GRAM_SetPoint /* 畫點在LCD12864_GRAM里 */
  123. (
  124.         uint8_t x,        /* 點的坐標X 0~127 */
  125.         uint8_t y,        /* 點的坐標Y 0~63  */
  126.         uint8_t color                                            /* 點的顏色 0 or 1 */
  127. )
  128. {
  129.         if( x > 127 )                return;
  130.         if( y > 63 )                return;
  131.         if(color == 1)
  132.         {
  133.                         LCD12864_GRAM[y*16+(x/8)] |= 0x80 >> (x % 8);
  134.         }
  135.         else
  136.         {
  137.                 LCD12864_GRAM[y*16+(x/8)] &= ~(0x80 >> (x % 8));
  138.         }
  139. }
  140. void LCD12864_GRAM_Refresh(void) /* 用LCD12864_GRAM里的數據刷新LCD12864*/
  141. {
  142.         uint16_t i,ii,count,count2;
  143.
  144.         count = 0;
  145.         count2 = 0;
  146.
  147.         LCD12864_Write_CMD(0x34);
  148.
  149.         for(ii=0;ii<32;ii++)
  150.         {
  151.                 LCD12864_Write_CMD(0x80+ii);
  152.                 LCD12864_Write_CMD(0x80);
  153.
  154.                 for(i=0;i<8;i++)
  155.                 {
  156.                         LCD12864_Write_DAT(LCD12864_GRAM[count]);
  157.                         LCD12864_Write_DAT(LCD12864_GRAM[count+1]);
  158.                         count+=2;
  159.                 }
  160.                 for(i=8;i<16;i++)
  161.                 {
  162.                         LCD12864_Write_DAT(LCD12864_GRAM[count2+512]);
  163.                         LCD12864_Write_DAT(LCD12864_GRAM[count2+1+512]);
  164.                         count2+=2;
  165.                 }
  166.         }
  167.
  168.         LCD12864_Write_CMD(0x36);
  169.         LCD12864_Write_CMD(0x30);
  170. }
  171. void LCD12864_Clear /* LCD12864清屏 */
  172. (
  173.         uint8_t state     /* LCD12864清屏的狀態 0x00 ~ 0xFF */
  174. )
  175. {
  176.         uint16_t i;
  177.
  178.         for(i=0;i<1024;i++)
  179.         {
  180.                 LCD12864_GRAM[i] = state;
  181.         }
  182.         LCD12864_GRAM_Refresh();
  183. }
  184. void LCD12864_Show8X16_Char         /* 顯示8*16像素大小的字符串 */
  185. (
  186.         uint8_t x,
  187.         uint8_t y,
  188.         uint8_t chr
  189. )
  190. {
  191.         uint8_t i,ii;
  192.         uint8_t xx,yy;
  193.         uint8_t chrr;
  194.
  195.         chrr = chr - 32;
  196.         xx = x;
  197.         yy = y;
  198.
  199.         for(i=0;i<16;i++)
  200.         {
  201.                 for(ii=0;ii<8;ii++)
  202.                 {
  203.                         if( ( ( ASCII_8X16[chrr * 16 + i] >> ii ) & 0x01 ) == 1 )
  204.                         {
  205.                                 LCD12864_GRAM_SetPoint(xx+ii,yy+i,1);
  206.                         }
  207.                         else
  208.                         {
  209.                                 LCD12864_GRAM_SetPoint(xx+ii,yy+i,0);
  210.                         }
  211.                 }
  212.         }
  213. }
  214. void LCD12864_GRAM_Show6X8_Char                /* 顯示6*8像素大小的字符串 */
  215. (
  216.         uint8_t x,
  217.         uint8_t y,
  218.         uint8_t chr
  219. )
  220. {
  221.         uint8_t i,ii;
  222.
  223.         chr -= 32;
  224.
  225.         for(i=0;i<6;i++)
  226.         {
  227.                 for(ii=0;ii<8;ii++)
  228.                 {
  229.                         if( ( ( ASCII_6X6[chr*6+i] >> ii ) & 0x01 ) == 1)
  230.                         {
  231.                                 LCD12864_GRAM_SetPoint(x+i,y+ii,1);
  232.                         }
  233.                         else
  234.                         {
  235.                                 LCD12864_GRAM_SetPoint(x+i,y+ii,0);
  236.                         }
  237.                 }
  238.         }
  239. }
  240. void LCD12864_Show8X16_Str         /* 顯示單個字符像素為8*16的字符串 自帶刷新LCD12864*/
  241. (
  242.         uint8_t x,        /* 字符左上角起始坐標X */
  243.         uint8_t y,        /* 字符左上角起始坐標Y */
  244.         uint8_t *str        /* 要顯示的字符串      */
  245. )
  246. {
  247.         while(*str != '\0')
  248.         {
  249.                 LCD12864_Show8X16_Char(x,y,*str);
  250.                 x += 8;
  251.                 str++;
  252.         }
  253.         LCD12864_GRAM_Refresh();
  254. }
  255. void LCD12864_Show6X8_Str                /* 顯示單個字符像素為6*8的字符串 自帶刷新LCD12864*/
  256. (
  257.         uint8_t x,        /* 字符左上角起始坐標X */
  258.         uint8_t y,        /* 字符左上角起始坐標Y */
  259.         uint8_t *str        /* 要顯示的字符串      */
  260. )
  261. {
  262.         while(*str != '\0')
  263.         {
  264.                 LCD12864_GRAM_Show6X8_Char(x,y,*str);
  265.                 x += 6;
  266.                 str++;
  267.         }
  268.         LCD12864_GRAM_Refresh();
  269. }
  270. /*=======================================================================================*/
全部資料51hei下載地址:
代碼資料.7z (1.11 MB, 下載次數: 82)
作者: Max_zhang    時間: 2021-5-16 01:06
這種帖子居然能給50分?請問GPIOwrite();在哪里?關鍵部分不給出來。
