標題: 單片機矩陣鍵盤顯示在數碼管上面 [打印本頁]
作者: SGW2020    時間: 2021-2-1 13:50
標題: 單片機矩陣鍵盤顯示在數碼管上面
矩陣鍵盤顯示在數碼管上面
04-02.zip (800 Bytes, 下載次數: 10)
04-01.zip (815 Bytes, 下載次數: 9)
#include<reg52.h>
sbit d1=P1^0;
sbit key1=P3^4;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table []={0x3f,0x06,
0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(uint z);
uchar num,temp;
void display (uchar num)
        P0=table[num];
        dula=1;
        dula=0;
void   matrixkeyscan()
         uchar temp,key;
         P3=0xfe;
         temp=P3;
         temp=temp&0xf0;
            delay(10);
             temp=P3;
             temp=temp&0xf0;
              if(temp!=0xf0)
              temp=P3;
              switch(temp)
            case 0xee:
                key=0;
                break;
            case 0xde:
                 key=1;
                 break;
            case 0xbe:
                key=2;
                break;
            case 0x7e:
                key=3;
                break;
            while (temp!=0xf0)
                   temp=P3;
                   temp=temp&0xf0;
              display(key);
    P3=0xfd;
         temp=P3;
         temp=temp&0xf0;
            delay(10);
             temp=P3;
             temp=temp&0xf0;
              if(temp!=0xf0)
              temp=P3;
              switch(temp)
            case 0xed:
                key=4;
                break;
            case 0xdd:
                 key=5;
                 break;
            case 0xbd:
                key=6;
                break;
            case 0x7d:
                key=7;
                break;
            while (temp!=0xf0)
                   temp=P3;
                   temp=temp&0xf0;
              display(key);
    P3=0xfb;
         temp=P3;
         temp=temp&0xf0;
            delay(10);
             temp=P3;
             temp=temp&0xf0;
              if(temp!=0xf0)
              temp=P3;
              switch(temp)
            case 0xeb:
                key=8;
                break;
            case 0xdb:
                 key=9;
                 break;
            case 0xbb:
                key=10;
                break;
            case 0x7b:
                key=11;
                break;
            while (temp!=0xf0)
                   temp=P3;
                   temp=temp&0xf0;
              display(key);
    P3=0xf7;
         temp=P3;
         temp=temp&0xf0;
            delay(10);
             temp=P3;
             temp=temp&0xf0;
              if(temp!=0xf0)
              temp=P3;
              switch(temp)
            case 0xe7:
                key=12;
                break;
            case 0xd7:
                 key=13;
                 break;
            case 0xb7:
                key=14;
                break;
            case 0x77:
                key=15;
                break;
            while (temp!=0xf0)
                   temp=P3;
                   temp=temp&0xf0;
              display(key);
        P0=0;
        dula=1;
            dula=0;
             P0=0xc0;
            wela=1;
               wela=0;
                  matrixkeyscan();
void  delay (uint z)
                uint x,y;
                for(x=z;x>0;x--)
                 for(y=110;y>0;y--);
//矩陣鍵盤 顯示0-16 方式2
