標題: 51單片機電子秤 仿真+程序 [打印本頁]
作者: a282350757    時間: 2021-3-9 01:22
標題: 51單片機電子秤 仿真+程序
程序
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. #include <absacc.h>
  4. #include <math.h>
  5. #define uchar unsigned char
  6. #define uint   unsigned int
  7. #define BUSY  0x80                               //常量定義
  8. #define DATAPORT P0
  9. sbit ADCS =P3^5;
  10. sbit ADDI =P3^7;
  11. sbit ADDO =P3^7;
  12. sbit ADCLK =P3^6;
  13. sbit LCM_RS=P2^0;
  14. sbit LCM_RW=P2^1;
  15. sbit LCM_EN=P2^2;
  16. uint x1,y1,z1=0,w1,temp1;
  17. uchar ad_data,k,n,m,e,num,s;                              //采樣值存儲
  18. sbit beep =P3^0;
  19.
  20. char press_data;                                  //標度變換存儲單元
  21. unsigned char ad_alarm;                           //報警值存儲單元
  22. unsigned char press_ge=0;                        //顯示值百位
  23. unsigned char press_shifen=0;                        //顯示值十位
  24. unsigned char press_baifen=0;                         //顯示值個位
  25. unsigned char press_qianfen=0;                        //顯示值十分位
  26. uchar code str0[]={"Weight:  .   Kg "};
  27. uchar code str2[]={"Price:          "};
  28. uchar code str3[]={"Total:             "};
  29. uchar code table2[]={0x37,0x38,0x39,0xfd,0x34,0x35,0x36,0x78,0x31,0x32,0x33,0x2d,0x3d,0x30,0x2e,0x2b}; //鍵盤碼
  30. void delay(uint);
  31. void lcd_wait(void);
  32. void delay_LCM(uint);        //LCD延時子程序
  33. void initLCM( void);        //LCD初始化子程序
  34. void lcd_wait(void);        //LCD檢測忙子程序
  35. void WriteCommandLCM(uchar WCLCM,uchar BusyC);                              //寫指令到ICM子函數
  36. void WriteDataLCM(uchar WDLCM);                                             //寫數據到LCM子函數
  37. void DisplayOneChar(uchar X,uchar Y,uchar DData);                           //顯示指定坐標的一個字符子函數
  38. void DisplayListChar(uchar X,uchar Y,uchar code *DData);                                         //顯示指定坐標的一串字符子函數
  39. void weishu(uint m);
  40. void weishu1(uint m);
  41. void display(void);
  42. uchar Adc0832(unsigned char channel);
  43. void alarm(void);
  44. void data_pro(void);
  45. /**********main funcation************/
  46. void main(void)
  47. {
  48.     delay(500);                      //系統延時500ms啟動
  49.         //ad_data=0;                       //采樣值存儲單元初始化為0
  50.            initLCM( );
  51.
  52.            WriteCommandLCM(0x01,1);                    //清顯示屏
  53.     DisplayListChar(0,0,str0);
  54.            DisplayListChar(0,1,str2);
  55.         while(1)
  56.     {
  57.            ad_data =Adc0832(0);           //采樣值存儲單元初始化為0
  58.            alarm();
  59.            data_pro();
  60.            display();
  61.         if(k==1)
  62.      {
  63.       DisplayOneChar((s+7),1,table2[num-1]);
  64.           x1=m;
  65.           y1=n;
  66.           y1=y1*10+x1;
  67.      }
  68.     if(k=='*')
  69.    {
  70.      data_pro();
  71.          WriteCommandLCM(0x01,1);
  72.          weishu(z1);
  73.          k=0;
  74.     }
  75.     if(k=='=')
  76.         {
  77.             z1=z1*temp1;
  78.             WriteCommandLCM(0x01,1);
  79.         DisplayListChar(0,1,str3);
  80.                 s=0;
  81.             weishu1(765);
  82.             k=0;
  83.         }
  84.         if(k==' ')
  85.         {
  86.            WriteCommandLCM(0x80+0x40,1);
  87.            WriteCommandLCM(0x01,1);
  88.            z1=0;
  89.            s=0;     //防止清零時指針后移動
  90.         }
  91.   }
  92. }
  93. /*********延時K*1ms,12.000mhz**********/
  94. void delay(uint k)
  95. {
  96.    uint i,j;
  97.    for(i=0;i<k;i++)
  98.     for(j=0;j<100;j++);
  99. }
  100. /**********寫指令到ICM子函數************/
  101. void WriteCommandLCM(uchar WCLCM,uchar BusyC)
  102. {
  103.     if(BusyC)
  104.         lcd_wait();
  105.         DATAPORT=WCLCM;
  106.     LCM_RS=0;                   // 選中指令寄存器
  107.     LCM_RW=0;
  108.         LCM_RW=0;                    // 寫模式
  109.     LCM_EN=1;
  110.         _nop_();
  111.         _nop_();
  112.    _nop_();
  113.    _nop_();
  114.    _nop_();
  115.    _nop_();
  116.    _nop_();
  117.     LCM_EN=0;
  118.
  119. }
  120. /**********寫數據到LCM子函數************/
  121. void WriteDataLCM(uchar WDLCM)
  122. {
  123.     lcd_wait( );             //檢測忙信號
  124.         DATAPORT=WDLCM;
  125.     LCM_RS=1;                // 選中數據寄存器
  126.     LCM_RW=0;                    // 寫模式
  127.     LCM_EN=1;
  128.     _nop_();
  129.            _nop_();
  130.            _nop_();
  131.            _nop_();
  132.            _nop_();
  133.            _nop_();
  134.            _nop_();
  135.         _nop_();
  136.     LCM_EN=0;
  137. }
  138. /***********lcm內部等待函數*************/
  139. void lcd_wait(void)
  140. {
  141.     DATAPORT=0xff;             //讀LCD前若單片機輸出低電平,而讀出LCD為高電平,則沖突,Proteus仿真會有顯示邏輯黃色
  142.         LCM_EN=1;
  143.     LCM_RS=0;
  144.         LCM_RW=0;
  145.     LCM_RW=1;
  146.     _nop_();
  147.     _nop_();
  148.     _nop_();
  149.     _nop_();
  150.     _nop_();
  151.     _nop_();
  152.         _nop_();
  153.     while(DATAPORT&BUSY)
  154.         {  LCM_EN=0;
  155.            _nop_();
  156.     _nop_();
  157.     _nop_();
  158.     _nop_();
  159.     _nop_();
  160.     _nop_();
  161.     _nop_();
  162.     _nop_();
  163.            LCM_EN=1;
  164.     _nop_();
  165.     _nop_();
  166.     _nop_();
  167.     _nop_();
  168.     _nop_();
  169.         _nop_();
  170.         _nop_();
  171.            }
  172.            LCM_EN=0;
  173.
  174. }
  175. /**********LCM初始化子函數***********/
  176. void initLCM( )
  177. {
  178.     LCM_EN=0;
  179.         DATAPORT=0;
  180.         delay(15);
  181.         WriteCommandLCM(0x38,0);    //三次顯示模式設置,不檢測忙信號
  182.     delay(5);
  183.     WriteCommandLCM(0x38,0);
  184.     delay(5);
  185.     WriteCommandLCM(0x38,0);
  186.     delay(5);
  187.     WriteCommandLCM(0x38,1);    //8bit數據傳送,2行顯示,5*7字型,檢測忙信號
  188.     WriteCommandLCM(0x08,1);    //關閉顯示,檢測忙信號
  189.     WriteCommandLCM(0x01,1);    //清屏,檢測忙信號
  190.     WriteCommandLCM(0x06,1);    //顯示光標右移設置,檢測忙信號
  191.     WriteCommandLCM(0x0c,1);    //顯示屏打開,光標不顯示,不閃爍,檢測忙信號
  192.     TMOD=0x11;
  193.         EA=1;
  194.     ET1=1;
  195.         TR1=1;
  196.         k=0;
  197.         x1=0;
  198.         y1=0;
  199.         z1=0;
  200. }
  201. /****顯示指定坐標的一個字符子函數****/
  202. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  203. {
  204.     Y&=0x01;
  205.     X&=0x0f;
  206.     if(Y)
  207.         X|=0x40;               //若y為1(顯示第二行),地址碼+0X40
  208.     X|=0x80;                    //指令碼為地址碼+0X80
  209.     WriteCommandLCM(X,1);
  210.     WriteDataLCM(DData);
  211. }
  212. /*******顯示指定坐標的一串字符子函數*****/
  213. void DisplayListChar(uchar X,uchar Y,uchar code *DData)
  214. {
  215.     uchar ListLength=0;
  216.     Y&=0x01;
  217.     X&=0x0f;
  218.     while(X<16)
  219.     {
  220.         DisplayOneChar(X,Y,DData[ListLength]);
  221.         ListLength++;
  222.         X++;
  223.     }
  224. }
  225. /*****************系統顯示子函數*****************/
  226. void display(void)
  227. {
  228.            WriteCommandLCM(0x0c,1);                                    //顯示屏打開,光標不顯示,不閃爍,檢測忙信號
  229.         DisplayListChar(0,0,str0);
  230.         //DisplayListChar(0,1,str2);
  231.         DisplayOneChar(8,0,press_ge+0x30);
  232.         DisplayOneChar(10,0,press_shifen+0x30);
  233.         DisplayOneChar(11,0,press_baifen+0x30);
  234.     DisplayOneChar(12,0,press_qianfen+0x30);
  235.         delay(1000);                               //穩定顯示
  236. }
  237. /************
  238. 讀ADC0832函數
  239. ************/
  240. //采集并返回
  241. uchar Adc0832(unsigned char channel)     //AD轉換,返回結果
  242. {
  243.      uchar i=0;
  244.     uchar j;
  245.     uint dat=0;
  246.     uchar ndat=0;
  247.     if(channel==0)channel=2;
  248.     if(channel==1)channel=3;
  249.     ADDI=1;
  250.     _nop_();
  251.     _nop_();
  252.     ADCS=0;//拉低CS端
  253.     _nop_();
  254.     _nop_();
  255.     ADCLK=1;//拉高CLK端
  256.     _nop_();
  257.     _nop_();
  258.     ADCLK=0;//拉低CLK端,形成下降沿1
  259.     _nop_();
  260.     _nop_();
  261.     ADCLK=1;//拉高CLK端
  262.     ADDI=channel&0x1;
  263.     _nop_();
  264.     _nop_();
  265.     ADCLK=0;//拉低CLK端,形成下降沿2
  266.     _nop_();
  267.     _nop_();
  268.     ADCLK=1;//拉高CLK端
  269.     ADDI=(channel>>1)&0x1;
  270.     _nop_();
  271.     _nop_();
  272.     ADCLK=0;//拉低CLK端,形成下降沿3
  273.     ADDI=1;//控制命令結束
  274.     _nop_();
  275.     _nop_();
  276.     dat=0;
  277.     for(i=0;i<8;i++)
  278.     {
  279.         dat|=ADDO;//收數據
  280.         ADCLK=1;
  281.         _nop_();
  282.         _nop_();
  283.         ADCLK=0;//形成一次時鐘脈沖
  284.         _nop_();
  285.         _nop_();
  286.         dat<<=1;
  287.         if(i==7)dat|=ADDO;
  288.     }
  289.     for(i=0;i<8;i++)
  290.     {
  291.         j=0;
  292.         j=j|ADDO;//收數據
  293.         ADCLK=1;
  294.         _nop_();
  295.         _nop_();
  296.         ADCLK=0;//形成一次時鐘脈沖
  297.         _nop_();
  298.         _nop_();
  299.         j=j<<7;
  300.         ndat=ndat|j;
  301.         if(i<7)ndat>>=1;
  302.     }
  303.     ADCS=1;//拉低CS端
  304.     ADCLK=0;//拉低CLK端
  305.     ADDO=1;//拉高數據端,回到初始狀態
  306.     dat<<=8;
  307.     dat|=ndat;
  308.     return(dat);            //return ad k
  309. }
  310. void data_pro(void)
  311. {
  312.       unsigned int;
  313.       float  press;
  314.           if(0<ad_data<256)
  315.                  {
  316.                     int vary=ad_data;
  317.                         press=(0.019531*vary);
  318.
  319.                         temp1=(int)(press*1000);                        //放大1000倍,便于后面的計算
  320.
  321.
  322.                         press_ge=temp1/1000;                                     //取壓力值百位
  323.                         press_shifen=(temp1%1000)/100;                            //取壓力值十位
  324.                         press_baifen=((temp1%1000)%100)/10;                    //取壓力值個位
  325.                         press_qianfen=((temp1%1000)%100)%10;                        //取壓力值十分位
  326.                       }
  327.
  328. }
  329. /*****************報警子函數*******************/
  330. void alarm(void)
  331. {
  332.          if(ad_data>=256)
  333.            beep=0;          //則啟動報警
  334.
  335.           else
  336.                beep=1;
  337. }
  338. void weishu(uint m)
  339. {
  340.    uchar wei4,wei3,wei2,wei1,wei0;
  341.    wei4=m/10000;
  342.    wei3=m%10000/1000;
  343.    wei2=m%1000/100;
  344.    wei1=m%100/10;
  345.    wei0=m%10;
  346.    DisplayOneChar(7,1,0x30+wei4);
  347.    DisplayOneChar(8,1,0x30+wei3);
  348.    DisplayOneChar(10,1,0x30+wei2);
  349.            //DisplayOneChar(10,1,'.');
  350.    DisplayOneChar(11,1,0x30+wei1);
  351.    DisplayOneChar(12,1,0x30+wei0);
  352. }
  353. void weishu1(uint m)
  354. {
  355.    uchar wei5,wei4,wei3,wei2,wei1,wei0;
  356.    wei5=m/100000;
  357.    wei4=m%100000/10000;
  358.    wei3=m%10000/1000;
  359.    wei2=m%1000/100;
  360.    wei1=m%100/10;
  361.    wei0=m%10;
  362.    DisplayOneChar(7,1,0x30+wei4);
  363.    DisplayOneChar(8,1,0x30+wei3);
  364.    DisplayOneChar(9,1,'.');
  365.    DisplayOneChar(10,1,0x30+wei2);
  366.    //DisplayOneChar(10,1,'.');
  367.    DisplayOneChar(11,1,0x30+wei1);
  368.    DisplayOneChar(12,1,0x30+wei0);
  369. }
  370. void temer1() interrupt 3
  371. { uchar temp;
  372.   EX1=0;
  373.   P1=0xfe;
  374.   temp=P1;
  375.   temp=temp&0xf0;
  376.   if(temp!=0xf0)
  377.   {
  378.     delay(5);
  379.         temp=P1;
  380.     temp=temp&0xf0;
  381.         while(temp!=0xf0)
  382.         {
  383.           temp=P1;
  384.           switch(temp)
  385.           {
  386.             case 0xee:num=1;n=7;k=1,s++;break;
  387.             case 0xde:num=2;n=8;k=1,s++;break;
  388.             case 0xbe:num=3;n=9;k=1,s++;break;
  389.             case 0x7e:num=4;k='/',s++;break;
  390.           }
  391.           while(temp!=0xf0)
  392.           {
  393.                    temp=P1;
  394.         temp=temp&0xf0;
  395.           }
  396.         //DisplayOneChar((s+6),1,table2[num-1]);
  397.         }
  398.   }
  399.   P1=0xfd;
  400.   temp=P1;
  401.   temp=temp&0xf0;
  402.   if(temp!=0xf0)
  403.   {
  404.     delay(5);
  405.         temp=P1;
  406.     temp=temp&0xf0;
  407.         while(temp!=0xf0)
  408.         {
  409.           temp=P1;
  410.           switch(temp)
  411.           {
  412.             case 0xed:num=5;n=4;k=1;s++;break;
  413.             case 0xdd:num=6;n=5;k=1;s++;break;
  414.             case 0xbd:num=7;n=6;k=1;s++;break;
  415.             case 0x7d:num=8;k='*';s++;break;
  416.           }
  417.           while(temp!=0xf0)
  418.           {
  419.                    temp=P1;
  420.         temp=temp&0xf0;
  421.           }
  422.         //DisplayOneChar(k+6,1,table2[num-1]);
  423.         }
  424.   }
  425.   P1=0xfb;
  426.   temp=P1;
  427.   temp=temp&0xf0;
  428.   if(temp!=0xf0)
  429.   {
  430.     delay(5);
  431.         temp=P1;
  432.     temp=temp&0xf0;
  433.         while(temp!=0xf0)
  434.         {
  435.           temp=P1;
  436.           switch(temp)
  437.           {
  438.             case 0xeb:num=9;n=1;k=1;s++;break;
  439.             case 0xdb:num=10;n=2;k=1;s++;break;
  440.             case 0xbb:num=11;n=3;k=1;s++;break;
  441.             case 0x7b:num=12;k='-';s++;break;
  442.           }
  443.           while(temp!=0xf0)
  444.           {
  445.                    temp=P1;
  446.         temp=temp&0xf0;
  447.           }
  448. //        DisplayOneChar(k+6,1,table2[num-1]);
  449.         }
  450.   }
  451.   P1=0xf7;
  452.   temp=P1;
  453.   temp=temp&0xf0;
  454.   if(temp!=0xf0)
  455.   {
  456.     delay(5);
  457.         temp=P1;
  458.     temp=temp&0xf0;
  459.         while(temp!=0xf0)
  460.         {
  461.           temp=P1;
  462.           switch(temp)
  463.           {
  464.             case 0xe7:num=13;k=' ';break;
  465.             case 0xd7:num=14;n=0;k=1;s++;;break;
  466.             case 0xb7:num=15;k='=';s++;break;
  467.             case 0x77:num=16;k='+';s++;;break;
  468.           }
  469.           while(temp!=0xf0)
  470.           {
  471.                    temp=P1;
  472.         temp=temp&0xf0;
  473.           }
  474.         //DisplayOneChar(k+6,1,table2[num-1]);
  475.          }
  476.
  477.   }
  478.   EX1=1;
  479. }
LCD+ADC0832 電子秤.zip
186.81 KB, 下載次數: 40, 下載積分: 黑幣 -5
