藍(lán)牙小車循跡
[打印本頁(yè)]
ccccccccx
時(shí)間:
2021-4-26 21:54
藍(lán)牙小車循跡
#include<reg52.h>
typedef unsigned char u8; //宏定義無(wú)符號(hào)字符型 8位
typedef unsigned int u16; //宏定義無(wú)符號(hào)整形 16位
sbit PWM1 = P2^6; //左電機(jī)高電平
sbit PWM2 = P2^5; //右電機(jī)高電平
sbit IN1 = P2^4;
sbit IN2 = P2^3; //左電機(jī)
sbit IN3 = P2^2;
sbit IN4 = P2^1; //右電機(jī)
sbit S1 = P1^1; //左紅外避障模塊
sbit S2 = P1^2; //右紅外避障模塊
sbit S3 = P1^3; //左紅外尋跡模塊
sbit S4 = P1^4; //右紅外尋跡模塊
sbit K1 = P3^2; //功能轉(zhuǎn)換按鍵
u8 connt; //調(diào)速周期
u8 PWM_NO; //高電平時(shí)間
u8 COM = 0; //功能控制位
u8 t=0; //判斷串口中斷是否執(zhí)行
void time(void) //定時(shí)計(jì)時(shí)器初始化函數(shù)
TMOD = 0x01; //中斷方式1
TH0 = 0xfe;
TL0 = 0x0c; //0.5ms
EA = 1; //打開總中斷
ET0 = 1; //打開計(jì)時(shí)器中斷
TR0 = 1; //啟動(dòng)計(jì)時(shí)器
void InitUART(void) //串口中斷初始化函數(shù)
SCON=0x50; //設(shè)置為工作方式1
TMOD=0x20; //設(shè)置計(jì)數(shù)器工作方式2
PCON=0x00; //波特率加倍
TH1=0xfd; //計(jì)數(shù)器初始值設(shè)置,注意波特率是9600的
TL1=0xfd;
ES=1; //打開接收中斷
EA=1; //打開總中斷
TR1=1; //打開計(jì)數(shù)器
void delay( u16 k ) //延時(shí)大約1ms
u16 i,j;
for(i=k;i>0;i--)
for(j=120;j>0;j--);
void SC() //剎車
IN1 = 0;
IN2 = 0;
IN3 = 0;
IN4 = 0;
void QJ() //前進(jìn)
IN1 = 1;
IN2 = 0;
IN3 = 1;
IN4 = 0;
void HT() //后退
IN1 = 0;
IN2 = 1;
IN3 = 0;
IN4 = 1;
void ZZ1() //左大轉(zhuǎn)
IN1 = 0;
IN2 = 1;
IN3 = 1;
IN4 = 0;
void ZZ2() //左小轉(zhuǎn)
IN1 = 0;
IN2 = 0;
IN3 = 1;
IN4 = 0;
void YZ1() //右大轉(zhuǎn)
IN1 = 1;
IN2 = 0;
IN3 = 0;
IN4 = 1;
void YZ2() //右小轉(zhuǎn)
IN1 = 1;
IN2 = 0;
IN3 = 0;
IN4 = 0;
void HY() //后右轉(zhuǎn)
IN1 = 0;
IN2 = 0;
IN3 = 0;
IN4 = 1;
void lin1() //紅外避障程序
if( S1 && S2 ) //兩探頭不反應(yīng),小車前進(jìn)
QJ();
if( !S1 && S2 ) //左探頭反應(yīng),小車右轉(zhuǎn)
SC();
delay(100);
HT();
delay(400);
YZ1();
delay(550);
SC();
delay(100);
if( S1 && !S2 ) //右探頭反應(yīng),小車左轉(zhuǎn)
SC();
delay(100);
HT();
delay(400);
ZZ1();
delay(550);
SC();
delay(100);
if( !S1 && !S2 ) //兩探頭反應(yīng),小車后退,右轉(zhuǎn)
SC();
delay(100);
HT();
delay(400);
HY();
delay(550);
void lin2() //尋跡功能程序
if( !S3 && !S4 ) //兩探頭反應(yīng),小車前進(jìn)
QJ();
delay(150);
SC();
delay(90);
if( S1 && S2 ) //兩探頭反應(yīng),小車停止
SC();
if( S3 && !S4 ) //左探頭不反應(yīng),小車右轉(zhuǎn)
SC();
delay(90);
YZ2();
delay(120);
if( !S3 && S4 ) //右探頭不反應(yīng),小車左轉(zhuǎn)
SC();
delay(90);
ZZ2();
delay(90);
void lin3() //物塊追蹤功能程序
if( S1 && S2 ) //兩探頭不反應(yīng),小車停止
SC();
if( !S1 && !S2 ) //兩探頭反應(yīng),小車前進(jìn)
QJ();
if( !S1 && S2 ) //右探頭不反應(yīng),小車左轉(zhuǎn)
ZZ1();
if( S1 && !S2 ) //左探頭不反應(yīng),小車右轉(zhuǎn)
YZ1();
void lin4() //魔術(shù)手功能程序
QJ();
HT();
if( !S1 && S2 ) //左探頭反應(yīng),小車后退
HT();
if( S1 && !S2 ) //右探頭反應(yīng),小車后退
HT();
void konzi() //控制位
if( K1 == 0 )
delay(10);
if( K1 == 0 )
COM++;
while( !K1 );
if( COM == 5)
COM = 0;
t=0;
if( COM == 0 )
PWM_NO = 14;
PWM_NO = 15;
void main () //主函數(shù)
time(); //計(jì)時(shí)器初始化
InitUART(); //串口初始化
connt = 20; //PWM的一個(gè)周期
PWM_NO = 14; //調(diào)速,數(shù)值越大速度越慢
IN1 = 0;
IN2 = 0;
IN3 = 0;
IN4 = 0; //待機(jī)
konzi();
switch(COM) //功能選擇區(qū)
case 0: lin1();break; //避障
case 1: lin2();break; //尋跡
case 2: lin3();break; //物體跟隨
case 3: lin4();break; //魔術(shù)手
case 4: t=1;SC();while(1);break; //跳轉(zhuǎn)到藍(lán)牙控制
void Timer0Interrupt(void) interrupt 1 //計(jì)時(shí)器中斷函數(shù)
u8 non;
TH0 = 0xfe;
TL0 = 0x0c;
non++;
if( non == PWM_NO )
PWM1 = 1;
PWM2 = 1;
if( non == connt )
non = 0;
if( PWM_NO != 0)
PWM1 = 0;
PWM2 = 0;
