標題: 單片機音樂盒程序圖和與源代碼 [打印本頁]
作者: 而通過的    時間: 2021-3-22 08:58
標題: 單片機音樂盒程序圖和與源代碼
  1. #include <reg51.h>                 //頭文件
  3. #define uint unsigned int          //宏定義
  4. uchar STH0;                                  //定時器變量
  5. uchar STL0;                                  //定時器變量
  6. bit FY=0;                                         //模式變量,為0時彈奏模式,為1時播放模式
  7. uchar Song_Index=0,Tone_Index=0;//單首歌曲音符數
  8. uchar k, key;                                         //k:按鍵數值變量。key:按鍵的鍵值(也就是有按鍵按下時的P0口狀態)
  9. sbit SPK=P3^7 ;                                 //定義喇叭的接口
  10. sbit LED1=P3^5;
  11. sbit LED2=P3^4;                                 //定義兩個LED的接口
  12. uchar code DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,//數碼管顯示的數組(1 2 3 4 5 6 7 8 9)
  13.                                                 0x88,0x83,0xc6,0xa1,0x86,0x8e,0x89,0xa3,0x8c,0xc8};        //(A B C D E F H O P N)
  14. unsigned char code num1[]=                        "   Music:       ";
  15. uchar code Song[][100]=         //內置音樂數組,song【歌曲序號】【音符順序】
  16. {
  17.         //        1        2        3        4        5        6        7
  18.         //        8        9        10        11        12        13        14
  19.         //        15        16        17        18        19        20        21
  20.         {12,10,9,9,10,8,9,10,
  21.         12,10,9,9,5,10,11,10,
  22.         10,10,14,10,9,8,7,8,
  23.         9,10,13,6,8,10,9,6,
  24.         8,7,5,6,12,10,9,9,
  25.         9,10,8,9,10,12,10,9,
  26.         9,9,5,10,11,10,10,10,
  27.         14,10,9,8,7,8,9,10,
  28.         13,6,8,10,9,6,8,7,
  29.         5,6,-1},                                 //煙花易冷
  30.         {13,12,10,12,15,13,
  31.         12,13,10,12,13,12,10,8,6,12,
  32.         10,9,9,10,12,12,13,10,9,
  33.         8,12,10,9,8,6,8,5,-1},//世上只有媽媽好
  34.         {10,10,11,10,9,8,9,12,9,9,
  35.         8,8,9,8,7,6,7,10,7,7,
  36.         6,9,10,9,8,6,5,9,10,9,
  37.         8,6,6,9,10,9,8,6,7,8,-1}, //當你孤單你會想起誰
  38.         {5,3,5,8,6,8,
  39.         5,5,1,2,3,2,1,2,5,
  40.         3,5,8,7,6,8,5,5,2,
  41.         3,4,0,1,6,8,8,7,6,
  42.         7,8,6,7,8,6,6,5,3,
  43.         1,2,5,3,5,8,7,6,8,
  44.         5,5,2,3,4,0,1,-1},                 //送別
  45.         {5,6,8,6,6,5,6,5,3,5,
  46.         5,6,8,6,6,5,6,5,6,1,
  47.         1,2,3,2,2,2,1,2,1,6,
  48.         3,2,5,6,8,6,6,5,6,5,
  49.         6,1,1,2,3,4,4,5,6,6,
  50.         5,6,8,6,8,6,5,5,1,6,
  51.         5,5,6,8,3,2,3,1,-1},           //最浪漫的事
  52.         {5,9,10,9,10,12,13,12,8,9,
  53.         10,13,12,10,12,12,13,15,13,12,
  54.         10,12,10,8,9,10,8,6,10,9,
  55.         12,9,10,9,10,12,13,12,8,9,
  56.         10,13,12,12,13,15,13,
  57.         12,10,12,10,8,6,10,9,8,6,
  58.         8,9,9,8,-1},                                //發如雪
  59.         {5,8,9,10,9,10,11,12,12,12,
  60.         11,10,9,5,8,9,10,11,12,12,
  61.         12,13,12,9,10,8,8,6,9,9,
  62.         10,10,8,12,8,12,8,7,8,8,6,
  63.         9,9,10,10,12,12,
  64.         12,13,12,9,10,8,
  65.         5,8,9,10,9,10,11,12,12,12,
  66.         11,10,9,5,8,9,10,9,10,11,
  67.         12,12,12,9,10,8,8,6,9,9,
  68.         10,10,8,12,8,12,12,7,8,-1},        //簡單愛
  69.         {8,9,10,8,8,9,10,8,10,11,12,10,11,12,
  70.         12,13,12,11,10,8,12,13,12,11,10,8,8,5,8,8,5,8,-1},        //兩只老虎
  71.         {5,5,6,5,8,7,
  72.         5,5,6,5,9,8,
  73.         5,5,12,10,8,7,6,
  74.         11,11,10,8,9,8,-1},                        //生日快樂
  75.         {6,8,9,10,12,10,8,9,6,8,9,10,
  76.         12,12,13,9,10,10,12,13,
  77.         12,13,15,14,13,12,13,10,8,9,10,12,8,6,
  78.         8,9,10,13,12,10,13,13,
  79.         12,11,10,9,10,12,6,8,9,8,9,
  80.         10,12,13,15,14,13,12,10,13,-1},        //讓我們蕩起雙槳
  81.         {8,8,12,12,13,13,12,
  82.         11,11,10,10,9,9,8,
  83.         12,12,11,11,10,10,9,
  84.         12,12,11,11,10,10,9,
  85.         8,8,12,12,13,13,12,
  86.         11,11,10,10,9,9,8,-1},                        //小星星
  87.         {12,10,12,10,12,10,8,9,11,10,9,12,
  88.         12,10,12,10,12,10,8,9,11,10,9,8,
  89.         9,9,11,11,10,8,12,9,11,10,9,12,
  90.         12,10,12,10,12,10,8,9,11,10,9,8,-1}, //粉刷匠
  91.         {8,9,10,11,12,12,12,11,10,
  92.         11,11,11,10,9,8,10,12,
  93.         8,9,10,11,12,12,12,11,10,
  94.         11,11,11,10,9,8,10,8,
  95.         13,13,13,12,11,12,12,12,11,10,
  96.         11,11,11,10,9,8,10,12,
  97.         13,13,13,12,11,12,12,12,11,10,
  98.         11,11,11,10,9,8,10,8,-1},                        //洋娃娃和小熊跳舞
  99.         {12,10,12,13,15,16,17,16,15,13,12,15,
  100.         17,16,15,12,17,16,15,12,
  101.         10,12,13,15,16,17,15,13,15,16,
  102.         13,13,14,13,13,17,15,14,15,13,
  103.         12,10,12,13,15,16,17,16,15,13,12,15,
  104.         17,17,17,17,15,16,16,16,16,12,
  105.         12,10,12,13,15,16,17,16,15,13,12,
  106.         15,15,-1},                                                           //小紅花
  107.         {8,9,10,11,12,10,8,15,13,11,12,12,10,
  108.         8,9,10,11,12,10,9,8,9,10,9,12,
  109.         8,9,10,11,12,10,8,15,13,11,12,10,
  110.         8,9,10,11,12,10,9,8,9,10,8,8,
  111.         15,13,11,12,12,8,15,13,11,12,10,
  112.         8,9,10,11,12,10,9,8,9,10,8,8,
  113.         15,13,11,12,12,8,15,13,11,12,10,
  114.         8,9,10,11,12,10,9,8,9,10,8,8,-1},        //小紅帽
  115.         {10,12,16,15,12,11,10,10,10,11,12,
  116.         13,12,10,12,16,15,12,11,
  117.         10,12,12,13,14,15,15,16,12,12,14,13,12,
  118.         10,12,15,13,15,16,15,14,12,10,12,
  119.         16,15,12,11,10,12,12,13,14,15,15,-1},        //雪絨花
  120. };
  121. uchar code Len[][100]= //內置音樂對應的節拍(音符持續時間)
  122. {
  123.         {1,1,2,4,1,1,1,4,
  124.         1,1,2,2,1,1,1,4,
  125.         1,1,1,1,2,1,1,1,
  126.         1,1,3,1,1,1,1,1,
  127.         1,1,1,6,1,1,2,1,
  128.         1,1,1,1,4,1,1,2,
  129.         1,1,1,1,1,4,1,1,
  130. 3,1,2,1,1,3,1,2,1,1,1,1,1,
  131.         3,1,1,1,1,1,1,2,
  132.         2,6,-1},
  133.         {3,1,2,2,2,1,
  134.         1,4,2,1,1,2,2,1,1,1,
  135.         1,4,3,1,2,1,1,2,2,
  136.         4,3,1,1,1,1,1,6,-1},
  137.         {2,1,1,2,1,1,2,2,2,3,
  138.         2,1,1,2,1,1,2,2,2,3,
  139.         2,1,1,1,1,2,2,1,1,1,
  140.         1,2,2,1,1,1,1,1,1,6,-1},
  141.         {2,3,1,3,2,2,
  142.         4,2,1,1,2,1,1,4,2,
  143.         1,1,2,1,2,2,4,2,1,
  144.         1,2,1,4,2,2,4,2,1,
  145.         1,4,1,1,1,1,1,1,1,
  146.         1,8,2,1,1,2,1,2,2,
  147.         4,2,1,1,2,2,4,-1},
  148.         {1,1,1,2,1,1,1,1,1,5,
  149.         1,1,1,2,1,1,1,1,1,5,
  150.         1,1,1,1,1,1,1,1,1,1,
  151.         2,3,1,1,1,2,1,1,1,1,
  152.         1,5,1,1,1,2,1,1,1,1,
  153.         1,2,1,3,1,1,1,4,1,1,
  154.         5,1,1,1,1,1,1,6,-1},
  155.         {1,1,2,1,1,1,1,3,1,1,
  156.         1,1,1,1,3,1,1,2,1,1,
  157.         1,1,2,1,1,1,1,1,1,1,
  158.         1,1,2,1,1,1,1,3,1,1,
  159.         1,1,3,1,1,2,1,
  160.         1,1,1,2,1,1,1,1,1,1,
  161.         1,1,1,4,-1},
  162.         {1,1,1,1,1,1,1,1,1,1,
  163.         1,1,3,1,1,1,1,1,1,1,
  164.         1,1,2,1,1,2,1,1,1,1,
  165.         1,1,1,1,1,1,1,1,1,1,1,
  166.         1,1,1,1,1,1,
  167.         1,1,2,1,1,2,
  168.         1,1,2,1,1,1,1,1,1,1,
  169.         1,1,3,1,1,1,1,1,1,1,
  170.         1,1,2,1,1,2,1,1,1,1,
  171.         1,1,2,1,1,1,1,1,1,-1},
  172.         {2,2,2,2,2,2,2,2,2,2,4,2,2,4,
  173.         1,1,1,1,2,2,1,1,1,1,2,2,2,2,4,2,2,4,-1},
  174.         {1,1,2,2,2,4,
  175.         1,1,2,2,2,4,
  176.         1,1,2,2,2,2,2,
  177.         1,1,2,2,2,4,-1},
  178.         {1,1,1,3,1,1,1,2,4,1,1,1,
  179.         3,1,2,2,4,1,1,4,
  180.         3,1,1,1,1,1,1,2,1,1,3,1,2,2,
  181.         1,1,1,1,5,4,3,1,
  182.         1,1,2,4,3,1,1,1,3,1,1,
  183.         2,2,2,2,1,1,1,1,4,-1},
  184.         {2,2,2,2,2,2,3,
  185.         2,2,2,2,2,2,3,
  186.         2,2,2,2,2,2,3,
  187.         2,2,2,2,2,2,3,
  188.         2,2,2,2,2,2,3,
  189.         2,2,2,2,2,2,4,-1},
  190.         {1,1,1,1,1,1,2,1,1,1,1,2,
  191.         1,1,1,1,1,1,2,1,1,1,1,2,
  192.         1,1,1,1,1,1,2,1,1,1,1,2,
  193.         1,1,1,1,1,1,2,1,1,1,1,3,-1},
  194.         {1,1,1,1,1,1,1,1,1,
  195.         1,1,1,1,1,1,1,2,
  196.         1,1,1,1,1,1,1,1,1,
  197.         1,1,1,1,1,1,1,2,
  198.         1,1,1,1,1,1,1,1,1,2,
  199.         1,1,1,1,1,1,1,2,
  200.         1,1,1,1,1,1,1,1,1,1,
  201.         1,1,1,1,1,1,1,3,-1},
  202.         {1,1,1,1,1,1,2,1,1,1,1,4,
  203.         2,1,1,4,2,1,1,4,
  204.         2,1,1,2,2,1,1,1,1,4,
  205.         2,1,1,3,1,1,1,1,1,4,
  206.         1,1,1,1,1,1,2,1,1,1,1,4,
  207.         1,1,1,1,4,1,1,1,1,4,
  208.         1,1,1,1,1,1,2,1,1,1,1,
  209.         4,4,-1},
  210.         {1,1,1,1,2,1,1,2,1,1,1,1,2,
  211.         1,1,1,1,1,1,1,1,2,2,2,2,
  212.         1,1,1,1,2,1,1,2,1,1,2,2,
  213.         1,1,1,1,1,1,1,1,2,2,2,2,
  214.         2,1,1,1,1,2,2,1,1,2,2,
  215.         1,1,1,1,1,1,1,1,2,2,2,2,
  216.         2,1,1,1,1,2,2,1,1,2,2,
  217.         1,1,1,1,1,1,1,1,2,2,2,2,-1},
  218.         {2,2,4,2,2,4,2,2,1,1,2,
  219.         4,4,2,2,4,2,2,4,
  220.         2,2,1,1,2,4,4,4,1,2,1,1,2,
  221.         2,2,4,2,2,2,2,4,4,2,2,
  222.         4,2,2,4,2,2,1,1,1,4,4,-1}
  223. };
  224. uint code tab[]={         //內置16個音符彈奏和播放時都是調用此數組內的數據用于定時器初值
  225.         63500,        //超低音 si
  226.         63628,63835,64021,64103,64260,64400,64524,          //低音do-si
  227.         64580,64684,64777,64820,64898,64968,65030,          //           do-si
  228.         65058,65110,65157,65178,65217,65252,65283,         //高音do-si
  229.         65313 };        //超高音do
  230. void delay1 (uint ms)      //粗略1ms延時函數,不精確
  231. {
  232.         uchar t;
  233.         while (ms--)
  234.         for(t=0;t<120;t++);
  235. }
  236. void delay(void)
  237. {
  238.         uchar i;
  239.         for (i=300;i>0;i--);
  240. }
  241. uchar getkey(void)                                  //矩陣按鍵掃描函數
  242. {
  243.         uchar scancode,tmpcode;
  244.         if((P1&0xf0)==0xf0)                         //無按鍵按下時此表達式成立
  245.         return (0);                                         //此函數返回值為0
  246.         scancode = 0xfe;                          //如果上面的if表達式不成立,此語句才可以執行
  247.         while((scancode&0x10)!=0)    //有按鍵按下時,此表達式成立
  248.         {
  249.                 P1=scancode;                           //將P0口賦值
  250.                 if((P1&0xf0)!=0xf0)           //判斷P0口的狀態
  251.                 {
  252.                         tmpcode = (P1&0xf0)|0x0f;                 //P0口的狀態與上0xf0,然后或上0x0f
  253.                         return((~scancode)+(~tmpcode));         //將兩個變量的值取反相加后返回此函數
  254.                 }
  255.                 else scancode=(scancode<<1)|0x01;           //如果上面的if語句不成立,將scancode左移一位
  256.         }
  257.         return(0xff);
  258. }
  259. void anjian()                                 //按鍵鍵值識別
  260. {
  261.         P1=0xf0;                                 //P1口賦值
  262.         if((P1&0xf0)!=0xf0)            //判斷是否有按鍵按下
  263.         {
  264.                 delay();                      //去抖
  265.                 if((P1&0xf0)!=0xf0)  //再次判斷有無按鍵按下
  266.                 {
  267.                         key=getkey();         //掃描按鍵
  268.                         Tone_Index=0;    //播放音符順序清零
  269.                         switch(key)            //根據掃描的按鍵編碼將k賦值
  270.                         {
  271.                                 case 0x88:         //按鍵編碼為0x88
  272. k = 0; //k賦值0k = 0;                 //k賦值0
  273.                                 break;                  //已經確定鍵值后提前跳出switch
  274.                                 case 0x48:   //如果不滿足上一個case則繼續向下判斷,直到有符合
  275.                                 k = 1;                  //k賦值1
  276.                                 break;       //下同,略
  277.                                 case 0x28:
  278.                                 k = 2 ;
  279.                                 break;
  280.                                 case 0x18:
  281.                                 k = 3 ;
  282.                                 break;
  283.                                 case 0x84:
  284.                                 k = 4 ;
  285.                                 break;
  286.                                 case 0x44:
  287.                                 k = 5 ;
  288.                                 break;
  289.                                 case 0x24:
  290.                                 k = 6 ;
  291.                                 break;
  292.                                 case 0x14:
  293.                                 k = 7 ;
  294.                                 break;
  295.                                 case 0x82:
  296.                                 k = 8 ;
  297.                                 break;
  298.                                 case 0x42:
  299.                                 k = 9 ;
  300.                                 break;
  301.                                 case 0x22:
  302.                                 k = 10 ;
  303.                                 break;
  304.                                 case 0x12:
  305.                                 k = 11 ;
  306.                                 break;
  307.                                 case 0x81:
  308.                                 k = 12 ;
  309.                                 break;
  310.                                 case 0x41:
  311.                                 k = 13 ;
  312.                                 break;
  313.                                 case 0x21:
  314.                                 k = 14 ;
  315.                                 break;
  316.                                 case 0x11:
  317.                                 k = 15 ;
  318.                                 break;
  319.                                 default :                 //如果以上都不符合,直接跳出,無鍵值輸出
  320.                                 break;
  321.                         }
  322.                 }
  323.         }
  324. }
  325. void main(void)                                                   //主函數
  326. {
  327.         SPK=0;
  328.         LED1=1;
  329.         LED2=0;                                                    //開機默認彈奏模式
  330.         P0=0xc0;                                                   //數碼管顯示0
  331.         IE=0x87;                                                   //定義外部中斷控制器
  332.         TMOD=0x01;                                                   //定義定時器0的工作方式
  333.         IT0=1;                                                           //外部中斷0為下降沿觸發
  334.         IT1=1;                                                           //外部中斷1為下降沿觸發
  335.         while(1)                                                   //進入死循環
  336.         {
  337.                 P1=0xf0;                                            //P1口賦值
  338.                 if((P1&0xf0)!=0xf0)                           //判斷P0口是否有變化
  339.                 {
  340. anjian(); //讀取鍵值anjian();                                   //讀取鍵值
  341.                         P0=DSY_CODE[k];                           //顯示鍵值,也就是顯示音符
  342.                         if(FY==0)                                   //如果是彈奏模式
  343.                         {
  344.                                 STH0 = tab[k]/256;
  345.                                 STL0 = tab[k]%256;           //根據k的值賦初值給T0
  346.                                 TR0 = 1;               //打開定時器用于定時產生頻率發生
  347.                                 while ((P1&0xf0)!=0xf0); //按鍵不松開的話,T0就一直產生頻率
  348.                                 TR0=0;                 //按鍵松開后關閉T0計時,頻率停止
  349.                         }
  350.                         else  //如果是播放模式(上面的if語句不成立就執行else)
  351.                         {
  352.                                 while (FY==1)                                                          //進入播放模式
  353.                                 {
  354.                                         if(Song[k][Tone_Index]==-1)                  //一首播放完退出
  355.                                         {
  356.                                                 Tone_Index=0;
  357.                                                 SPK=0;
  358.                                                 break;
  359.                                         }
  360.                                         STH0=(tab[Song[k][Tone_Index]])/256;
  361.                                         STL0=(tab[Song[k][Tone_Index]])%256; //將內置音樂數組的數據賦給定時器做為初值計時
  362.                                 //        P0=DSY_CODE[Song[k][Tone_Index]];          //顯示播放的音符
  363.                                         TR0 = 1;                                                          //打開定時器定時開關
  364.                                         delay1(300*Len[k][Tone_Index]);          //節拍數組延時
  365.                                         Tone_Index++;                                                  //變量加準備播放下一個音符
  366.                                         TR0=0;        //停止定時器
  367.                                         anjian();                                                         //掃描按鍵
  368.                                         P0=DSY_CODE[k];                                                 //顯示音樂序號
  369.                                         while((P1&0xf0)!=0xf0);
  370.                                 }
  371.                         }
  372.                 }
  373.         }
  374. }
  375. void EXO_IXT() interrupt 0                  //外部中斷0
  376. {
  377.         FY=0;                                                  //彈奏模式
  378.         LED1=1;
  379.         LED2=0;                                                  //點亮彈奏模式指示燈
  380.         Tone_Index=0;                                  //歌曲音符序號清零,以便于下次播放內置音樂時從頭播放
  381. }
  382. void EX1_INT() interrupt 2                  //外部中斷1
  383. {
  384.         FY=1;                                                  //播放模式
  385.         LED1=0;                                                  //點亮播放模式指示燈
  386.         LED2=1;
  387. }
  388. void time0_int(void) interrupt 1 using 0   //定時器0
  389. {
  390.         TH0 = STH0;                                   //定時器賦初值
  391.         TL0 = STL0;
  392.         SPK=!SPK;                             //喇叭引腳取反,產生頻率的音樂
  393. }
作者: 517538964    時間: 2021-3-25 08:09
需要什么實物  能說一下嗎 樓主 我想做出來
作者: 而通過的    時間: 2021-3-25 21:01
517538964 發表于 2021-3-25 08:09
仿真圖上都有標注的
作者: 緣來yy    時間: 2021-3-26 19:45
名稱        數量(個)        型號        備注
電阻        3
數碼管        1        7SEG-DIGITAL
開關        3                BUTTON
單片機        1        AT89C51
三極管        3        2N3906
揚聲器        1                SPEAKER
電源        2                5V
電容        3                22pf(2個)
晶振        1                CRYSTAL
譯碼器        1        74LS138
地址鎖存器        1        74LS373
七路反向器        1        ULN2003A
三態反向八D鎖存器        1        74LS374
作者: 緣來yy    時間: 2021-3-26 19:46
而通過的 發表于 2021-3-25 21:01
仿真圖上都有標注的
名稱        數量(個)        型號        備注
電阻        3
數碼管        1        7SEG-DIGITAL
開關        3                BUTTON
單片機        1        AT89C51
三極管        3        2N3906
揚聲器        1                SPEAKER
電源        2                5V
電容        3                22pf(2個)
晶振        1                CRYSTAL
譯碼器        1        74LS138
地址鎖存器        1        74LS373
七路反向器        1        ULN2003A
三態反向八D鎖存器        1        74LS374
這是我自己在百度搜的,不知道可以不可以,錯了請指教
作者: 517538964    時間: 2021-3-27 00:57
本帖最后由 517538964 于 2021-3-27 12:33 編輯
緣來yy 發表于 2021-3-26 19:46
名稱        數量(個)        型號        備注
電阻        3
數碼管        1        7SEG-DIGITAL
謝謝 做出來就需要這么多東西嗎 我就按照你寫的買了、要提交材料,我不知道具體買什么  還有你的仿真圖能發我一下嗎
