單片機PH值檢測魚缸自動換水系統程序
LCL000
2020-11-27 19:01
單片機PH值檢測魚缸自動換水系統程序
/******************** (C) COPYRIGHT 2015 Silicone shell electronic studio **************************
* 文件名 :main.c
* 描述 :
* 硬件連接:
* 實驗平臺:
STC12C5A60S2
開發板
https://www.bilibili.com/video/BV1rK411V7xa/
#include <STC12C5A60S2.h>
#include <intrins.h>
#include <lcd.h>
#include <DS18B20.h>
#define MAIN_Fosc 11059200L //定義主時鐘, 模擬串口和和延時會自動適應。5~35MHZ 22118400L
#define ADC_OFF() ADC_CONTR = 0
#define ADC_ON (1 << 7)
#define ADC_90T (3 << 5)
#define ADC_180T (2 << 5)
#define ADC_360T (1 << 5)
#define ADC_540T 0
#define ADC_FLAG (1 << 4) //軟件清0
#define ADC_START (1 << 3) //自動清0
#define ADC_CH0 0
#define ADC_CH1 1
#define ADC_CH2 2
#define ADC_CH3 3
#define ADC_CH4 4
#define ADC_CH5 5
#define ADC_CH6 6
#define ADC_CH7 7
sbit k1 = P2^0;
sbit k2 = P2^1;
sbit k3 = P2^2;
sbit fs_led = P3^3;
sbit ss_led = P3^4;
sbit yw_up = P3^6;
sbit yw_down = P3^7;
/**************變量定義***************************/
float PH=0.0;
float PH_value=0.0;
float ph1=0.0,ph2=0.0;
float ph_h=0.0, ph_h_2=0.0;
unsigned int temp_data=0;
unsigned char disbuff[14]={0};
void DelayUs(unsigned int time); //延時子函數
void Delay1(unsigned int time); //延時主程序
void delay_ms_AD(unsigned char ms);
void press_k1();
void press_k2();
void press_k3();
void Display_PH1();
void Display_PH2();
void Display_time_set();
uint adc10_start(uchar channel); //channel = 0~7
uint key_flag = 0,turnwater=0,flag1=0;
uint count1 = 0;
uint i;
void PH_Value_Conversion()
PH=(PH*5)/1024;
PH_value=-5.8887*PH+21.677;
if((PH_value<=0)){PH_value=0;}
if((PH_value>14)){PH_value=14.1;}
/*顯示酸堿度*/
disbuff[0]=(int)(PH_value*100)/1000+'0';
disbuff[1]=(int)(PH_value*100)%1000/100+'0';
disbuff[2]='.';
disbuff[3]=(int)(PH_value*100)%100/10+'0';
disbuff[4]=(int)(PH_value*100)%10+'0';
DisplaySingleChar(0x03,1,disbuff[0]);
DisplaySingleChar(0x04,1,disbuff[1]);
DisplaySingleChar(0x05,1,disbuff[2]);
DisplaySingleChar(0x06,1,disbuff[3]);
DisplaySingleChar(0x07,1,disbuff[4]);
void TEMP_Value_Conversion() //溫度
disbuff[9]=(int)(temp_data)/1000+'0';
disbuff[10]=(int)(temp_data)%1000/100+'0';
disbuff[11]=(int)(temp_data)%100/10+'0';
disbuff[12]='.';
disbuff[13]=(int)(temp_data)%10+'0';
DisplaySingleChar(0x0b,1,disbuff[10]);
DisplaySingleChar(0x0c,1,disbuff[11]);
DisplaySingleChar(0x0d,1,disbuff[12]);
DisplaySingleChar(0x0e,1,disbuff[13]);
* 函數名:main
* 描述 :主函數
* 輸入 :無
* 輸出 :無
void main(void)
ss_led = 0;
fs_led = 0;
Init_Ds18b20();
LCDInit(); //顯示屏初始化
DisplayString(0x0,0," Welcome... ");
DisplayString(0x0,1,"water quality");
Delay1(2500);
WriteCmd(LCD_CLS);
P1ASF = 0x07; //12C5A60AD/S2系列模擬輸入(AD)選擇
ADC_CONTR = ADC_360T | ADC_ON;
ph1 = 5.0;
ph2 = 6.0;
press_k1();
press_k2();
press_k3();
if (count1 == 0)
DisplayString(0x02,0,"*");
DisplayString(0x09,0," ");
if (count1 == 1)
DisplayString(0x02,0," ");
DisplayString(0x09,0,"*");
DisplayString(0x0,1,"PH:");
DisplayString(0x09,1,"T:");
Display_time_set();
for(i=0; i<2; i++)
Delay1(500);
if(i==0)
PH = adc10_start(0);
PH_Value_Conversion();
if(i==1)
temp_data=Get_temp();
TEMP_Value_Conversion();
if (PH_value < ph1 || PH_value > ph2)
turnwater = 1;
if( turnwater == 1 )
if(yw_down == 0 && flag1 == 0) //放水過程
ss_led = 0;
fs_led = 1;
if(yw_down == 1 && flag1 == 0) //放水完畢,開始上水
ss_led = 1;
fs_led = 0;
flag1 = 1;
if(yw_up == 0 && flag1 == 1) //上水完畢,關繼電器
ss_led = 0;
fs_led = 0;
turnwater = 0;
flag1=0;
///********************* 做一次ADC轉換 *******************/
uint adc10_start(uchar channel) //channel = 0~7
uint adc;
uchar i;
ADC_RES = 0;
ADC_RESL = 0;
ADC_CONTR = (ADC_CONTR & 0xe0) | ADC_START | channel;
i = 250;
do{
if(ADC_CONTR & ADC_FLAG)
ADC_CONTR &= ~ADC_FLAG;
adc = (uint)ADC_RES;
adc = (adc << 2) | (ADC_RESL & 3);
return adc;
}while(--i);
return 1024;
// 函數: void delay_ms(unsigned char ms)
// 描述: 延時函數。
// 參數: ms,要延時的ms數.
// 返回: none.
// 版本: VER1.0
// 日期: 2010-12-15
// 備注:
unsigned int i;
do{
i = MAIN_Fosc / 14000;
while(--i) ; //14T per loop
}while(--ms);
Display_PH1();
Display_PH2();
void Display_PH1()
uint ph_h1, ph_h2,ph_h3,ph_h4;
ph_h = ph1 * 100;
ph_h1 = (int)ph_h/1000;
ph_h2 = (int)ph_h%1000/100;
ph_h3 = (int)ph_h%100/10;
ph_h4 = (int)ph_h%10;
DisplaySingleChar(0x03,0,ph_h1+0x30);
DisplaySingleChar(0x04,0,ph_h2+0x30);
DisplaySingleChar(0x05,0,'.');
DisplaySingleChar(0x06,0,ph_h3+0x30);
DisplaySingleChar(0x07,0,ph_h4+0x30);
void Display_PH2()
ph_h_2 = ph2 * 100;
ph_h1 = (int)ph_h_2/1000;
ph_h2 = (int)ph_h_2%1000/100;
ph_h3 = (int)ph_h_2%100/10;
ph_h4 = (int)ph_h_2%10;
DisplaySingleChar(0x0a,0,ph_h1+0x30);
DisplaySingleChar(0x0b,0,ph_h2+0x30);
DisplaySingleChar(0x0c,0,'.');
DisplaySingleChar(0x0d,0,ph_h3+0x30);
DisplaySingleChar(0x0e,0,ph_h4+0x30);
// 描述: 鍵盤掃描。
void press_k1()
if (k1 == 0)
Delay1(80);
if (k1 == 0)
//key_flag = 1;
count1++;
if (count1 ==2)
count1 = 0 ;
void press_k2()
if (k2 == 0)
Delay1(100);
if (k2 == 0)
if (count1 == 0)
ph1+=0.1;
if(ph1>=14)
ph1 = 0;
if (count1 == 1)
ph2+=0.1;
if(ph2>=14)
ph2 = 0;
void press_k3()
if (k3 == 0)
Delay1(100);
if (k3 == 0)
if (count1 == 0)
ph1-=0.1;
if(ph1<=0)
ph1 = 14;
if (count1 == 1)
ph2-=0.1;
if(ph2<=0)
ph2 = 14;
//延時函數//
unsigned int timeCounter = 0;
for (timeCounter = time;timeCounter > 0 ;timeCounter --)
DelayUs(255);
for (timeCounter = 0;timeCounter < time;timeCounter ++)
_nop_();
//void BitTime(void) //位時間函數
// uint i;
// i = ((MAIN_Fosc / 100) * 104) / 140000L - 1; //根據主時鐘來計算位時間
// while(--i);
//模擬串口發送
//void Tx1Send(uchar dat) //9600,N,8,1 發送一個字節
// uchar i;
// EA = 0;
// P_TXD1 = 0;
// BitTime();
// for(i=0; i<8; i++)
// if(dat & 1) P_TXD1 = 1;
// else P_TXD1 = 0;
// dat >>= 1;
// BitTime();
// P_TXD1 = 1;
// EA = 1;
// BitTime();
// BitTime();
