標(biāo)題: 89單片機(jī)+四個(gè)74HC595的LED16x16點(diǎn)陣 程序源碼原理圖 [打印本頁]
作者: 人人學(xué)會單片機(jī)    時(shí)間: 2021-1-3 20:12
07 點(diǎn)陣16X16 四個(gè)模塊級連原理圖與內(nèi)存分配圖.pdf (111.34 KB, 下載次數(shù): 51)
04 點(diǎn)陣16X16 單個(gè)模塊原理圖.pdf (84.31 KB, 下載次數(shù): 39)
02 點(diǎn)陣工作原理與焊接制作注意事項(xiàng).pdf (14.4 MB, 下載次數(shù): 27)
電路原理圖如下:
//------------------------------------------------------------------------------------------------祁緒電子《人人學(xué)會單片機(jī)》------
//1、本程序適用于:由4個(gè)595驅(qū)動(dòng)的16*16點(diǎn)陣。先發(fā)16位陽極列選信號,再發(fā)送陰極字節(jié)模數(shù)據(jù)。
//2、為方便閱讀,使用傳統(tǒng)編程思路編寫,并未使用框架式編程方式,
//3、本程序使用11.0592M晶振,STC89C52RC單片機(jī)12T模式工作。
//4、11.0592M晶振,刷新率50幀,太低會閃爍、太高CPU卡頓。
//5、89系列單片機(jī)下載的時(shí)候,如果“使能6T(雙倍速)模式,可以增加單片機(jī)運(yùn)行速度。
#include<REG52.H>
#include<intrins.h>
//------漢字字模保存數(shù)組code
uchar code hanzi[10][32]=
//五角星
        {        0x00,0x00,0x04,0x00,0x06,0x02,0x07,0x0C,0x07,0xBC,0x07,0xF8,0x0F,0xF8,0x3F,0xF0,0xFF,0xE0,0x3F,0xF0,0x0F,0xF8,0x07,0xF8,0x07,0xBC,0x07,0x0C,0x06,0x02,0x04,0x00                },
//祁
        {        0x10,0x20,0x10,0x40,0x10,0x80,0x91,0x00,0x73,0xFF,0x15,0x00,0x18,0x80,0x00,0x00,0x7F,0xFF,0x40,0x10,0x42,0x08,0x4D,0x04,0x70,0x88,0x00,0x70,0x00,0x00,0x00,0x00                },
//緒
        {        0x04,0x44,0x0C,0xC6,0x35,0x44,0xC6,0x48,0x0C,0x68,0x02,0x48,0x22,0x80,0x23,0xFF,0x22,0x92,0xFE,0x92,0x2A,0x92,0x32,0x92,0x23,0xFF,0x46,0x80,0x02,0x00,0x00,0x00                },
//電
        {        0x00,0x00,0x1F,0xE0,0x12,0x40,0x12,0x40,0x12,0x40,0x12,0x40,0xFF,0xFC,0x12,0x42,0x12,0x42,0x12,0x42,0x12,0x42,0x3F,0xE2,0x10,0x02,0x00,0x0E,0x00,0x00,0x00,0x00                },
//子
        {        0x01,0x00,0x01,0x00,0x41,0x00,0x41,0x00,0x41,0x00,0x41,0x02,0x41,0x01,0x47,0xFE,0x45,0x00,0x49,0x00,0x51,0x00,0x61,0x00,0x01,0x00,0x03,0x00,0x01,0x00,0x00,0x00                },
//黑桃
        {         0x00,0x00,0x03,0xC0,0x07,0xE0,0x0F,0xF0,0x1F,0xF0,0x3F,0xE1,0x7F,0xC3,0xFF,0xFF,0xFF,0xFF,0x7F,0xC3,0x3F,0xE1,0x1F,0xF0,0x0F,0xF0,0x07,0xE0,0x03,0xC0,0x00,0x00                },
//紅心
        {        0x00,0x00,0x07,0x80,0x0F,0xC0,0x1F,0xE0,0x1F,0xF0,0x1F,0xF8,0x0F,0xFC,0x07,0xFE,0x07,0xFE,0x0F,0xFC,0x1F,0xF8,0x1F,0xF0,0x1F,0xE0,0x0F,0xC0,0x07,0x80,0x00,0x00                },
//梅花
        {         0x00,0x00,0x00,0xE0,0x01,0xF0,0x03,0xF8,0x33,0xF8,0x79,0xF1,0xFD,0xE3,0xFF,0xFF,0xFF,0xFF,0xFD,0xE3,0x79,0xF1,0x33,0xF8,0x03,0xF8,0x01,0xF0,0x00,0xE0,0x00,0x00                },
//方片
        {        0x00,0x00,0x01,0x00,0x03,0x80,0x07,0xC0,0x0F,0xE0,0x1F,0xF0,0x3F,0xF8,0x7F,0xFC,0xFF,0xFE,0x7F,0xFC,0x3F,0xF8,0x1F,0xF0,0x0F,0xE0,0x07,0xC0,0x03,0x80,0x01,0x00                },
//花點(diǎn)
        {        0xAA,0xAA,0x55,0x55,0xAA,0xAA,0x55,0x55,0xAA,0xAA,0x55,0x55,0xAA,0xAA,0x55,0x55,0xAA,0xAA,0x55,0x55,0xAA,0xAA,0x55,0x55,0xAA,0xAA,0x55,0x55,0xAA,0xAA,0x55,0x55                }
uchar idata Mould[2];                                          //控制該列的取模值,低電平亮燈,每個(gè)模組16行,占2字節(jié)
uchar idata upright[2];                                        //控制某一列,高電平亮燈,每個(gè)模組16列,占2字節(jié)
uchar idata LED2X64[34];                                //開辟緩存空間,被定時(shí)器隨時(shí)調(diào)用。每列兩個(gè)字節(jié),多加2個(gè)用于移位操作。
sbit HC595_DS=P3^6;                                                //74HC595的數(shù)據(jù)
sbit HC595_SH=P3^5;                                                //74HC595的時(shí)鐘
sbit HC595_ST=P3^4;                                                //74HC595的鎖存
//------定時(shí)器0配置:16位定時(shí)器,1.25ms顯示1列,幀率50幀。
void Timer0_Init()
        TMOD&=0Xf0;                                                        //16位定時(shí)器模式,需要人工重裝初值
        TMOD|=0X01;                                                        //16位定時(shí)器模式,需要人工重裝初值
        TL0=0x80;
        TH0=0xf8;                                                        //STC89最高刷新率60幀,太高了會占用CPU
        ET0=1;        //定時(shí)器0中斷閉合導(dǎo)通
        TR0=1;        //定時(shí)器0啟動(dòng)
        EA=1;        //總中斷閉合導(dǎo)通
//------發(fā)送數(shù)據(jù)到595芯片
void HC595_Write()                                                //74HC595發(fā)送數(shù)據(jù)。
        uchar value,i,j=1;
        value=upright[j*2-1];
        for(i=0;i<8;i++)                                         //發(fā)送給每個(gè)模組的 U4 ,高電平整列可以亮,低電平整列滅。
                HC595_SH=0;                                                //時(shí)鐘拉低
                HC595_DS=value&0x80;                          //從最后一個(gè)字節(jié)開始,先高位后低位。
                value<<=1;                                                //字節(jié)左移
                HC595_SH=1;                                                //時(shí)鐘上升沿拷貝
        value=upright[j*2-2];
        for(i=0;i<8;i++)                                         //發(fā)送給每個(gè)模組的 U3 ,高電平整列可以亮,低電平整列滅。
        value=Mould[j*2-1];
        for(i=0;i<8;i++)                                         //發(fā)送給每個(gè)模組的 U2 ,低電平整行可以亮,高電平整行全滅。
        value=Mould[j*2-2];
        for(i=0;i<8;i++)                                         //發(fā)送給每個(gè)模組的 U1 ,低電平整行可以亮,高電平整行全滅。
        HC595_ST=1;                                                        //鎖存脈沖信號,上升沿。
        HC595_DS=0;                                                        //延時(shí)
        HC595_ST=0;                                                        //鎖存脈沖信號復(fù)位。
        HC595_SH=0;
////定時(shí)器中斷處理,16位定時(shí)器,控制595函數(shù)1.25ms顯示1列,幀率50幀。
void Timer0_Routnie (void) interrupt 1
        static uchar i;
        static uint kkk=0x0001;                                //用于16列輪流控制
        TH0=0xfb;                                                        //定時(shí)器賦初始值65536-(11059200÷6T÷16列÷50幀)
        TL0=0x95;                                                        //STC89最高刷新率60幀,太高了會占用CPU, 0x95是微調(diào)值約等于計(jì)算值
        Mould[1]=~LED2X64[i+1];                                //i=0,把緩存的第01號字節(jié)發(fā)送到第一個(gè)模組的最左邊的下8位。
        Mould[0]=~LED2X64[i+0];                                //i=0,把緩存的第00號字節(jié)發(fā)送到第一個(gè)模組的最左邊的上8位。
        upright[1]=kkk/256;                                        //16位變量KKK,取高8位。控制第一個(gè)模組的0~7列。
        upright[0]=kkk%256;                                        //16位變量KKK,取低8位。控制第一個(gè)模組的8~15列。
        kkk=_irol_(kkk,1);                                        //循環(huán)控制0~16列
        i++;i++;
        i=i%32;
        HC595_Write();                                                //595的緩存Mould[8]、upright[8],得到數(shù)據(jù)后,立馬發(fā)送到芯片
//------主函數(shù)
void main()        //主函數(shù)
        uchar k=0;
        for(k=0;k<32;k++)
                LED2X64[k]=hanzi[k/32+1][k%32];        //把要顯示的內(nèi)容寫入緩存
        HC595_DS=0;                                                        //初始化595IO口拉低
        HC595_SH=0;                                                        //初始化595IO口拉低
        HC595_ST=0;                                                        //初始化595IO口拉低
        Timer0_Init();                                                //初始化定時(shí)器
         while(1)                                                           //大循環(huán)
08 點(diǎn)陣16X16 字模提取 漢字字模軟件設(shè)置.png (53.5 KB, 下載次數(shù): 203)
08 點(diǎn)陣16X16 字模提取 漢字字模舉例.jpg (879.22 KB, 下載次數(shù): 130)
06 點(diǎn)陣16X16 使用STC8多功能DMX無線板做主控 級聯(lián)驅(qū)動(dòng).jpg (252.56 KB, 下載次數(shù): 140)
03 點(diǎn)陣8X8 管腳引出的拉線圖.png (275.3 KB, 下載次數(shù): 136)
作者: SHANWAZI    時(shí)間: 2021-3-3 10:59
這點(diǎn)陣取模軟件能不能共享以下
作者: 人人學(xué)會單片機(jī)    時(shí)間: 2021-3-3 17:00
SHANWAZI 發(fā)表于 2021-3-3 10:59
其他多種資料的統(tǒng)一鏈接:https://pan.baidu.com/s/1HKoHDJSc9sxFTQvllo825g
提取碼:1234
作者: 大佬求帶DD    時(shí)間: 2021-3-24 19:51
字模提取
字模提取V2.2.rar
262.6 KB, 下載次數(shù): 26, 下載積分: 黑幣 -5
我是用這個(gè)提取字模的,樓主那個(gè)我知道但不會用
作者: myself1820    時(shí)間: 2021-5-15 10:18
謝謝分享,最近正在研究點(diǎn)陣模塊
作者: shi79433233    時(shí)間: 2021-5-24 14:11
原理圖文件可以分享下嘛
