標題: LCD12864主控T6963已用51單片機點亮 [打印本頁]
作者: rayin    時間: 2020-11-22 15:37
顯示屏12864 用89C52點亮,下一步準備把DS12887搞一起再做一個電子時鐘。顯示屏要加大。
Resize of Resize of IMG20201122152039.jpg (103.46 KB, 下載次數(shù): 97)
Resize of Rotation of IMG20201122151857.jpg (173.94 KB, 下載次數(shù): 138)
作者: rayin    時間: 2020-12-27 21:12
#include <regx52.h>
#define DataPort P2
sbit Wr=P1^0;
sbit Rd=P1^1;
sbit CD=P1^2;
sbit CS=P1^3;
sbit RST=P1^4;
//unsigned char
void t(unsigned char para)
{for(;para;para--);}
void delay(unsigned int para)
        unsigned int wdtime=0xffff;
        for(;para;para--)
                for(;wdtime;wdtime--);
void InstruWrite(unsigned char param)
{ RST=1;CS=1;Wr=1;Rd=1;CD=1;
        CS=0;Wr=1;Rd=1;CD=1;
        Wr=0;//CD=1;
        t(5);
        DataPort=param;
        t(6);
        CS=0;Wr=1;CD=1;
void DataWrite(unsigned char param)
        CS=0;Wr=1;Rd=1;CD=0;
        Wr=0;//CD=0;
        t(5);
        DataPort=param;
        t(6);
        CS=0;Wr=1;CD=1;
void AutoWrite(void)
        InstruWrite(0xb0);
void AutoEnd(void)
        InstruWrite(0xb2);
void TextHomeSet(unsigned char paraH,unsigned char paraL)
        DataWrite(paraL);        DataWrite(paraH);
        InstruWrite(0x40);
void TextAreaSet(unsigned char columns)
        DataWrite(columns);DataWrite(0x00);
        InstruWrite(0x41);
void GraphicHomeSet(unsigned char paraH,unsigned char paraL)
        DataWrite(paraL);DataWrite(paraH);
        InstruWrite(0x42);
void GraphicAreaSet(unsigned char columns)
        InstruWrite(0x43);
void CursorSet(unsigned char para)
        InstruWrite(para);
void AddressSet(unsigned char paraH,unsigned char paraL)
        DataWrite(paraL);
        DataWrite(paraH);
        InstruWrite(0x24);
void ModeSet(unsigned char para)
        InstruWrite(para);
void InitLcd(void)
        TextHomeSet(0x00,0x00);
        TextAreaSet(22);
        GraphicHomeSet(0x00,0xb0);
        GraphicAreaSet(22);
        ModeSet(0x80);
void Printf(unsigned char position,unsigned char leng,unsigned char ptr)
        InstruWrite(0x97);
        AddressSet(0x00,position);
        InstruWrite(0xa7);
        AutoWrite();
        for(;leng;leng--)
        {        DataWrite(ptr++);
                if(ptr>0x80)ptr=0x00;
        AutoEnd();
void Character(void)
{  unsigned char x,y,d=0x00;
        InstruWrite(0x97); //text mode
        AddressSet(0x00,0x00);
        InstruWrite(0xa7);
        AutoWrite();
        for(x=0x00;x<22;x++)
        { for(y=0x00;y<16;y++)
                { DataWrite(d++);
                        if(d>0x80) d=0x00;  //7f
        AutoEnd();
void Bar(void)
        unsigned char x,y;
        InstruWrite(0x98);
        AddressSet(0x00,0xb0);
        AutoWrite();
        for(y=0;y<64;y++)
                for(x=0;x<11;x++)
                { if(y+6*x>=64) DataWrite(0xff);
                  else DataWrite(0x00);
                  DataWrite(0x00);
        AutoEnd();
void ET(void)
{ unsigned char x,y;
        InstruWrite(0x97);
        AutoWrite();
        for(y=0;y<8;y++)
         for(x=0;x<22;x++)
         { DataWrite(0x25);DataWrite(0x34);         }
        AutoEnd();
void Boundary(void)
        unsigned char x,y;
        InstruWrite(0x98);
        AutoWrite();
   for(y=0;y<64;y++)
           for(x=0;x<22;x++)
           { if(y==0||y==63) DataWrite(0xff);
             { if(x==0)        DataWrite(0x20);
               else { if(x==21) DataWrite(0x10);
   AutoEnd();
void CheckBoard(unsigned char paraA,unsigned char paraB)
{ unsigned char i,j;
        InstruWrite(0x98); //graghic mode
        AutoWrite();
        for(i=0;i<32;i++)
        { for(j=0;j<22;j++) DataWrite(paraA);
          for(j=0;j<22;j++) DataWrite(paraB);
        AutoEnd();
void main(void)
{        unsigned char i=0;
        InitLcd();
        for(;1;i++,i%=8)
           switch(i)
           { case 0: Character();                                         break;
                   case 1: Boundary();                                                break;
                   case 2: Bar();        break;
                   case 3: CheckBoard(0xff,0xff);break;
                   case 4: CheckBoard(0x00,0x00);break;
                   case 5: CheckBoard(0xaa,0x55);break;
                   case 6: CheckBoard(0x55,0xaa);break;
                   case 7: ET();                        break;
     delay(0x5fff);
                 //while(1);
作者: 啤酒瓶子老大    時間: 2021-3-26 10:18
留個記號。我好像有一個6963的。
作者: mengsiu    時間: 2021-10-17 21:56
本帖最后由 mengsiu 于 2021-10-17 22:09 編輯
正常點亮
作者: njzr    時間: 2021-10-17 22:42
樓主的屏有問題啊,顯示濃淡不一,如果不是硬件故障那就是初始化代碼設(shè)置有錯誤,比如分壓比等參數(shù)
作者: rayin    時間: 2021-10-20 09:47
顯示畫面切換的速度太快了,拍照正好拍到這個切換的畫面的時間點上了,就是上面這個結(jié)果,我用到現(xiàn)在平是沒問題。
