標題: 基于stm32的水質檢測源程序與Proteus仿真設計 [打印本頁]
作者: lufeiboy    時間: 2021-3-19 22:18
STM32水質檢測仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include "stm32f10x.h"
  2. #include "bsp-lcd1602.h"
  3. #include "delay.h"
  4. #include "sys.h"
  5. #include "adc.h"
  6. char PH_High = 7;
  7. char zuodu_High = 50;
  8. void LED( void )
  9. {
  10.         GPIO_InitTypeDef GPIO_InitStructure;
  11.
  12.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  13.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  14.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  15.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  16.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  17.         GPIO_SetBits( GPIOA,GPIO_Pin_10 );
  18.
  19. }
  20. int main(void)
  21. {
  22.   int ADC_num;
  23.         int temp1,temp2;
  24.
  25.         ADC1_GPIO_Config();
  26.   ADC_Config();
  27.         LCD1602_Init();
  28.         LCD1602_ShowStr(0,1,"zd_S:50% PH_S:7",15);
  29.         LCD1602_ShowStr(0,0,"zd:      PH:   ",15);
  30.         LED();
  31.
  32.         while(1)
  33.         {
  34.                 ADC_num=Get_ADC(ADC_Channel_0);
  35.                 temp1=ADC_num*100/4096;
  36.                 LCD1602_WriteCmd( 0x80 + 3 );
  37.                 LCD1602_WriteDat( temp1/10 + 0x30 );
  38.                 LCD1602_WriteDat( temp1%10 + 0x30 );
  39.                 LCD1602_WriteDat( '%' );
  40.
  41.                 ADC_num=Get_ADC(ADC_Channel_1);
  42.                 temp2=ADC_num*10/4096;
  43.                 LCD1602_WriteCmd( 0x80 + 13 );
  44.                 LCD1602_WriteDat( temp2 + 0x30 );
  45.
  46.                 if(( temp1 >= 50 )||( temp2 >= 7 ))
  47.                 {
  48.                         GPIO_ResetBits( GPIOA,GPIO_Pin_10 );
  49.                 }
  50.                 else
  51.                 {
  52.                         GPIO_SetBits( GPIOA,GPIO_Pin_10 );
  53.                 }
  54.         }
  55. }
  56. 3、main函數
  57. #include "stm32f10x.h"
  58. #include "bsp-lcd1602.h"
  59. #include "delay.h"
  60. #include "sys.h"
  61. #include "adc.h"
  62. char PH_High = 7;
  63. char zuodu_High = 50;
  64. void LED( void )
  65. {
  66.         GPIO_InitTypeDef GPIO_InitStructure;
  67.
  68.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  69.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  70.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  71.         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  72.         GPIO_Init(GPIOA, &GPIO_InitStructure);
  73.         GPIO_SetBits( GPIOA,GPIO_Pin_10 );
  74.
  75. }
  76. int main(void)
  77. {
  78.   int ADC_num;
  79.         int temp1,temp2;
  80.
  81.         ADC1_GPIO_Config();
  82.   ADC_Config();
  83.         LCD1602_Init();
  84.         LCD1602_ShowStr(0,1,"zd_S:50% PH_S:7",15);
  85.         LCD1602_ShowStr(0,0,"zd:      PH:   ",15);
  86.         LED();
  87.
  88.         while(1)
  89.         {
  90.                 ADC_num=Get_ADC(ADC_Channel_0);
  91.                 temp1=ADC_num*100/4096;
  92.                 LCD1602_WriteCmd( 0x80 + 3 );
  93.                 LCD1602_WriteDat( temp1/10 + 0x30 );
  94.                 LCD1602_WriteDat( temp1%10 + 0x30 );
  95.                 LCD1602_WriteDat( '%' );
  96.
  97.                 ADC_num=Get_ADC(ADC_Channel_1);
  98.                 temp2=ADC_num*10/4096;
  99.                 LCD1602_WriteCmd( 0x80 + 13 );
  100.                 LCD1602_WriteDat( temp2 + 0x30 );
  101.
  102.                 if(( temp1 >= 50 )||( temp2 >= 7 ))
  103.                 {
  104.                         GPIO_ResetBits( GPIOA,GPIO_Pin_10 );
  105.                 }
  106.                 else
  107.                 {
  108.                 所有資料51hei提供下載:
  109.         GPIO_SetBits( GPIOA,GPIO_Pin_10 );
  110.                 }
  111.         }
  112. }
Keil代碼與Proteus仿真下載(注意版本號):
Keil5版本: 程序.7z (185.48 KB, 下載次數: 428)
Proteus8.8版本: proteus.rar (118.47 KB, 下載次數: 393)
作者: 895545    時間: 2021-3-27 14:45
你好,為什么我的Proteus中沒有STM32F103R6這個芯片,請問您用的那個版本
作者: wifingtta    時間: 2021-3-31 22:36
用的PROTEUS8.9測試,程序,仿真都可用,很好,謝謝樓主分享。放心下載!
作者: hukexaioxu    時間: 2021-5-18 01:08
謝謝,請問如何模擬測量電導率。
作者: starfox    時間: 2021-5-18 11:31
水質主要是檢測什么變化量?說說實現原理哈。
作者: 1515546    時間: 2021-5-18 18:04
895545 發表于 2021-3-27 14:45
Proteus sp2才有stm103的芯片
作者: fffnb    時間: 2021-5-24 09:43
proteus8
作者: fffnb    時間: 2021-5-28 09:13
proteus8
作者: fffnb    時間: 2021-5-28 09:14
wifingtta 發表于 2021-3-31 22:36
確實不錯
作者: 文明23    時間: 2021-6-7 09:46
能給我解釋一下代碼嗎
作者: liuyiyi    時間: 2021-12-30 11:53
最好在代碼后加上注釋,這樣便于新手理解,
作者: atmy1    時間: 2022-4-22 15:47
需要使用Proteus8.8才行 不然會導致運行ad一直采集不到 一直顯示0
作者: 額防護    時間: 2022-5-3 12:07
需要用Proteus8.8版本才行,其他版本可能會出問題,看圖
作者: da'da'l'k    時間: 2023-4-17 17:01
用的PROTEUS8.8測試,程序,仿真都可用,很好,謝謝樓主分享。放心下載!
作者: da'da'l'k    時間: 2023-4-18 19:43
這個告警燈是由模擬看門狗來控制的嗎?
