Arduino (ESP8266)獲取網絡時間
Franze2020
2021-4-17 22:53
#include <NTPClient.h>
// change next line to use with another board/shield
#include <ESP8266WiFi.h>
//#include <WiFi.h> // for WiFi shield
//#include <WiFi101.h> // for WiFi 101 shield or MKR1000
#include <WiFiUdp.h>
const char *ssid = "你的wifi";
const char *password = "wifi密碼";
int timeZone = 8; //東八區的時間
WiFiUDP ntpUDP;
// You can specify the time server pool and the offset (in seconds, can be
// changed later with setTimeOffset() ). Additionaly you can specify the
// update interval (in milliseconds, can be changed using setUpdateInterval() ).
NTPClient timeClient(ntpUDP, "europe.pool.ntp.org", timeZone*3600, 60000);
void setup(){
Serial.begin(115200);
WiFi.begin(ssid, password);
while ( WiFi.status() != WL_CONNECTED ) {
delay ( 500 );
Serial.print ( "." );
timeClient.begin();
void loop() {
timeClient.update();
Serial.println(timeClient.getFormattedTime());
delay(500);
