51單片機(jī)+1602函數(shù) Proteus仿真
美琴的備胎
時(shí)間:
2021-3-14 09:05
(22.17 KB, 下載次數(shù): 86)
2021-3-14 09:04 上傳
單片機(jī)源程序如下:
LCD1602.C文件 LCD1602的函數(shù)
#include "hardware.h"
#include "lcd1602.h"
void LCD_check_busy(void) //檢測(cè)LCD狀態(tài),看它是不是還在忙呢
LCD_EN=0;
LCD_RS=0;
LCD_RW=1;
LCD_DATA=0xff;
LCD_EN=1;
if(!LCD_BUSY)break;
LCD_EN=0;
void LCD_cls(void) //LCD清屏
LCD_check_busy();
LCD_RS=0;
LCD_RW=0;
LCD_DATA=1;
LCD_EN=1;
LCD_EN=0;
void LCD_write_instruction(unsigned char LCD_instruction) //寫指令到LCD
LCD_check_busy();
LCD_RS=0;
LCD_RW=0;
LCD_DATA=LCD_instruction;
LCD_EN=1;
LCD_EN=0;
void LCD_write_data(unsigned char LCD_data) //輸出一個(gè)字節(jié)數(shù)據(jù)到LCD
LCD_check_busy();
LCD_RS=1;
LCD_RW=0;
LCD_DATA=LCD_data;
LCD_EN=1;
LCD_EN=0;
void LCD_set_position(unsigned char x) //LCD光標(biāo)定位到x處
LCD_write_instruction(0x80+x);
void LCD_go_home(void) //LCD光標(biāo)歸位
LCD_write_instruction(LCD_GO_HOME);
void LCD_printc(unsigned char lcd_data) //輸出一個(gè)字符到LCD
LCD_write_data(lcd_data);
void LCD_prints(unsigned char *lcd_string) //輸出一個(gè)字符串到LCD
unsigned char i=0;
while(lcd_string[i]!=0x00)
LCD_write_data(lcd_string[i]);
i++;
void LCD_initial(void) //初始化LCD
LCD_write_instruction(LCD_AC_AUTO_INCREMENT|LCD_MOVE_DISENABLE);
LCD_write_instruction(LCD_DISPLAY_ON|LCD_CURSOR_OFF);
LCD_write_instruction(LCD_DISPLAY_DOUBLE_LINE);
LCD_cls();
項(xiàng)目.zip
(73.85 KB, 下載次數(shù): 18)
2021-3-14 09:05 上傳
點(diǎn)擊文件名下載附件
