標題: 安卓體重計算器java源程序 使用Intent在Activity間傳輸數據 [打印本頁]
作者: dori    時間: 2020-12-15 20:25
本帖最后由 dori 于 2020-12-18 23:10 編輯
完成一個體重計算器的應用程序開發。
MainActivity文件:
import androidx.appcompat.app.AppCompatActivity;
import android.content.Intent;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.EditText;
import android.widget.RadioGroup;
public class MainActivity extends AppCompatActivity {
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        Button bn=findViewById(R.id.bn);
        final RadioGroup male=findViewById(R.id.male);
        //綁定監視器
        bn.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                EditText et = findViewById(R.id.editText);
                Boolean sex = male.getCheckedRadioButtonId()==R.id.rb1?true:false;//true為男,false為女
                String height = et.getText().toString();
                //創建Intent
                Intent intent = new Intent(MainActivity.this, Activity.class);
                intent.putExtra("sex", sex);
                intent.putExtra("height", height);
                startActivity(intent);
Activity.java文件:
import android.widget.TextView;
public class Activity extends AppCompatActivity {
    @Override
        setContentView(R.layout.result);
        TextView tv1 = findViewById(R.id.gender);
        TextView tv2 = findViewById(R.id.height);
        TextView tv3 = findViewById(R.id.weight);
        //獲得intent
        Intent intent = getIntent();
        //獲得性別和身高信息
        Boolean sex =intent.getBooleanExtra("sex", true);
        Integer height = Integer.parseInt(intent.getStringExtra("height"));
        if (sex) //男
            tv1.setText("你是一名男性");
            tv2.setText("你的身高是" + height + "厘米");
            Double weight = (height - 80) * 0.7;
            tv3.setText("你的標準體重是" + weight + "公斤");
        } else {
            tv1.setText("你是一名女性");
            Double weight = (height - 70) * 0.6;
activity_main.xml文件:
<?xml version="1.0" encoding="utf-8"?>
<androidx.constraintlayout.widget.ConstraintLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    tools:context=".MainActivity">
    <LinearLayout
        android:id="@+id/linearLayout"
        android:orientation="vertical"
        app:layout_constraintTop_toTopOf="parent"
        tools:layout_editor_absoluteX="-148dp">
        <TextView
            android:id="@+id/textView2"
            android:layout_height="40dp" />
        <TextView
            android:id="@+id/textView"
            android:layout_height="wrap_content"
            android:text="計算標準體重"
            android:textSize="30sp" />
        <TableRow
            android:orientation="vertical">
            <TextView
                android:id="@+id/textView3"
                android:layout_width="73dp"
                android:text="性別:"
                android:textSize="20sp" />
            <RadioGroup
                android:id="@+id/male"
                android:layout_width="337dp"
                android:orientation="horizontal">
                <RadioButton
                    android:id="@+id/rb1"
                    android:layout_width="142dp"
                    android:text="男性"
                <RadioButton
                    android:id="@+id/rb2"
                    android:layout_width="147dp"
                    android:text="女性"
            </RadioGroup>
        </TableRow>
        <TableRow
            android:layout_height="wrap_content">
            <TextView
                android:id="@+id/height"
                android:text="身高:"
            <EditText
                android:id="@+id/editText"
                android:layout_width="175dp"
                android:ems="10"
                android:inputType="number"
                android:textColor="#E91E63" />
            <TextView
                android:id="@+id/textView5"
                android:layout_width="72dp"
                android:text="cm"
        </TableRow>
        <TableRow
            android:layout_width="400dp"
            android:layout_height="60dp">
            <TextView
                android:id="@+id/textView6"
                android:layout_width="314dp"
                android:layout_height="wrap_content" />
            <Button
                android:id="@+id/bn"
                android:layout_width="wrap_content"
                android:text="計算"
                android:textSize="25sp" />
        </TableRow>
    </LinearLayout>
</androidx.constraintlayout.widget.ConstraintLayout>
result.xml文件:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:orientation="vertical" android:layout_width="match_parent"
    android:layout_height="match_parent">
    <TextView
        android:id="@+id/textView10"
        android:layout_height="158dp" />
    <TextView
        android:id="@+id/gender"
        android:layout_height="52dp" />
    <TextView
    <TextView
        android:id="@+id/weight"
</LinearLayout>
使用Intent在Activity間傳輸數據.rar (8.52 MB, 下載次數: 5)
