標(biāo)題: 求牛人幫忙看看這個(gè)程序,一個(gè)燈都不亮 [打印本頁(yè)]
作者: LHYF    時(shí)間: 2013-7-23 15:44
//用AVR點(diǎn)亮32*32LED點(diǎn)陣 點(diǎn)陣?yán)锛?4hc595 和74hc138芯片
#include<avr/io.h>
#include<util/delay.h>
#include<avr/interrupt.h>
#include<avr/pgmspace.h>
#define SI1       PORTC|=(1<<PC0)
#define SI0       PORTC&=~(1<<PC0)
#define G1()      PORTC|=(1<<PC1)                      // HC_595輸出使能控制端置1
#define G0()      PORTC&=~(1<<PC1)                     // HC_595輸出使能控制端置0
#define RCK1()    PORTC|=(1<<PC2)                      // HC_595存儲(chǔ)寄存器時(shí)鐘輸入置1
#define RCK0()    PORTC&=~(1<<PC2)                     // HC_595存儲(chǔ)寄存器時(shí)鐘輸入置0
#define SCK1()    PORTC|=(1<<PC3)                      // HC_595移位寄存器時(shí)鐘輸入置1
#define SCK0()    PORTC&=~(1<<PC3)                     // HC_595移位寄存器時(shí)鐘輸入置0
#define SCLR1()   PORTC|=(1<<PC4)                      // HC_595移位寄存器清零輸入置1
#define SCLR0()   PORTC&=~(1<<PC4)                     // HC_595移位寄存器清零輸入置0
#define OE1()     PORTA|=(1<<PA5)                      // HC_138使能置1
#define OE0()     PORTA&=~(1<<PA5)                     // HC_138使能置0
long  scan_date0[128]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
        0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 };
unsigned char scan_date1[32]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,0x0f,
                              0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1a,0x1b,0x1c,0x1d,0x1e,0x1f}; //行
void delay(unsigned int ms )
     while(ms--)
  _delay_ms(1);
//初始化函數(shù)
void init()
                                         //HC_595初始化
    DDRC=0x1F;
PORTC=0xFF;
    G0() ;                               //使能HC_595輸出使能控制端
    SCK0();                              // HC_595移位寄存器時(shí)鐘輸入端口置低電平
    RCK0();
    SCLR0();
    SCLR1();
                                         //HC_138初始化
    DDRA=0x3F;
PORTA=0xFF;
//HC_595列掃描
void HC_595( unsigned int date)
    unsigned char i;
    for(i=0;i<8;i++)
    {     G0();
      SCK0();
         if(date&0x80)
        PORTC|=(1<<PC0);                //串行數(shù)據(jù)輸入
              PORTC&=~(1<<PC0);
         date<<=1;
   SCK1();
    RCK0();                             //上升沿鎖存數(shù)據(jù)輸出
          RCK1();
           G1();                               //關(guān)閉輸出使能控制端
int main()
{   init();
    unsigned int i=0;
    unsigned int m=3;
unsigned int n=0;
    for(i=0;i<=31;i++)
     OE0();                                //打開HC_138使能
        PORTA=scan_date1[i];
  for(n=m-3;n<=m;n++)
   {   if(n<=127)
     HC_595(scan_date0[n]);
           m=m+4;
       delay(4);
       // OE1();                                    //關(guān)閉HC_138使能
