能幫我看下單片機程序哪錯了嗎?求幫助
15830376694
2020-12-27 13:28
能幫我看下單片機程序哪錯了嗎?求幫助
#include <reg52.h>
uchar table[] = "Hello everyone!";
uchar table1[] = "Welcome to here!";
uchar num;
void main(void)
unsigned char i;
for(i=0;i<16;i++)
LcdWriteData(uchar [i]);
while(1);
void Lcd1602_Delay1ms(uint c)
uchar a,b;
for(;c>0;c--)
for(b=199;b>0;b--)
for(a=1;a>0;a--);
#ifndef LCD1602_4PINS
void LcdWriteCom(uchar com)
LCD1602_E=0;
LCD1602_RS=0;
LCD1602_RW=0;
LCD1602_DATAP=com;
Lcd1602_Delay1ms(1);
LCD1602_E=1;
Lcd1602_Delay1ms(10);
LCD1602_E=0;
#else
LCD1602_E=0;
LCD1602_RS=0;
LCD1602_RW=0;
LCD1602_DATAPINS=com;
LCD1602_Delay(1);
LCD1602_E=1;
lcd1602_Delay1ms(10);
LCD1602_E=0;
lcd1602_Delay1ms(1);
LCD1602_DATAPINS=com<<4;
LCD1602_E=1;
LCD1602_E=0;
#endif
void LcdWriteData(uchar dat)
LCD1602_E=0;
LCD1602_RS=1;
LCD1602_RW=0;
LCD1602_DATAPINS=dat;
LCD1602_Delay1ms(1);
LCD1602_E=1;
LCD1602_Delay1ms(10);
LCD1602_E=0;
#else
LCD1602_E=0;
LCD1602_RS=1;
LCD1602_RW=0;
LCD1602_E=1;
LCD1602_E=0;
LCD1602_DATAPINS=dat<<4;
LCD1602_E=1;
LCD1602_E=0;
#endif
void LcdInit()
LcdWriteCom(0x38);
LcdWriteCom(0x0c);
LcdWriteCom(0x06);
LcdWriteCom(0x01);
LcdWriteCom(0x80);
#else
void LcdInit()
LcdWriteCom(0x32);
LcdWriteCom(0x28);
LcdWriteCom(0x0c);
LcdWriteCom(0x06);
LcdWriteCom(0x01);
LcdWriteCom(0x80);
#endif
#ifndef _LCD_H_
#define _LCD_H_
#define LCD1602_4PINS
#include<reg52.h>
#ifdef uchar
#endif
#ifndef uint
#endif
#define LCD1602_DATAPINS P0
sbit LCD1602_E=P2^2;
sbit LCD1602_RW=P2^1;
sbit LCD1602_RS=P2^0;
void LCD1602_Delay1ms(uint c);
void LcdWriteCom(uchar Com);
void LcdWriteDaTa(uchar dat);
void LcdInit();
#endif
51hei團團
2020-12-27 15:20
編譯器提示的什么錯誤?
張天師
2020-12-27 19:58
1.LcdWriteData(uchar [i]);這條語句不對,應該是LcdWriteData(table [i]);或者LcdWriteData(table1 [i]);
2.另外主程序要先對LCD初始化,再啟動顯示
3.很多程序放值位置不對,應該函數聲明及宏定義在前,函數在后。你基本上全反了
