標題: 速度測量器 lcd1602 stc89c52 [打印本頁]
作者: 朝朝1    時間: 2021-1-21 20:03
#include <reg52.h>
typedef unsigned char uchar;
typedef unsigned int uint;
sbit key=P3^4;
sbit key1=P3^5;
sbit RS = P1^0;
sbit RW = P1^1;
sbit EN = P2^5;
sbit BEEP=P2^3;
unsigned char i,a,b,c,d,f,g,h,i;
unsigned char x,y,m,n,z;
float p,j;
int q,w,e,r,o;
void delayms(unsigned int xms)
   unsigned i,j;
        for(i=xms;i>0;i--)
           for(j=110;j>0;j--);
void Read_Busy()
        uchar busy;
        P0 = 0xff;
        RS = 0;
        RW = 1;
        do
                EN = 1;
                busy = P0;
                EN = 0;
        }while(busy & 0x80);
//?LCD1602??????
void Write_Cmd(uchar cmd)
        Read_Busy();//???
        RS = 0;
        RW = 0;
        P0 = cmd;
        EN = 1;
        EN = 0;
void Write_Dat(uchar dat)
        Read_Busy();
        RS = 1;
        RW = 0;
        P0 = dat;
        EN = 1;
        EN = 0;
void charter(unsigned char x,unsigned char y,unsigned char dat)
if(y==0)
Write_Cmd(0x80+x);
Write_Cmd(0xc0+x);
Write_Dat( dat);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
Write_Cmd(0x80 + x);
Write_Cmd(0xC0 + x);
while (*s)
Write_Dat( *s);
s ++;
void lcdinit()
   Write_Cmd(0x38);
   Write_Cmd(0x08);    /*????*/
   Write_Cmd(0x01);    /*????*/
   Write_Cmd(0x06);    /*????????*/
   Write_Cmd(0x0C);    /*????????*/
void Timer0Init(void)                //50??@11.0592MHz
        TMOD = 0x01;                //???????
       TH0=0xdc;               //10ms??
   TL0=0x00;
                ET0=1;
        EA=1;
        TR0 = 0;                //???0????
void beep()
    unsigned char y;
    for (y=0;y<180;y++)
      BEEP=!BEEP;                //BEEP??
          delayms(70);
    BEEP=1;                      //?????
unsigned char num,num1,u;
lcdinit();
Timer0Init();
        LCD_Write_String(0,1,"time:");
        LCD_Write_String(0,0,"speed:00:00cm/s");
        LCD_Write_String(5,1,"00:00:00:00");
if(key==0)
        delayms(50);
if(key==0)
num=num+1;
while(!key);
switch(num)
        case 1:TR0=1;
        //LCD_Write_String(0,0,"begin count 1");
                delayms(5);
        break;
        case 2:TR0=0;
                //LCD_Write_String(0,0,"pause count 2");
        delayms(5);
        break;
        case 3:TR0=1;
                //LCD_Write_String(0,0,"begin count 3");
        delayms(5);
        break;
        case 4:TR0=0;
        //LCD_Write_String(0,0,"pause count 4");
        delayms(5);
        break;
if(key1==0)
void timer() interrupt 1
TH0=0xdc;
   TL0=0x00;
  a++;
        o=3546;
        charter(15,1,'0'+a);
if(a==10)
        a=0;
        b++;
        x=b%10;
                charter(14,1,'0'+x);
if(b==10)
        b=0;
c++;
        y=c%10;
        charter(12,1,'0'+y);
if(c==10)
c=0;
        d++;
        z=d%10;
        charter(11,1,'0'+z);
if(d==6)
d=0;
                charter(11,1,'0'+0);
        e++;
        m=e%10;
        charter(9,1,'0'+m);
if(e==10)
e=0;
        f++;
        n=f%10;
                charter(8,1,'0'+n);
p=a*0.01+b*0.1+c*1+d*10;
j=3/p;
o=j*100;
q=o/1000;
w=o%1000/100;
e=o%1000%100/10;
r=o%1000%100%10;
charter(6,0,'0'+q);
        charter(7,0,'0'+w);
        charter(9,0,'0'+e);
        charter(10,0,'0'+r);
作者: longmon    時間: 2022-2-21 17:04
有具體程序說明嗎?測量原理?
