用PIC單片機的PWM生產一個頻率和幅值可調的正弦波
tony009
2021-1-16 09:06
(250.36 KB, 下載次數: 145)
2021-1-16 16:09 上傳
#include "Head.h"
void main (void)
OSCCON=0b11110000;
TRISD=0;
PORTD=0;
TRISC=0b10000000;
OPTION_REG=0b10001000;
INTCON=0b11100000;
PIE1=0b00100000;//開串口中斷
CCP1CON=0b00001100;
PR2=255;
T2CON=0b00000100;// 最大脈沖寬度 4*(255+1)=1024
TXSTA=0b00100100; //SYNC=0;BRGH=1;
RCSTA=0b10010000;
BAUDCON=0b00001000; //BRG16=1;
SPBRGH=0;
SPBRG=207; //FOSC/[4(n+1)] (32000000/38400)/4-1=207
Send();
//定時器中斷程序
void interrupt TMR0INT(void)//4/32*256=32us
static unsigned char a=0,b=0,c=0;
static unsigned int pwm_duty=0;
const unsigned int pwm_1[PI_data]={0,13,25,37,50,62,74,85,96,107,118,127,137,146,154,162,
169,175,181,186,190,194,196,198,200,200,200,198,196,194,190,186,
181,175,169,162,154,146,137,127,118,107,96,85,74,62,50,37,
25,13};
const unsigned int pwm_2[PI_data]={0,31,63,94,124,155,184,213,241,268,294,319,342,364,385,405,
422,438,452,465,476,484,491,496,499,500,499,496,491,484,476,465,
452,438,422,405,385,364,342,319,294,268,241,213,184,155,124,94,
63,31};
const unsigned int pwm_3[PI_data]={0,63,125,187,249,309,368,426,482,536,588,637,685,729,771,809,
844,876,905,930,951,969,982,992,998,1000,998,992,982,969,951,930,
905,876,844,809,771,729,685,637,588,536,482,426,368,309,249,187,
125,63};
if(T0IF)
T0IF=0;
LATD6^=1;
if(++a==Pwm_frequency) //1000000/(Pwm_frequency*32*50)=頻率HZ 1000000/(6*32*50)=104HZ
a=0;
if(++b==PI_data)b=0;
switch(c)
case 1: {pwm_duty=pwm_1;break;}
case 2: {pwm_duty=pwm_2;break;}
case 3: {pwm_duty=pwm_3;break;}
default: {pwm_duty=pwm_1;break;}
} CCP1CON=(CCP1CON&0xcf)|((pwm_duty&3)<<4);CCPR1L=pwm_duty>>2;
if(RCIF)
static unsigned char temp=0;
if(OERR==1){CREN=0;asm("nop");CREN=1;}
temp=RCREG;
switch(temp)
case 'a':{Pwm_frequency++;break;}//頻率加
case 'b':{if(Pwm_frequency)Pwm_frequency--;break;}//頻率減
case 'c':{c++;if(c>3)c=1;break;}//振動幅度
lgktech
2021-1-16 21:44
收下了,有匯編的嗎?
tony009
2021-1-19 15:04
匯編的沒啊,
siyrra
2021-6-3 10:30
好東西,先收下了,感謝分享
nanfuB
2021-6-29 21:01
正想弄一個SPWM輸出電路,先收下了,謝謝
xv8276
2021-6-30 22:39
這個正正弦波不正
gaojian218
2021-7-24 19:11
好東西,先收下了,感謝分享
風動還是心動
2021-9-21 15:30
為什么PWM產生周期用TIMER2,中斷里面確實TIMER0的程序?
ahcene2035
2021-10-23 03:02
這個正正弦波不正
一片一城
2021-10-28 16:53
負半周是三角波,正半周看著象一鍋窩頭。
xywf
2021-11-11 10:03
正負半周能否對稱圓滑一點?謝謝!
MCU_FANS
2021-11-30 20:16
用查表的方式!
mick32
2022-5-23 23:54
where is "Head.h" ?
Thanks
zch5200
2023-4-19 16:45
發這樣的程序最好說用什么晶振,因為PIC的CCP輸出沒計算好的話脈寬調整并不是真的是0~1023,頻率高是話有的300就到100%了
三極管一樣的人
2023-12-7 16:30
有沒有按鍵固定選擇幾個周期,占空比不變的思路,望指點下~,是不是每次選擇PR2; CCPR2L;CCP2CON; 都要重新填寫下?
