51單片機雙設備通信控制小燈的程序設計
Sicinera
2020-11-25 20:50
51單片機雙設備通信控制小燈的程序設計
單片機設計小程序,多虧隊友帶在我本來的代碼上修改了不少,在此表示由衷感謝!
以下是全部源程序,因為偷懶沒有把各個模塊的子程序封裝成庫,供大家學習!
臨近期末,事多人忙,也愿大家好好努力,不愧初心!
#include <reg52.h>
#include <stdio.h>
#include <string.h>
#include <intrins.h>
#define U unsigned char
sbit scl=P1^1;
sbit sda=P1^0;
sbit key=P1^7;
sbit red=P1^4;
sbit green=P1^3;
sbit blue=P1^5;
U a[81]={1},st=1,sq=1;
char page=0;
U num=0,sw=1;
U code order1[]="AT+RST\r\n";
U code order2[]="AT+CWMODE=2\r\n";
U code order3[]="AT+CWSAP=\"sPinAr\",\"22222222\",11,3\r\n";
U code order4[]="AT+CIPMUX=1\r\n";
U code order5[]="AT+CIPSERVER=1,8080\r\n";
U code order6[]="AT+CIFSR\r\n";
U code dt_pls[2][6]={
0x00,0x80,0x00,0x00,0x00,0X00, //dot
0x08,0x08,0x3E,0x08,0x08,0X00}; //plus
U code alpha[26][6]={
0xFC,0x12,0x11,0x12,0xFC,0x00, //A
0xFF,0x89,0x89,0x89,0x76,0x00, //B
0x7E,0x81,0x81,0x81,0x42,0x00, //C
0xFF,0x81,0x81,0x81,0x7E,0x00, //D
0xFF,0x89,0x89,0x89,0x89,0x00, //E
0xFF,0x09,0x09,0x09,0x09,0x00, //F
0x7E,0x81,0x91,0x91,0x70,0x00, //G
0xFF,0x08,0x08,0x08,0xFF,0x00, //H
0x81,0x81,0xFF,0x81,0x81,0x00, //I
0x41,0x81,0x81,0xFF,0x01,0x00, //J
0xFF,0x18,0x24,0x42,0x81,0x00, //K
0xFF,0x80,0x80,0x80,0x80,0x00, //L
0xFF,0x06,0x0C,0x06,0xFF,0x00, //M
0xFF,0x08,0x10,0x20,0xFF,0x00, //N
0x7E,0x81,0x81,0x81,0x7E,0x00, //O
0xFF,0x11,0x11,0x11,0x0E,0x00, //P
0x7E,0x81,0xA1,0xA1,0xFE,0x00, //Q
0xFF,0x19,0x29,0x49,0x86,0x00, //R
0x46,0x89,0x89,0x89,0x72,0x00, //S
0x01,0x01,0xFF,0x01,0x01,0x00, //T
0x7F,0x80,0x80,0x80,0x7F,0x00, //U
0x07,0x38,0xC0,0x38,0x07,0x00, //V
0x1F,0xE0,0x18,0xE0,0x1F,0x00, //W
0x81,0x66,0x18,0x66,0x81,0x00, //X
0x03,0x0C,0xF0,0x0C,0x03,0x00, //Y
0xE1,0x91,0x89,0x85,0x83,0x00}; //Z
U code bet[26][6]={
0x70,0x88,0x88,0x88,0xF0,0x00, //a
0xFF,0x88,0x88,0x88,0x70,0x00, //b
0x70,0x88,0x88,0x88,0x48,0x00, //c
0x70,0x88,0x88,0x88,0xFF,0x00, //d
0x70,0xA8,0xA8,0xA8,0xB0,0x00, //e
0x88,0x88,0xFE,0x09,0x09,0x00, //f
0x4C,0x92,0x92,0x92,0x7C,0x00, //g
0xFF,0x08,0x08,0x08,0xF0,0x00, //h
0x08,0x08,0xFA,0x80,0x40,0x00, //i
0x00,0x40,0x88,0x88,0xFA,0x00, //j
0xFF,0x20,0x50,0x88,0x88,0x00, //k
0x80,0x40,0xFF,0x92,0x4C,0x00, //l
0xF8,0x10,0xF8,0x10,0xF8,0x00, //m
0xF8,0x10,0x08,0x08,0xF0,0x00, //n
0x70,0x88,0x88,0x88,0x70,0x00, //o
0x08,0xFC,0x24,0x24,0x18,0x00, //p
0x18,0x24,0x24,0xFC,0x80,0x00, //q
0x08,0xFC,0x04,0x04,0x08,0x00, //r
0x48,0x94,0x94,0x94,0x64,0x00, //s
0x08,0x7C,0x88,0x88,0x40,0x00, //t
0x08,0x7C,0x80,0x80,0xFC,0x00, //u
0x1C,0x60,0x80,0x60,0x1C,0x00, //v
0x3C,0xC0,0x3C,0xC0,0x3C,0x00, //w
0x84,0x48,0x30,0x48,0x84,0x00, //x
0x84,0x98,0x60,0x18,0x04,0x00, //y
0xC4,0xA4,0x94,0x94,0x8C,0x00}; //z
U digital[10][6]={
0x00,0x7E,0x91,0x89,0x7E,0x00, //0
0x00,0x80,0x82,0xFF,0x80,0x00, //1
0x00,0xC2,0xA1,0x91,0x8E,0x00, //2
0x00,0x42,0x89,0x89,0x76,0x00, //3
0x00,0x38,0x24,0x22,0xFF,0x00, //4
0x00,0x8F,0x89,0x89,0x71,0x00, //5
0x00,0x7E,0x89,0x89,0x71,0x00, //6
0x00,0x03,0xF1,0x09,0x07,0x00, //7
0x00,0x76,0x89,0x89,0x76,0x00, //8
0x00,0x4E,0x91,0x91,0x7E,0x00}; //9
void time(){
U i,j;
for(i=200;i>0;i--)
for(j=200;j>0;j--);
U scan(){
U i;
if(!key){
time();
while(!key);
return 2;
if(sw && num>1){
sw=0;
for(i=1;i<81;i++)
a[i]=0;
return 3;
return 0;
void iic_init(){
scl=1;_nop_();_nop_();
sda=1;_nop_();_nop_();
void iic_sta(){
sda=0;_nop_();_nop_();
void iic_rsp(){
U i=0;
while(sda&&(i++<255));
scl=0;_nop_();_nop_();
void iic_stp(){
void iic_wr(U x){
U i,temp;
temp=x;
for(i=0;i<8;i++){
temp<<=1;
sda=CY;_nop_();_nop_();
void command(U x){
iic_sta();
iic_wr(0x78);iic_rsp(); //address of OLED
iic_wr(0x00);iic_rsp(); //address of register
iic_wr(x);iic_rsp();
iic_stp();
void dat(U x){
iic_sta();
iic_wr(0x40);iic_rsp(); //address of register
iic_stp();
void OLED_SetPos(U x,U y){ //set_pos(place,page)
command(0xb0+y);
command(((x&0xf0)>>4)|0x10);
command(x&0x0f);
void OLED_clear(){
U i,j;
for(i=0;i<8;i++){
OLED_SetPos(0,i);
for(j=0;j<128;j++){
dat(0x00);
void OLED_Init(){
command(0xae);command(0x20);command(0x10);command(0xb0);
command(0xc8);command(0x00);command(0x10);command(0x40);
command(0x81);command(0xff);command(0xa1);command(0xa6);
command(0xa8);command(0x3f);command(0xa4);command(0xd3);
command(0x00);command(0xd5);command(0xf0);command(0xd9);
command(0x22);command(0xda);command(0x12);command(0xdb);
command(0x20);command(0x8d);command(0x14);command(0xaf);
OLED_clear();
void OLED_String(U page,U *str){
U character,j;
U count_character_num=0;
while(*str){
OLED_SetPos(count_character_num*6,page);
character = *str;
if(character>='0' && character<='9')
for(j=0;j<6;j++)
dat(digital[character-'0'][j]);
else if(character=='.')
for(j=0;j<6;j++)
dat(dt_pls[0][j]);
else if(character>='A' && character<='Z')
for(j=0;j<6;j++)
dat(alpha[character-'A'][j]);
else if(character>='a' && character<='z')
for(j=0;j<6;j++)
dat(bet[character-'a'][j]);
else if(character=='+')
for(j=0;j<6;j++)
dat(dt_pls[1][j]);
else dat(0x00);
str++;
if(++count_character_num*6>120){
if(++page==8){
page=0;
OLED_clear();
void wificommand(U k[]){
U i;
ES=0;
TI=1;
puts(k);
while(!TI);
TI=0;
ES=1;
while(1){
if(a[1])
OLED_String(page,a);
if(scan()==2){
for(i=1;i<81;i++)
a[i]=0;
break;
if((page=4-page)==0)
OLED_clear();
void wifi_Init(){
wificommand(order1);
wificommand(order2);
wificommand(order3);
wificommand(order4);
wificommand(order5);
wificommand(order6);
time();time();time();time();
void doublechat(){
U i,l;
while(1){
if(a[3]=='+' && a[4]=='I' && a[5]=='P' && a[6]=='D' && sq){
sq=0;
l = (a[11]>='0'&&a[11]<='9')?(a[10]-'0')*10+(a[11]-'0'):a[10]-'0';
if(a[12]=='2' && a[13]=='2' && a[14]=='2'){
red=1;
blue=0;
green=0;
else if(a[12]=='3' && a[13]=='3' && a[14]=='3'){
red=0;
blue=1;
green=0;
else if(a[12]=='4' && a[13]=='4' && a[14]=='4'){
red=0;
blue=0;
green=1;
if(a[8]-'0'){
if(l==1){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,1\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==2){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,2\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==3){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,3\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==4){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,4\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==5){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,5\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==6){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,6\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==7){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,7\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==8){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,8\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==9){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,9\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==10){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,10\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==11){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,11\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==12){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,12\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==13){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,13\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==14){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,14\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==15){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,15\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==16){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,16\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==17){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,17\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==18){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,18\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==19){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,19\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else{
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=0,20\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else{
if(l==1){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,1\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==2){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,2\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==3){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,3\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==4){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,4\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==5){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,5\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==6){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,6\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==7){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,7\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==8){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,8\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==9){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,9\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+12);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==10){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,10\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==11){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,11\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==12){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,12\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==13){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,13\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==14){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,14\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==15){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,15\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==16){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,16\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==17){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,17\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==18){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,18\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else if(l==19){
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,19\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
else{
st=0;
ES=0;
TI=1;
printf("AT+CIPSEND=1,20\r\n");
while(!TI);
TI=0;
time();
TI=1;
puts(a+13);
while(!TI);
TI=0;
ES=1;
time();
st=1;
if(a[1])
switch(scan()){
case 3:
sq=1;
goto lop;
case 2:
for(i=1;i<81;i++)
a[i]=0;
OLED_clear();
sq=page=0;
lop:
page+=2;
if(page==8){
time();time();time();time();time();time();
OLED_clear();
page=0;
int main(){
TMOD=0x21;
TH1=TL1=0xfd;
TH0=0x4c;
TL0=0xd0;
EA=ET0=ES=SM1=TR1=REN=1;
SM0=TR0=0;
iic_init();
OLED_Init();
wifi_Init();
TR0=1;
page=-2;
OLED_clear();
OLED_String(2,"Waiting For");
OLED_String(4,"Connection...");
while(1){
doublechat();
void tim() interrupt 1{
TH0=0x4c;
TL0=0xd0;
num++;
void sep() interrupt 4{
U i,p;
RI=0;
for(i=1;i<81;i++)
if(a[i-1]&&!a[i]){
if(st)a[i]=SBUF;
else p=SBUF;
num=0;
sw=1;
break;
